Plantronics CS50 Wireless Office Headset System
#8
4.5
based on 16 reviews
Ratings Distribution
5 star
11
4 star
8
3 star
0
2 star
1
1 star
0
Category Average
3.6
Low Price:
$177.99 at OnSale
 Trusted:
$184.95 at PC Connection
$183.05 at pcRUSH
see all stores
$177.99 - $241.00
from 16 stores
More Images
Pros
  • Durable (7)
  • Clear signal (5)
  • Lightweight (5)
  • Nice sound (5)
  • Simple / intuitive controls (5)
  • Clear reception (4)
  • Good volume control (3)
See less See more
Cons
  • Not loud enough (1)
  • Poor reception / weak antenna (1)
Best Uses
  • Long talks (2)
  • Multiple lines (2)
  • Conference calls (1)
  • Dorm room (1)
  • Hands free office use (1)
  • Handsfree office (1)
  • High-volume (1)
  • In office on long calls (1)
  • Making multiple calls (1)
  • Multi tasking (1)
Provided by MAGo Enterprise
MODEL- CS50 VENDOR- PLANTRONICS FEATURES- Wireless Office Headset SystemThe Plantronics CS50 Wireless Office Headset System brings the ultimate in mobility and handsfree conversations to your phone. The CS50 gives you eight hours of talk time and the wireless convenience to roam up to 300 feet with secure conversations. And taking or ending a call is as simple as pressing a button with the optional Plantronics HL10 Lifter. * Wireless Hands-free MobilityPlantronics CS50 is the next-generation wireless headset system that lets you take the conversation wherever you need to go. Up to 300 feet. * All-day Freedom and ConvenienceWalk and talk for up to 8 hours on the phone without having to recharge your CS50. * Crystal Clear and Secure Conversations The CS50 uses digital 900 MHz technology to deliver calls that are clear private and completely secure. * Intuitive Intelligent InnovativeThe CS50 s integrated IntelliStand makes wireless mobility as easy as answering the phone--pick up the headset and you pick up the call. (Requires HL10 handset lifter sold separately.) And when you are away from your desk you're still in touch to think and talk on your feet either answering or ending a call with the touch of a button. * Stylish Convertible ComfortableThe CS50 is as stylish as it is comfortable with a customizable convertible headset that can be worn over the ear or over the head ensuring all-day wearing comfort. An optional behind-the-head style is also available. SPECIFICATIONs -------------------------------------- Headset Weight : 26 grams Headset Battery : Li-Ion Polymer Battery Recharge Time: 1.5 hours (80%)/3 hours (100%) Headset Microphone : Noise canceling Headset Controls : Volume mute call answer/end Talk Time: 8 hours User Density : 40 Range: Up to 300 ft. Operating Frequency : 900 MHz Digital Security : Yes Compatibility: Most office or PBX-based telephones Wearing Styles : Convertible: over the ear over the head behind the head (with accessory neckband)
Specification Description
Model 10273676, 66664-11, CS-50/HL-10 BUNDLE, CS50
UPC 017229115767
Accessory Indicator Yes
Battery Average Run Time 8
Battery Average Run Time UOM HOURS
Battery Type Product
Benefits Compatible with most office or PBX-based telephonesHeadset fully recharges in less than 3 hours for up to 8 hours of wireless, hands-
Benefits Digital 900MHz for secure conversationsEnables remote or 1-touch call answer/end with your Plantronics headsetNo desktop foo
Capacity UOM mAh
Chemistry Lithium Ion
Connectivity Technology Wireless
Description Header Get wireless.
Description Header Make your desk phone wireless.
