Polk Audio RC60i White (Pr) 6.5 Inch Round 2-Way In-Wall or Ceiling Loudspeaker
5.0
based on 1 review
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.4
$119.99 at Crutchfield
Find it at Amazon
Find it at Ebay
$119.99
from 1 store
Pros
  • Attractive design (1)
  • Crisp sound (1)
  • Easy to connect (1)
  • Great sound quality (1)
  • Powerful (1)
See less See more
Best Uses
  • Home theater (1)
Provided by OneCall
RCi Series In-Wall Speakers deliver incredible Polk sound to every room in your home without using any floor or shelf space! Now you have new options for more flexibility and performance from Polk Audio.
Out of the box and into the wall (or ceiling), that`s how easy it is to install new Polk Audio RCi Series In-Wall Loudspeakers like the RC60i. Dynamic Balance components and Aimable Tweeters ensure spacious imaging with amazing clarity and well-balanced sound in any listening position, not just a small sweet spot. Paint them to match your décor and they practically disappear, leaving you with nothing but high performance sound! Installation is easy as 1-2-3: cut one hole, feed the wires, and simply drop the speaker in. Rotating Cams secure the speaker safely with no extra assembly or mess.
The RC60i features:
  • Round shape and flush design allows the RC60i to mimic the look of a recessed lighing fixture -- the ultimate in stealth sound!
  • Aimable tweeters for direct high frequency control; excellent imaging even for off-axis listening positions... (Tweeter shown below is on RC55i, but you get the idea.)
  • Durable, moisture resistant materials for safe use in bathrooms, kitchens, saunas, even under outdoor eaves.
  • Wide dispersion design for even sound-coverage throughout even large rooms.
  • Rotating Cam Mounting System: the fastest and easiest installation system ever:
  • Rubber driver-surround outlasts cheap foam surrounds (see Competitors, inferior) for years of trouble-free performance.
  • Infinite Baffle Tuning uses the virtual enclosure of in-wall space for superior bass response.
  • Paintable grille and flange allows Polk in-wall speakers to virtually disappear in your room.
  • Timbre-matched to the Polk Audio Monitor Series for seamless, enveloping imaging when used in a home theater system.
  • Specification Description
    UPC 747192106904
    Color White
    Diameter (Inches) 8.875
    Frequency Response 40Hz-27kHz
    Hole Cutout Dimension 7.5625
    Impedance 8 ohms
    Mounting Depth 2.375
    Pre-Construction Mounting Brackets Optional
    Sensitivity 89dB
    Speaker Terminals Spring Terminals
    Speaker Type 2-Way
    Speaker Type Ceiling Mount
    Tweeter Size (Inches) 0.75
    Woofer Size (Inches) 6.5
    Polk Audio RC60i White (Pr) 6.5 Inch Round 2-Way In-Wall or Ceiling Loudspeaker Questions
    Questions and Answers
    Where to Buy
    $119.99
    BizRate Rating Outstanding 9.4
    Product Reviews
    Last update: Jul 6, 2009
    Polk Audio RC60i White (Pr) 6.5 Inch Round 2-Way In-Wall or Ceiling Loudspeaker Reviews
    Displaying 1 - 1 of 1 Reviews
    Show
    Sort by
    I would buy this product again and again
    5.0
      Pros
    • Attractive Design
    • Crisp Sound
    • Easy To Connect
    • Great Sound Quality
    • Powerful
      Cons
    • None
      Best Uses
    • Home Theater
    "love the fact you don't have to look at speakers in the room. sound is incredible! love it!!! "
    Was this Speaker & Subwoofer review on the Polk Audio RC60i White (Pr) 6.5 Inch Round 2-Way In-Wall or Ceiling Loudspeaker helpful to you?
    Jul 6 2009
    RICKY
    Arizona
    I am:
    • Practical
    • Professional
    • Tech Savvy
    Reviewed at:
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
