Polk Audio DSW4000 MicroPRO 12-Inch 1200 Watt Powered Subwoofer
#163
4.2
based on 5 reviews
from $999.95 - $1,999.95
Ratings Distribution
5 star
4
4 star
0
3 star
0
2 star
0
1 star
1
Category Average
4.4
Low Price:
$999.95 at OneCall
$999.99 at J&R Electronics
Find it at Amazon
Pros
  • Attractive design (2)
  • Easy to connect (2)
  • Great sound quality (2)
  • Powerful (2)
  • Even my wife likes it (1)
See less See more
Best Uses
  • Home theater (2)
  • Basic systems (1)
Provided by OneCall
You'll hear and feel material that you've never felt before!
Who should listen to the Polk DSW MicroPro series? Anyone looking for a large quantity AND quality of bass, from a compact enclosure. DSW MicroPro is suitable for any genre of music, and any style of movie. It works great for video games too.
But don't let their small size fool you, they play loud and deep, providing powerful, musical bass. With a host of innovative features including a quadrilateral fluid coupled bass radiator allow huge bass from a small cabinet. A unique inverted dustcap design gives the woofer an elegant look while eliminating the need for a grille. All these features add up for stellar subwoofer performance from a compact enclosure.
Other advanced MicroPro features include:
Remote Control
Allows adjustment of subwoofer functions at your finger tips. No more getting up and sitting down to adjust the volume.
AutoPRO
Automatic Polk Room Optimizer which uses a microphone to take actual samples of the performance in your room, and adjust accordingly to smoothen out the response. Polk Room Optimizer (PRO) is also included and corrects for different room placements.
Multiple Power Management Options
The subwoofer can be turned on and off via 12 volt trigger, automatic signal sensing on/off or manual remote control operation.
Beautifully styled Cabinet
Extensively braced with an extremely thick 1" MDF front baffle. The MicroPro cabinet not only looks great but is structurally sound. The subwoofers stand on firm rubber feet so they won't go sliding across the floor at high volume.
Quadrilateral Bass Radiator
The quadrilateral design offers more radiating area then a round design. This is the magic behind the subwoofer's ability to play so low, while maintaining a compact size.
Advanced Digital Amplifier allows for high efficiency, bullet proof reliability and minimal heat generation. Each model has 1200 watts of continuous power on tap. That's over 1.5 horsepower! It can deliver 2400 watts peak!
Feedforward Distortion Supression Technology minimizes distortion while maximizing acoustic output- the best of both worlds.
Subwoofer Driver Design & Technology
The robust woofer is the powerhouse behind the subwoofer and borrows a host of innovative technology from our top of the line Signature Reference Mobile Series.
  • Basket is cast alumnium instead of inferior stamped steel as seen on cheaper designs. What this means for you is an extremely rigid frame that will not flex when handling the 1200 watt amplifier. Special vents in the basket allow air circulation to keep the voice coil cool.
  • Cone features an inverted dustcap and surround provide extreme stiffness. For further cone rigidity, it's attached to the woofer's drive mechanism via 4.5" diameter ABS Cone coupler. The inverted woofer cone matches the finish of the cabinet and eliminates the need for any grille. The DSW MicroPro 4000's woofer and enclosure is elegantly finished in gloss black.
  • Magnets Double stacked magnets give the woofer incredible power, maximizing the magnetic strength of the woofer's drive mechanism.
  • Surround & Spiders Inverted rubber surround controls the woofer and allows incredible travel and will not break down, even after relentless pounding. Dual spiders on both the woofer and passive radiator allow linear woofer control even at maximum volumes.
  • Specification Description
    Model AM4455-A, DSW4000, PK-DSW4000
    UPC 747192112868
    Amplifier 1200 Watts
    Depth (Inches) 16.5
    Height (Inches) 16.75
    Line Level LFE Input
    Line Out Yes
    Speaker Level Inputs Yes
    Speaker Level Outputs Yes
    Weight (Pounds) 57
    Width (Inches) 15.5
    Woofer Size (Inches) 12
    Polk Audio DSW4000 MicroPRO 12-Inch 1200 Watt Powered Subwoofer Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Nov 10, 2009
    Polk Audio DSW4000 MicroPRO 12-Inch 1200 Watt Powered Subwoofer Reviews
    Displaying 1 - 5 of 5 Reviews
    Show
    Sort by
    Nothing Micro about the sound
    5.0
      Pros
    • Attractive Design
    • Crisp Sound
    • Easy To Connect
    • Great Sound Quality
    • Powerful
      Cons
    • None
      Best Uses
    • Home Theater
    "This is a solid sub it completely blows away my old bose accoustimass sub. Couldn't be happier. Would highly recommended this to anyone serious about their sound setup. This is great for games and movies. "
    Was this Speaker & Subwoofer review on the Polk Audio DSW4000 MicroPRO 12-Inch 1200 Watt Powered Subwoofer helpful to you?
    Nov 10 2009
    Jimbo
    Riverview, FL
    I am:
    • Audiophile
    • Tech Savvy
    Reviewed at:
    Price: $999.99
    WOW!......
    5.0
      Pros
    • Attractive Design
    • Easy To Connect
    • Even My Wife Likes It
    • Powerful
      Cons
    • None
      Best Uses
    • Basic Systems
    • Home Theater
    "WOW!This is an awesome sub,easy to set up and pleasing to the eyes, even my wife thinks it looks great, sounds amazing and doesn't distort when pushed at high volumes, be warned your neighbors will be knocking your door and not to borrow sugar, worth every penny, I'll definitely recommend this produ …"  Read Full Review »
    Sep 12 2009
    Perfectionist
    Brooklyn, NY
    I am:
    • Audiophile
    • Movie Enthusiast
    Reviewed at:
    Price: $999.99
    [3 of 3 customers found this review helpful]
    Exceptional performance from small package
    5.0
    "It is stunning the amount of clean, powerful bass this little cube pushes out! It has the ability to set not only the volume, but the phase (0,90,180,270), and has a room optimizer. The bass is powerful and very clear. It is also a furniture-quality piece. Very nice presentation. My wife doesn't min …"  Read Full Review »
     Report Abuse  (3)  (0)  0 comments
    Aug 15 2008
    Christopher M. Griffin
    Orlando, FL United States
    Reviewed at:
    Price: $1,999.95
    [1 of 1 customers found this review helpful]
    Best bang for the buck!
    5.0
    "This is by far the best subwoofer that I have ever heard. I picked this up because my old Verwin Vega 12" wasn't doing it for me anymore, and my Polk RT20P towers needed something to provide a matching bass with. Let me just say that this is much smaller than my old 12" but pushes out six times as …"  Read Full Review »
     Report Abuse  (1)  (0)  0 comments
    Feb 27 2009
    460_mustang
    Chicago
    Reviewed at:
    Price: $1,999.95
    [3 of 12 customers found this review helpful]
    Purchase Elsewhere
    1.0
    "Recieved my DSW MicroPRO 4000 order today after overnight ordering it, only to find out that UPS completely destroyed the item. Seriously looks like they drug the item behind the truck for several blocks.. Called Amazon customer service who could not help me and Amazon's managers were convienantly n …"  Read Full Review »
     Report Abuse  (3)  (9)  0 comments
    Oct 14 2008
    J. Hathaway
    Los Angeles, CA
    Reviewed at:
    Price: $1,999.95
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
