Plantronics Voyager PRO Bluetooth Speakerphone
#284
3.4
based on 5 reviews
from $89.99
Ratings Distribution
5 star
2
4 star
1
3 star
0
2 star
1
1 star
1
Category Average
3.7
$89.99 at RadioShack
Find it at Amazon
Find it at Ebay
Pros
  • Easy to use (4)
  • Clear signal (3)
  • Comfortable (3)
  • Lightweight (3)
  • Nice sound (3)
  • Durable (2)
  • Good battery life (2)
  • Good volume control (1)
See less See more
Cons
  • As ad-does not have eq (1)
  • Heavy / bulky (1)
  • Heavy behind the ear (1)
  • Poor battery life (1)
  • Poor sound quality (1)
  • Spotty signal (1)
  • Uncomfortable (1)
Best Uses
  • Work (3)
  • Good for commuting (2)
  • Multitasking (2)
  • Travel (2)
  • Around the house (1)
Provided by RadioShack
If you want a superior noise-canceling Bluetooth headset, look no further than the PRO.
Specification Description
Model Voyager Pro/ 79800-7
Accessory Indicator Yes
Battery Type Product
Benefits Dual-mic AudioIQ² keeps the natural sound of your voice while keeping out background noiseBlocks intrusive wind noise with 3 lay
Capacity UOM mAh
Chemistry Lithium Ion
Connections Micro-USB (1)
Connectivity Technology Wireless
Country Of Origin China
Description Header Bluetooth gone PRO.
Display Catalog Number 17-4993
Headphones Technology Bluetooth
Headphones Type Earbuds & earclips
Included in the Box Plantronics Voyager PRO headsetAC charger
Manufacturer Labor Warranty 12
Manufacturer Parts Warranty 12
MAP Price 0.0
New Date Mon Nov 09 00:00:00 CST 2009
Operating Temperature UOM ° F
Power Device rechargeable li-ion battery
Product Depth 3
Product Dimensions UOM inches
Product Height 2
Product Type Headsets
Product Weight 0.1
Product Weight UOM pounds
Product Width 0.5
Rechargeable Yes
Supported Languages English
Transmission Range 33 feet
Plantronics Voyager PRO Bluetooth Speakerphone Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 9, 2009
Plantronics Voyager PRO Bluetooth Speakerphone Reviews
Displaying 1 - 5 of 5 Reviews
Show
Sort by
would not buy again!!!
1.0
    Pros
  • None
    Cons
  • Bulky
  • Uncomfortable
    Best Uses
  • None
"I had to return this because it was causing sores behind my ear. Hard to switch from one ear to the other. Controls close together, hard to adjust while driving. Would not recommend this particular model. This model was a great disappointment! "
Was this Bluetooth Headset review on the Plantronics Voyager PRO Bluetooth Speakerphone helpful to you?
Nov 9 2009
Sama
San Diego. CA
I am:
  • Business Professional
  • Practical
Some calls good, most very poor.
2.0
    Pros
  • Easy To Use
    Cons
  • Poor Sound
  • Short Battery Life
  • Spotty Signal
    Best Uses
  • Travel
  • Work
"Used it on two phones and had very poor luck with both. Thought maybe the first one I bought was defective, took it back for exchange but second was no better.
Battery life shorter than small one it replaced.
Comfort was OK but not as good as I expected. "
Nov 7 2009
Mark
Central, Iowa
I am:
wrongly advertized- no 20 band eq
4.0
    Pros
  • Clear Signal
  • Comfortable
  • Easy To Use
  • Good Sound
  • Lightweight
    Cons
  • As ad-does not have EQ
    Best Uses
  • None
"i am dissapointed that this item is not as advertised. reason for buying was the supposed 20 band equlizer. which it does not have. get your act together radio shack!!!!!! "
Nov 5 2009
josey
thomasville,Ga
[1 of 3 customers found this review helpful]
Best BT Headset I have ever used
5.0
    Pros
  • Clear Signal
  • Comfortable
  • Durable
  • Easy To Use
  • Good Sound
  • More »
    Cons
  • None
    Best Uses
  • Commuting
  • Multitasking
  • Work
"This is the 7th different BT I have used in the past two years. By far it is the best combination in comfort, ease of use, clarity, and noise cancellation of any I have used - ranging in price from $49 to $129. "
 Report Abuse  (1)  (2)  0 comments
Oct 24 2009
Treeman
Plano, TX
I am:
  • Practical
[2 of 2 customers found this review helpful]
Best bluetooth ever!!!
5.0
    Pros
  • Clear Signal
  • Comfortable
  • Durable
  • Easy To Use
  • Good Sound
  • More »
    Cons
  • None
    Best Uses
  • Around The House
  • Commuting
  • Multitasking
  • Travel
  • Work
"Works great! Long barry life. Perfect sound qualtity "
 Report Abuse  (2)  (0)  0 comments
Oct 15 2009
Jimmie the Fist
St Louis MO
I am:
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
