PLANTR Plantronics Cell Phone Headset
#323
3.5
based on 46 reviews
from $10.63 - $25.02
Ratings Distribution
5 star
18
4 star
13
3 star
6
2 star
3
1 star
10
Category Average
3.7
Low Price:
$10.63 at ANTOnline
$11.99 at MacMall
Find it at Amazon
More Images
Pros
  • Durable (8)
  • Clear reception (6)
  • Easy to use (6)
  • Lightweight (6)
  • Simple / intuitive controls (4)
  • Clear signal (3)
  • Comfortable (3)
  • Great sound quality (3)
  • Nice sound (3)
  • Good performance (2)
See less See more
Cons
  • Uncomfortable (5)
  • Low volume (3)
  • Poor sound quality (3)
  • Brused behind ear pain (1)
  • Disconnects (1)
  • Fits poorly (1)
  • Hard on the ears (1)
  • Heavy / bulky (1)
  • Not durable (1)
  • Not quite stable enough (1)
Best Uses
  • Around the house (4)
  • Long talks (4)
  • Multitasking (3)
  • Work (3)
  • Conference calls (2)
  • Dorm room (2)
  • High-volume (2)
  • Good for commuting (1)
  • Home office (1)
  • Mobility while on calls (1)
Provided by Buzzillions.com
The Plantronics M220C Headset for Cordless Phones combines an innovative design with a noise-canceling microphone- resulting in a stable- great-sounding headset. The noise-canceling microphone provides call clarity in most environments. The M220C is compatible with most headset-ready cordless phones- and the microphone volume switch lets you optimize the headset to your phone.
  • Product Description: Plantronics M 220C- headset
  • Product Type: Headset- wired
  • Recommended Use: Cordless phone
  • Headphones Type: Headphone- monaural
  • Headphones Form Factor: Over-the-ear
  • Connectivity Technology: Wired
  • Sound Output Mode: Mono
  • Microphone: Built-in- boom
  • Microphone Operation Mode: Mono
Specification Description
Model M-220C, M220C
UPC 017229117198
Accessory Indicator Yes
Benefits Noise-canceling microphone provides call clarity in most environmentsCompatible with most headset-ready cordless phonesMicro
Cables Included Headset cable - integrated
Capacity UOM mAh
Connections 1 x headset
Connectivity Technology Wired
Connector Type 1 x headset
Country Of Origin Switzerland
Description Header Cancel the noise.
Display Catalog Number 43-1927
Headphone Sound Output Mode Mono
Headphones Form Factor Over-the-ear
Headphones Technology Dynamic
Headphones Type Earbuds & earclips
Manufacturer Parts Warranty 1
MAP Price 0.0
Model M-220C
Operating Temperature UOM ° F
Product Type Headsets
Protect your investment. Yes
Supported Languages English
PLANTR Plantronics Cell Phone Headset Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 11, 2009
PLANTR Plantronics Cell Phone Headset Reviews
Most helpful positive review
Most helpful negative review
5.0
Works great! Sounds great!
"I've been using this for hands free conversations with a Panasonic cordless phone for about 5 years. I've replaced the phone with a newer Panasonic model twice, and only had to replace this earpiece once - finally wore out the cord at the plug. The sound both ways is perfect - like having a normal conversation with someone right there in the room with you. The people that had problems might not have realized th..." Read Full Review »
Oct 31, 2009 by RicDB
See more positive PLANTR Plantronics Cell Phone Headset reviews
1.0
Won't stay put!
"I use this product daily but I am now about to buy another one! The reception is great, no problems there. It's also wonderful to have volume and mute control included. Only problem with this is the fit, it does not stay put in your ear no matter how you adjust, the rubber earpiece that goes in your ear comes off at times when you wiggle it to hear your caller or adjust the fit. Most times I have to push it..." Read Full Review »
Feb 07, 2008 by Jen
See more negative PLANTR Plantronics Cell Phone Headset reviews
Displaying 1 - 5 of 46 Reviews
Show
Sort by
5.0
    Pros
  • Clear Signal
  • Comfortable
  • Durable
  • Easy To Use
  • Good Sound
  • More »
    Cons
  • None
    Best Uses
  • Around The House
  • Multitasking
  • Work
"I've been using this for hands free conversations with a Panasonic cordless phone for about 5 years. I've replaced the phone with a newer Panasonic model twice, and only had to replace this earpiece once - finally wore out the cord at the plug. The sound both ways is perfect - like having a normal c …"  Read Full Review »
Was this Bluetooth Headset review on the PLANTR Plantronics Cell Phone Headset helpful to you?
Oct 31 2009
RicDB
Long Beach, New York
I am:
  • Business Professional
  • Parent
  • Practical
Excellent Excellent Excellent
5.0
    Pros
  • Clear Reception
  • Durable
  • Easy Controls
    Cons
  • No CONS
    Best Uses
  • Conference Calls
  • High Volume
  • Long Talks
"I've been using this headset with my cordless phones for well over a year. I work from home and use the headset a minimum of 8 hours per day. And then in the evening on my home phone. It fits well, it stays in place just fine, and the sound is good coming in and going out. Better still, when I g …"  Read Full Review »
Jan 26 2009
Happy Headset User
Leesburg, VA
I am:
  • Practical
  • Professional
Poor reception!
1.0
    Pros
  • Receiver can hear well
    Cons
  • Poor Sound
  • Uncomfortable
    Best Uses
  • None
"Person on the other end can hear you clear. But receiver would not allow me to hear clearly. It also brused me behind the ear, which was extremely painful, for nearly a week. I would not recommend this product. "
Nov 11 2009
NewPhilaMan
New Phila, Oh
I am:
  • Gearhead
  • Practical
Won't stay put!
1.0
    Pros
  • Clear Reception
    Cons
  • Fits poorly
  • Not Durable
    Best Uses
  • Short Talks
Only problem with this is the fit, it does not stay put in your ear no matter how you adjust, the rubber earpiece that goes i …"  Read Full Review »
Feb 7 2008
Jen
Katy, Texas
I am:
  • Practical
  • Professional
Another quadriplegic review
4.0
    Pros
  • Clear Reception
  • Durable
  • Easy Controls
  • Reception is quite good
    Cons
    Best Uses
  • Dorm Room
  • Long Talks
"I will agree with others that the stability of it is to be desired at times. Once you get it to stay put I find it very unobtrusive to use. I use it daily and read where a lot of people have problem with reception, I usually find that it is the volume level on the other parties end. After a perio …"  Read Full Review »
Feb 19 2008
David
Michigan
I am:
  • Practical
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
