Plantronics Pulsar 590A Headset
4.1
based on 7 reviews
from
Ratings Distribution
5 star
4
4 star
1
3 star
1
2 star
1
1 star
0
Category Average
3.6
More Images
Pros
  • Clear signal (4)
  • Lightweight (4)
  • Nice sound (3)
  • Durable (2)
  • Good volume control (2)
  • Great sound quality (2)
  • Simple / intuitive controls (1)
  • Sounds good has deep bass (1)
  • Versatile (1)
See less See more
Cons
  • A little uncomfortable (1)
  • Disconnects (1)
  • Flimsy (1)
  • Heavy / bulky (1)
  • Hedset twist nids realign (1)
  • Somewhat bulky (1)
Best Uses
  • Good for commuting (5)
  • Travel (4)
  • Long talks (2)
  • Around the house (1)
  • Battery life is very long (1)
Provided by Beach Audio
The Plantronics Pulsar 590 Series Bluetooth Stereo Headsets deliver
the ultimate in wireless freedom! Seamlessly switch between your
Bluetooth phone and your favorite music or movie so you will never
miss a call. With up to 12 hours of talk time and 10 hours of
listen time, you can enjoy wireless stereo listening on laptops,
PCs, TVs, DVD and MP3 players.
Includes Foldable Headset, AC Charger, In-Flight Cable, USB Charger,
and Travel Case included.
* High fidelity stereo sound for superior audio performance.
* Up to 12 hours talk time and up to 10 hours audio listening time.
* The Universal Adapter included with the Pulsar 590A plugs directly into
most 3.5 mm audio devices, so you can enjoy Bluetooth stereo listening
on laptops, PCs, PDAs, TVs, MP3 and DVD players, and home entertainment
systems.
* Seamlessly switch between calls and music listening.
* Telescoping voice tube provides clear calls and discreet conversations.
* Foldable headset design for convenient travel and compact storage.
* Adjustable headband and pillow-soft ear cushions for superior fit and
wearing comfort.
* Dedicated buttons allow call and music control functions directly from
the headset.
* Convenient desktop charging stand to charge and store your headset.
* Supports Bluetooth Hands-Free and Headset Profiles, Advanced Audio
Distribution Profile (A2DP), Audio/Video, Remote Control Profile (AVRCP),
and Generic Audio/Video Distribution Profile (GAVDP).
* For stereo sound, Bluetooth-enabled devices must support the Advanced
Audio Distribution Profile (A2DP).
-- SPECIFICATIONs -----------------------------------
LISTEN TIME - up to 10 hours
TALK TIME - up to 12 hours
STANDBY TIME - approx. 130 hours
CHARGE TIME - 2 hours
RANGE - Bluetooth standard 33 feet (10 meters)
HEADSET SPEAKERS-
28mm Neodymium
FREQUENCY RESPONSE-
Telephony : 300 Hz to 3600 Hz (CVSD u-law)
Stereo Audio: 20 Hz to 20 kHz (16-bit 48kHz SBC coding)
IMPEDANCE - 32 +/- 4 ohms @ 1 kHz
DISTORTION - www.plantronics.com
Specification Description
Model PLAPUL590A, PULSAR 590A, PULSAR590A
UPC 017229120136
Accessory Indicator Yes
Battery Average Run Time 10
Battery Average Run Time UOM HOURS
Battery Type Product
Benefits High-fidelity stereo* sound offers superior audio performanceSeamlessly switch between your Bluetooth®-enabled phone** and music
Capacity UOM mAh
Connectivity Technology Wireless
Country Of Origin Mexico
Description Header Wireless freedom for your phone and music.
Display Catalog Number 55014772
Features Up to 12 hours talk time and up to 10 hours audio listening time on a full chargeUniversal adapter plugs directly into most 3.5mm aud
Headphones Type Over the head
Manufacturer Labor Warranty 2
Manufacturer Part Number PULSAR 590A
Manufacturer Parts Warranty 2
MAP Price 0.0
Model PULSAR590A
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Disclaimer * For stereo listening, Bluetooth® devices must support the Bluetooth® Audio Distribution Profile (A2DP). Devices that do not support the A2DP
Product Type Headsets
Product Weight UOM pounds
Required to function A2DP support (for stereo listening on Bluetooth® devices)Plantronics universal adapter (for devices without A2DP support)
Size Specialty
Supported Languages English
Plantronics Pulsar 590A Headset Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: Pulsar 590A Headset
See all eBay results
  at eBay.com
Product Reviews
Last update: Jan 15, 2009
Plantronics Pulsar 590A Headset Reviews
Displaying 1 - 5 of 7 Reviews
Show
Sort by
looks nice poor quality
3.0
    Pros
  • Clear Sound
  • Lightweight
    Cons
  • Flimsy
    Best Uses
  • Commuting
  • Long Talks
"this item well it sounds flat but when you push the stop button all the high comes out, also the head band twist where it looks like its fitted sideways have to take it off and twist the head band. i use this primarily for listening to music at work and the battery last for 10 hours str8 or more wit …"  Read Full Review »
Was this Cell Phone Accessory review on the Plantronics Pulsar 590A Headset helpful to you?
Jul 8 2007
work and listen
la habra, ca
I am:
  • Gearhead
  • Loves new gadgets
[1 of 1 customers found this review helpful]
WILL BE THE LAST HEADSET YOU NEED
5.0
    Pros
  • Clear Signal
  • Good Sound
  • Good Volume Control
  • Lightweight
    Cons
  • A LITTLE UNCOMFORTABLE
  • Somewhat bulky
    Best Uses
  • Commuting
  • Travel
"A LITTLE BULKY BUT YOU WONT FIND A BETTER SET THAT HAS ALL THE BELLS AND WHISTLES BELIEVE ME I HAVE TRIED,MY FAMILY HAS NAMED ME MR.GADGET CAUSE OF ALL THE ELECTRONICS I BUY AND THIS IS ONE OF THE BEST BUYS ONE DOWNSIDE IS IF WORN FOR A LONG PERIOD IT TENDED TO MAKE MY EAR TENDER MAYBE NOT ENOUGH PA …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Mar 12 2008
MR, GADGET
ORANGE COUNTY
I am:
  • Gearhead
No question, it's the best
5.0
    Pros
  • Clear Signal
  • Good Sound
    Cons
  • Bulky
    Best Uses
  • Commuting
  • Travel
"Awsome headset, out of question. I've tried a few different headsets, but this one is what you need.Only small thing I personaly don't like, it's round hanging down bluetooth universal adapter for listening music. I wish Plantronics will do some better improvements on adapter's research, like Headse …"  Read Full Review »
Jul 26 2008
Bobby Kim
Seattle, WA
I am:
  • Business Professional
Luv this headset
5.0
    Pros
  • Clear Sound
  • Durable
  • Easy Controls
  • Lightweight
  • Versatile
    Cons
  • None
    Best Uses
  • Commuting
  • Long Talks
  • Travel
"These r my prized posessions along with my Krazor "
Jul 18 2007
Kasim The Dream
Miami Beach, FL
I am:
  • Gearhead
  • Parent
  • Practical
i would buy this product again and again
4.0
    Pros
  • Clear Signal
  • Durable
  • Good Sound
  • Lightweight
    Cons
  • None
    Best Uses
  • Commuting
  • Travel
"this is a great headset absoultely no problem "
Jan 23 2008
muzikalmadness
brooklyn new york
I am:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
