Polk Audio Monitor 70 Black (Ea) 3-Way Floorstanding Loudspeaker
4.3
based on 3 reviews
Ratings Distribution
5 star
1
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.4
Pros
  • Attractive design (3)
  • Easy to connect (3)
  • Great sound quality (3)
  • Powerful (2)
See less See more
Cons
  • Wood quality (1)
Best Uses
  • Large rooms (3)
  • Audiophiles (2)
Provided by OneCall
The name Monitor is special to Polk Audio. The original Polk Audio Monitor Series, produced in the mid-1970s, ushered in the modern loudspeaker era by setting the standard for performance and value. The original Monitor Series is the line that made Polk Audio famous with its simple, sturdy construction, clear, accurate sound, powerful bass and superior imaging all at a price that made great sound available to everyone.
The newly reborn Monitor Series is classic Polk: a quality-built, affordable line of high performance loudspeakers for music and home theater. They are highly efficient, so they can be driven easily by unpretentious receivers, and they are voice matched for lifelike surround sound environments. The Monitor Series boasts a stylish look that complements today`s flat screen technology, with wood grain finishes and modern Titanium faces, and beefy stabilizer feet on the tower models. Built for speed, sound quality and value, the Monitor Series is a great introduction to high performance sound.
The Monitor 70 features:
  • High efficiency design allows the Monitor Series to reveal the classic Polk Audio sound (open, spacious and clear) even when driven by modestly-powered amplifiers and receivers.
  • 1-inch (25mm) Fabric/Polymer Composite Dynamic Balance Dome Tweeter with powerful Neodymium magnet structure delivers clear and detailed high frequency response for realistic reproduction of vocals and instruments.
  • 6 1/2-inch Bi-Laminate Composite Dynamic Balance Drivers are lightweight and stiff with good damping for high efficiency, excellent bass and lower distortion.
  • Multiple small-diameter driver design delivers wide dispersion, better mid-range, and more detailed bass response for an open, box-less, three-dimensional sound.
  • Non-resonant all-MDF enclosure construction with ¾-thick baffles and front-to-back and side-to-side internal bracing ensures cleaner, clearer, more lifelike sound quality.
  • Crossovers use Mylar bypass capacitors for more detailed high frequencies.
  • Dual Five-Way Binding Post Connectors, allowing for more secure hook-up options, as well as bi-wiring and bi-amping flexibility.
  • Monitor Series speakers are modern living accessories that make a stylish statement in either Black or Cherry wood grain finish, with Titanium faces.
  • Magnetically shielded for safe placement on or near TVs and video monitors with no risk of video distortion.
  • Bold, fat stabilizer feet that ensure stability on carpet or hard floors for more precise bass response and superior imaging.
  • Slim tower design has a footprint of less than one square foot.
  • Critically Tuned Flared Port minimizes port noise (chuffing) for good low frequency extension with low distortion, resulting in natural, full-bodied sound with rich bass.
  • Specification Description
    Model MONITOR70
    UPC 747192110581
    Color Black
    Crossover Frequency 2.6kHz
    Depth (Inches) 14.75
    Frequency Response 30Hz-25kHz
    Height (Inches) 42
    Impedance 8 ohms
    Magnetic Shielding Yes
    Midrange Size (Inches) (2) 6.5
    Sensitivity 90dB
    Speaker Terminals 5-Way Binding Post
    Speaker Terminals Bi-Wire Capable
    Speaker Type 3-Way
    Speaker Type Floor Standing
    Tweeter Size (Inches) 1
    Weight (Pounds) 47
    Width (Inches) 7.75
    Woofer Size (Inches) (2) 6.5
    Polk Audio Monitor 70 Black (Ea) 3-Way Floorstanding Loudspeaker Questions
    Questions and Answers
    Where to Buy
    Amazon   at Amazon.com
    ebay
    eBay listings for: Monitor 70 Black (Ea) 3-Way Floorstanding Loudspeaker
    See all eBay results
      at eBay.com
    Product Reviews
    Last update: Nov 5, 2008
    Polk Audio Monitor 70 Black (Ea) 3-Way Floorstanding Loudspeaker Reviews
    Displaying 1 - 3 of 3 Reviews
    Show
    Sort by
    Cheap price, Great sound, [...]
    4.0
      Pros
    • Attractive Design
    • Easy To Connect
    • Great Sound Quality
    • Powerful
      Cons
    • None
      Best Uses
    • Audiophiles
    • Larger Rooms
    "I was looking for some front channel speakers that would serve my musical tastes and work as fronts for my surround setup. These do both perfectly but don't expect much base. Definitely add a sub. "
    Was this Speaker & Subwoofer review on the Polk Audio Monitor 70 Black (Ea) 3-Way Floorstanding Loudspeaker helpful to you?
    Jun 18 2008
    dotcommark
    Louisville, KY
    I am:
    • Tech Savvy
    Reviewed at:
    I would buy this product aagin.
    4.0
      Pros
    • Attractive Design
    • Easy To Connect
    • Powerful
      Cons
    • Wood Quality
      Best Uses
    • Audiophiles
    • Larger Rooms
    "The sound is very good. It has a nice bass which complements the the pront and sub. "
    Nov 4 2008
    V the Player
    Thousand Oaks
    I am:
    • Audiophile
    • Tech Savvy
    Reviewed at:
    [1 of 4 customers found this review helpful]
    Great Value
    5.0
      Pros
    • Attractive Design
    • Easy To Connect
      Cons
    • None
      Best Uses
    • Larger Rooms
    "Replaced a 20 year old set of Polk bookshelf speakers with these. Worth every cent--the sound is far more clear at the high end, and I've got good bass too. "
     Report Abuse  (1)  (3)  0 comments
    Nov 5 2008
    Mike
    Scarsdale, NY
    I am:
    • Tech Savvy
    Reviewed at:
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    ebay
      at eBay.com
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
