Plantronics CS55H Wireless Earset
#25
4.1
based on 7 reviews
from $189.88 - $329.99
Ratings Distribution
5 star
6
4 star
9
3 star
2
2 star
1
1 star
0
Category Average
3.6
More Images
Pros
  • Lightweight (12)
  • Clear signal (11)
  • Good volume control (10)
  • Nice sound (10)
  • Durable (8)
  • Clear reception (3)
  • Comfortable (3)
  • Simple / intuitive controls (3)
  • Easy to use (2)
  • Good battery life (2)
See less See more
Cons
  • Uncomfortable (2)
  • Echos a lot (1)
  • Inadequate volume (1)
  • Limited range (1)
  • Lots of feed back (1)
  • No caller id (1)
  • No flash button (1)
  • Signal beeps too faint (1)
  • Signal breaks up (1)
Best Uses
  • High-volume (3)
  • Long talks (3)
  • Conference calls (2)
  • Home (2)
  • Multitasking (2)
  • Work (2)
  • Around the house (1)
  • Good around the house (1)
  • Good for commuting (1)
  • Home office (1)
Provided by DollarRite
Plantronics CS55H Home Edition DECT 6.0 Wireless Headset System
Sound like the Pro you are with the Plantronics CS55H Home Edition Wireless Headset System for your home cordless or corded phone. Weve combined the clarity of traditional corded technology with the hands-free mobility of wireless so you can move around your home (up to 300 feet) without interrupting or missing a call. The CS55H uses 1.9GHz voice-dedicated wireless technology greatly reducing interference. Conversations are much easier and professional thanks to the noise-canceling microphone that filters out unwanted noises. Youll come through loud and clear to your clients and colleagues while eliminating the distraction of barking dogs the doorbell or your familys voices.
  • Plantronics 1.9GHz (DECT 6.0) wireless headset
  • For home use
  • Home corded/cordless telephone adapter provides hook/switch control no lifter
    required (2-way RJ-11 splitter also included)
  • Convertible over-the-ear or over-the-head headset
  • 10 Hours of talk time
  • Up to 300ft. range
  • Full charge in 3 hours
  • For use with home telephones
  • Noise canceling microphone
  • Reversible headset fits either ear
  • Power online and charge indicators on base
  • Volume control and mute on headset
  • Call answer/end on headset
  • Online indicator on headset
  • 1 Year manufacturers warranty
  • Silver
Package contents
  • Headset
  • Base unit
  • AC charger
  • Small medium and large earloops
  • Over the head headband
  • Splitter
  • Adapter
  • Manual
Specification Description
Model 73374-07, CS-55H, CS55H
UPC 017229123946
Connection Type Wireless
Sound Mode Mono
Plantronics CS55H Wireless Earset Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 17, 2009
Plantronics CS55H Wireless Earset Reviews
Most helpful positive review
[12 of 12 customers found this review helpful]
Most helpful negative review
[4 of 4 customers found this review helpful]
5.0
I Love Mine
"I was considering the purchase of a Calisto Pro or the CS55H. If you are considering the purchase of either one of these and can not decide like I couldn’t. Then I strongly suggest going to your nearest Staples Store. The one I went to is located at Capital Crossing 2950 East Millbrook Rd. Raleigh, NC. They have both these items “On Display” you can touch and feel them. What I did not like about the Calisto Pro ..." Read Full Review »
May 14, 2008 by Mr. Mike
See more positive Plantronics CS55H Wireless Earset reviews
3.0
OK, but needs more volume
"Fine in general, but inadequate volume with conference calls...." Read Full Review »
Mar 13, 2008 by NE Consultant
See more negative Plantronics CS55H Wireless Earset reviews
Displaying 1 - 5 of 7 Reviews
Show
Sort by
Better than expected
4.0
    Pros
  • Clear Reception
  • Durable
  • Easy Controls
    Cons
  • No caller ID
    Best Uses
  • Conference Calls
  • High Volume
  • Long Talks
  • Walking around my home
"For the record, I hate headsets. But this one passed my distaste tests: comfortable, people can hear me, I can hear them with great dual volume control (on base and headset) and it's wireless so I can walk around and not be held back.
The only thing....no 3 way and no ID? Unless I missed this in t …"  Read Full Review »
Was this Telephone Accessory review on the Plantronics CS55H Wireless Earset helpful to you?
Aug 17 2009
Gadget Gal
Chicago, IL
I am:
  • Gadget gal
  • Tech Savvy
Reviewed at:
Price: $189.88
Great product but expensive
4.0
    Pros
  • Clear Signal
  • Durable
  • Good Sound
  • Good Volume Control
  • Lightweight
    Cons
  • Uncomfortable
    Best Uses
  • Home
"This is great product. I had no problem setting it up and after the initial charge, it just worked like a charm. The only thing is that I use the overhead band. It appears to be a bit too tight and there is no adjustment. I guess I just have to get used to its.
I deducted one star due to unc …"  Read Full Review »
Apr 2 2007
Bob
Cupertino, CA
I am:
  • Parent
  • Practical
  • Work from home
Reviewed at:
4.0
"I love it except for a few little glitches. The tip much be up by your mouth. If it slips down even a little, folks cannot hear you. It is also rather awkward to get on, although quite comfortable once it is on. And, the coordination between the headset and base phone is odd and a bit cumbersome. I …"  Read Full Review »
Jun 15 2008
Jeantoo
MI
Reviewed at:
Excellent Service
5.0
    Pros
  • Clear Reception
  • Durable
  • Easy Controls
    Cons
  • None
    Best Uses
  • High Volume
  • Long Talks
  • Telecommuting
"The price was better than Office Depot and the service was professional, [...] it was up in running in a few hours! "
Aug 13 2009
Lynn
Jacksonville Beach, FLorida
I am:
  • Professional
Reviewed at:
Price: $189.88
Great Home Version Headset
4.0
    Pros
  • Clear Signal
  • Durable
  • Good Sound
  • Great Range
  • More »
    Cons
  • None
    Best Uses
  • Home
"Just wish that Plantronics would make the smaller "blue tooth" size microphone for the home version of their product. "
Mar 15 2007
Bro-Ken
Long Island, New York
Reviewed at:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
