Plantronics T10 Corded Headset Telephone
#41
3.8
based on 24 reviews
Ratings Distribution
5 star
6
4 star
13
3 star
1
2 star
1
1 star
3
Category Average
3.6
$33.25 - $97.42
from 16 stores
More Images
Pros
  • Simple / intuitive controls (10)
  • Clear reception (7)
  • Durable (7)
  • Comfortable handset (5)
  • Great sound quality (5)
  • Nice features (4)
  • Attractive design (2)
  • Nice sound (2)
  • Clear signal (1)
  • Easy setup (1)
See less See more
Cons
  • Poor reception / weak antenna (2)
  • Poor sound quality (2)
  • At lot of static noise (1)
  • Below par quality (1)
  • Confusing / difficult controls (1)
  • No features (1)
  • Not meant to last (1)
  • Not wireless (1)
  • Pricey (1)
  • Too large and bulky (1)
Best Uses
  • Long talks (10)
  • Telecommuting (9)
  • Conference calls (7)
  • High-volume (3)
  • High call volume (2)
  • Everyday (1)
  • Versatile (1)
Provided by CameraWorld.com
Increase your productivity and comfort. Using a telephone and headset solution can increase your productivity by allowing you to handle other tasks while talking on the phone. Additionally, the use of a headset can reduce neck, upper back, and shoulder tension allowing for a more comfortable work environment. Experience the freedom, comfort and great sound quality of a Plantronics Headset Telephone Solution. Do more. Comfortably.
Main Features
  • Manufacturer: Plantronics
  • Manufacturer Part Number: T10
  • Manufacturer Website Address: www.plantronics.com
  • Product Type: Business Phone
  • Phone Lines: 1
  • Buttons & Keys: Keypad, Redial, Flash Button, Volume Control - Earpiece/Tone, Mute Button - with indicator light
  • Standard Warranty: 1 Year(s)
  • Specification Description
    Model 10273676, T10
    UPC 017229017283
    Benefits Single-line telephone with ergonomically designed, convertible headsetNoise-canceling microphone reduces background noiseAdj
    Capacity UOM mAh
    Country Of Origin Taiwan
    Description Header Increase productivity.
    Dialer Location Base
    Dialer Type Keypad
    Display Catalog Number 55010274
    End Product Indicator Yes
    Features Mute with indicator light, so you can control the sound levelCable connects to existing telephone jacks
    Indicators Mute
    Manufacturer Labor Warranty 12
    Manufacturer Part Number T10
    Manufacturer Parts Warranty 12
    MAP Price 0.0
    Max Operating Temperature 120 Fahrenheit
    Min Operating Temperature 39 Fahrenheit
    Model T10
    Multiline Operation Capability Single-line
    Operating Temperature UOM ° F
    Placing / Mounting Desktop
    Product Type Corded phones
    Ringer Control Yes
    Supported Languages English
    Volume Control Yes
    Plantronics T10 Corded Headset Telephone Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Oct 15, 2009
    Plantronics T10 Corded Headset Telephone Reviews
    Most helpful positive review
    [8 of 8 customers found this review helpful]
    Most helpful negative review
    4.0
    Great Asset to a Home Based Business
    "I use this phone for my work-at-home businesses and bought it about a year ago. Its great not to have to put a receiver between my ear and shoulder so I can type with both hands. Also, it frees up my hands in between calls so I can do other things. It has a volume control, but the only thing I would change is to increase the volume even more. On some calls, the caller is difficult to hear on one of my busine..." Read Full Review »
    Jul 27, 2008 by Karlly
    See more positive Plantronics T10 Corded Headset Telephone reviews
    1.0
    Good while it lasts
    "Ok I am here shopping for the THIRD one of these in two years. Average usage about 2 hours per day continuous. Seems the chips of these things are not meant to stand up to continuous talk. Continuous talk seems to burn out the off/on button (same problem two different phones). Seems the on button being lit up for so long shorts that particular curcuit. Too much money for a once a year replacement. Too bad my co..." Read Full Review »
    Mar 14, 2009 by Brammy
    See more negative Plantronics T10 Corded Headset Telephone reviews
    Displaying 1 - 5 of 24 Reviews
    Show
    Sort by
    4.0
      Pros
    • Comfortable Handset
    • Durable
    • Good Sound Quality
    • Nice Features
      Cons
    • None
      Best Uses
    • High Call Volume
    • Long Talks
    "I use this phone for my work-at-home businesses and bought it about a year ago. Its great not to have to put a receiver between my ear and shoulder so I can type with both hands. Also, it frees up my hands in between calls so I can do other things. It has a volume control, but the only thing I wo …"  Read Full Review »
    Was this Telephone Accessory review on the Plantronics T10 Corded Headset Telephone helpful to you?
     Report Abuse  (8)  (0)  0 comments
    Jul 27 2008
    Karlly
    Bowling Green, KY
    I am:
    • Value Oriented
    Reviewed at:
    Price: $79.99
    You get what you see
    4.0
      Pros
    • Easy To Set Up
    • Good Sound
      Cons
    • too large and bulky
      Best Uses
    • Everyday Use
    "The Plantronics T10 replaces a 20-year old Radio Shack equivalent they OEM'ed from AT&T. That older unit served me very well, but the padding on the earphone was disintegrating, and I could not get replacements; and all the switches were filled with static and behaving erratically. I selected this P …"  Read Full Review »
    Oct 12 2008
    mdc
    Kingston, WA
    I am:
    • Value Oriented
    [1 of 1 customers found this review helpful]
    Perfect Home Office Phone
    4.0
      Pros
    • Attractive Design
      Cons
    • None
      Best Uses
    • Conference Calls
    • Telecommuting
    "A recent job change converted me from a full-time office employee to a full-time home employee. I was going to need the ability to talk on the phone, sometimes for extended periods of time, while still having both hands free to type at the computer.
    I researched various types of headset telephon …"  Read Full Review »
     Report Abuse  (1)  (0)  0 comments
    Jun 18 2008
    MdniteEagl
    Mount Arlington, NJ
    I am:
    • Value Oriented
    Reviewed at:
    Price: $64.88
    Good while it lasts
    1.0
      Pros
    • Clear Reception
    • Easy Controls
      Cons
    • Below par quality
    • Not meant to last
      Best Uses
    • Long Talks
    • Telecommuting
    "Ok I am here shopping for the THIRD one of these in two years. Average usage about 2 hours per day continuous. Seems the chips of these things are not meant to stand up to continuous talk. Continuous talk seems to burn out the off/on button (same problem two different phones). Seems the on button b …"  Read Full Review »
    Mar 14 2009
    Brammy
    Georgia
    I am:
    • Gearhead
    • Practical
    • Professional
    Reviewed at:
    Price: $79.99
    Overall a good selection
    4.0
      Pros
    • Easy Controls
      Cons
    • Poor Reception
      Best Uses
    • Conference Calls
    • Long Talks
    • Telecommuting
    "Use this for all types of calls (full time telework, most personal calls evenings and weekends). Love the hands-free-ness of it, but don't like the slight staticky sound when it is not on Mute. Really like the ease with which I can move back and forth between Talk and Mute. "
    Sep 7 2009
    HFK
    Alexandria, VA
    I am:
    • Professional
    Reviewed at:
    Price: $79.99
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