Display Catalog Number 55009760
Display Catalog Number 55009761
End Product Indicator Yes
Features Integrated IntelliStand™ makes answering the phone as easy as picking up the headsetStylish headset is convertible for optimal,
Headphones Type Over the head
Headphones Type Specialty & mono
Included in the Box CS50 Wireless HeadsetHL10 Lifter
Included in the Box Plantronics Wireless Office HeadsetCharging cradle1 rechargeable Li-ion batteryReversible earloopsHeadband
Manufacturer Labor Warranty 12
Manufacturer Part Number 66664-11
Manufacturer Part Number CS50
Manufacturer Parts Warranty 12
MAP Price 0.0
Model 66664-11
Model CS50
Operating Temperature UOM ° F
Product Type Headsets
Product Weight 0.98
Product Weight UOM ounces
Radio Frequency Range 900MHz
Recharge Time 3
Recharge Time UOM HOURS
Rechargeable Yes
Supported Languages English
Transmission Range 300 feet
Plantronics CS50 Wireless Office Headset System Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 6, 2009
Plantronics CS50 Wireless Office Headset System Reviews
Most helpful positive review
[6 of 6 customers found this review helpful]
Most helpful negative review
[1 of 1 customers found this review helpful]
5.0
Love it!!
"I love this headset. The whole system works magnificently. Only one little tiny con, and that is the fact that the part of the head-band that the headset clicks into is quite fragile. Other than that, it's clear, lite weight, and easy to hook up...." Read Full Review »
Sep 06, 2007 by Gretchen
See more positive Plantronics CS50 Wireless Office Headset System reviews
2.0
"The company I work for ...
"The company I work for sells 2 wireless headsets one being the plantronics CS50 & the other being the GN Netcom 9120. I've used the GN9102 for months now & decided to demo the CS50 as it is a more attractive headset so more popular with our customers so we decided it was time for us use the same headset here is what I like & don't like.... Likes: 1) Was quite easy to set up & did not require a technicians assis..." Read Full Review »
Aug 18, 2006 by Becky
See more negative Plantronics CS50 Wireless Office Headset System reviews
Displaying 1 - 5 of 16 Reviews
Show
Sort by
[0 of 2 customers found this review helpful]
Comfortable, and very good but...
4.0
    Pros
  • Clear Reception
  • Easy Controls
    Cons
  • Not loud enough
    Best Uses
"This is very comfortable to wear once you find the right combo of ear piece and headset (a selection is included).
Hold a charge fantastically long.
My biggest qualm is finding the right volume, I find I am constantly fiddling with the volume control on the headset and the phone itself. Too …"  Read Full Review »
Was this Telephone Accessory review on the Plantronics CS50 Wireless Office Headset System helpful to you?
 Report Abuse  (0)  (2)  0 comments
Mar 28 2009
NYC pro
NY, NY
I am:
  • Gearhead
  • Practical
  • Professional
  • Tech Savvy
Reviewed at:
Price: $199.99
The pain in my neck is gone!
4.0
    Pros
  • Clear Reception
  • Durable
  • Easy Controls
    Cons
  • None
    Best Uses
  • Multi tasking
  • Multiple Lines
"The pain in my neck has subsided. I no longer have to hold the phone between my shoulder and ear while completing other tasks. The pain is gone! I can move around the office and still talk with customers. "
Aug 6 2009
Rose
Olean, NY
I am:
  • Practical
  • Professional
Reviewed at:
Price: $239.99
2.0
I've used the GN9102 for months now & decided to demo the CS50 as it is a more attractive headset so more popular with our customers so we decided it was time for us use the same hea …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Aug 18 2006
Becky
Undisclosed
Works great for me.
4.0
    Pros
  • Clear Reception
  • Durable
  • Easy Controls
    Cons
  • None
    Best Uses
  • Conference Calls
  • Dorm Room
  • High Volume
  • Long Talks
  • Multiple Lines
"This works great for work. I am on the phone all day and it saves me a kinked neck. I have used it for 3 years now and I am purchasing one for a co-worker. He is now hooked on it also. "
Jun 30 2009
No Kinked Neck
Salt Lake City, Utah
I am:
  • Practical
Reviewed at:
Price: $239.99
[1 of 2 customers found this review helpful]
Small Office Use
4.0
    Pros
  • Clear Signal
  • Durable
  • Good Sound
  • Lightweight
    Cons
  • None
    Best Uses
  • None
"Great small business solution for those who need to be on the phone to make money. Great for our older Lucent phone systems. No signal conflict with several users in a small office environment. "
 Report Abuse  (1)  (1)  0 comments
Jul 21 2008
Pacman
Boise, ID
I am:
  • Business Professional
Reviewed at:
Price: $199.99
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
