Pioneer Elite KURO 60" Plasma TV - PRO151FD
#9
4.8
based on 49 reviews
from $6,499.98
Ratings Distribution
5 star
44
4 star
2
3 star
1
2 star
1
1 star
1
Category Average
4.6
$6,499.98 at Best Buy
Find it at Amazon
Find it at Ebay
More Images
Pros
  • Great picture quality (28)
  • Attractive design (25)
  • Fast setup (12)
  • Simple controls (11)
  • 2 year warranty (1)
  • Best rated plasma ever (1)
  • Best shadow detail (1)
  • Good connection options (1)
  • Great sound quality (1)
  • High resolution (1)
See less See more
Cons
  • Pricey (3)
  • Difficult to set up (2)
  • Complex picture adjustmen (1)
  • Cost (1)
  • Hdmi inputs bend cables (1)
  • Heat (1)
  • Optimum setting pre-selec (1)
Best Uses
  • Home (24)
  • Movies (23)
  • Wall mounting (14)
  • Professional (4)
  • Best flat panel to date (1)
  • Office (1)
  • Video (1)
Provided by Abt Electronics
Pioneer Elite KURO 60" Black Plasma HDTV - PRO151FD/ 1920 x 1080p Full HD Resolution/ 480i/480p/720p/1080i/TRUE 1080p 24fps Signals/ Thinner Cosmetic Design With Elegant Acrylic Bezel/ Four Independent HDMI v1.3 Inputs/ Home Media Gallery Home Network Connectivity/ Subwoofer Output/ Room Light Sensor/ ATSC/NTSC Tuner With Clear QAM/ Picture-In-Picture/ Black Finish
Specification Description
Model PRO-151FD, PRO151FD
UPC 012562887128
Analog Audio (1) Side Input
Analog Audio (2) Rear Input
Analog Audio Rear Output
Analog Audio / Video (1) Side Input
Aspect Ratio 16:9
Component Video Rear Input
Depth (Inches) 3.7
HDMI (1) Side Input
HDMI (3) Rear Input
HDTV HDTV Tuner Built In
Headphone Jack Side Output
Height (Inches) 34.5
Optical Rear Output
Remote Control Learning
Remote Control Pre-Programmed
Resolution 1920 x 1080
RJ45 Ethernet Rear Input
RS-232C Rear Input
S-Video Rear Input
Screen Size (inches) 60
Speakers 18 Watts x 2
Stand Included
Subwoofer Out Rear Output
Tuner ATSC
Tuner NTSC
Tuner QAM
USB Port Side Input
Weight (Pounds) 135
Width (Inches) 66.03
Pioneer Elite KURO 60" Plasma TV - PRO151FD Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 25, 2009
Pioneer Elite KURO 60" Plasma TV - PRO151FD Reviews
Most helpful positive review
Most helpful negative review
[1 of 1 customers found this review helpful]
5.0
THE BEST FLAT PANEL TV PERIOD.
"IF YOUR NOT GOING TO USE A PROJECTOR FOR YOUR HIGH END HOME THEATER, THIS IS THE BEST FLAT PANEL TV PERIOD. ONECALL HAD THE BEST OVERALL PRICE I COULD FIND [...]!AFTER READING ALL THE REVIEWS & DOING A LOT OF RESEARCH THE PIONEER PRO ELITE KURO IS THE BEST FLAT PANEL EVER MADE PERIOD.PIONEER IS LEAVING THE TV MANUFACTURING BUSINESS, SO GET WHY YOU CAN.THE BLACK LEVELS ARE SO GOOD THEY CAN'T EVEN BE MEASURED WITH..." Read Full Review »
Mar 20, 2009 by KODG MAN
See more positive Pioneer Elite KURO 60" Plasma TV - PRO151FD reviews
1.0
Terrible Pioneer Support
"Pioneer Plasmas are exceptional in picture quality. However, when you have a failure, their product support is very poor and very, very costly when available. The Power switch failed on my Pioneer PDP 5030HD and they wanted me to send it into Pioneer and they were going to charge me $600 just to replace the Power switch. Pioneer wouldn't even give a local Authorized Pioneer Servicer the necessary part to make th..." Read Full Review »
Jun 09, 2009 by EddieJ
See more negative Pioneer Elite KURO 60" Plasma TV - PRO151FD reviews
Displaying 1 - 5 of 49 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • BEST RATED PLASMA EVER
  • Great Picture
    Cons
  • COMPLEX PICTURE ADJUSTMEN
    Best Uses
  • BEST FLAT PANEL TO DATE
  • Home
  • Movies
"IF YOUR NOT GOING TO USE A PROJECTOR FOR YOUR HIGH END HOME THEATER, THIS IS THE BEST FLAT PANEL TV PERIOD. ONECALL HAD THE BEST OVERALL PRICE I COULD FIND [...]!AFTER READING ALL THE REVIEWS & DOING A LOT OF RESEARCH THE PIONEER PRO ELITE KURO IS THE BEST FLAT PANEL EVER MADE PERIOD.PIONEER IS LEAV …"  Read Full Review »
PIONEER ELITE KURO PRO 151
Was this Plasma TV review on the Pioneer Elite KURO 60" Plasma TV - PRO151FD helpful to you?
Mar 20 2009
KODG MAN
CLEVELAND, OHIO
I am:
  • Enthusiast
Reviewed at:
[4 of 4 customers found this review helpful]
Even Better Than in the Store
5.0
    Pros
  • Great Picture
    Cons
  • Difficult to Setup
    Best Uses
  • Movies
"I was torn between going with this traditional plasma solution and the new TFT LCD LED units from Samsung/Sony. I'm glad I went with the Pioneer Kuro since the picture quality when hooked up to HD TV channels or Blue Ray disks is absolutely superb. In particular, I am floored whenever I watch the E …"  Read Full Review »
 Report Abuse  (4)  (0)  0 comments
Mar 26 2009
Alex
CT
I am:
  • Enthusiast
Reviewed at:
Best Flat-Screen HDTV I have ever owned!
5.0
    Pros
  • Great Picture
  • No Image Smearing
  • Outstanding black levels
  • Superb Color Calibration
  • More »
    Cons
  • HDMI Inputs Bend Cables
    Best Uses
  • Home
  • Movies
  • Professional
  • Wall Mounting
"I have been receiving HDTV signals for over 10 years. The Pioneer PRO-151FD is the best flat screen (plasma or LCD) that I have ever owned! This plasma has inky black levels, excellent shadow detail, superb color calibration, a wide viewing angle, and does not smear fast-moving images. My plasma vi …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Apr 13 2009
HDTV Guy
Nevada City, CA
I am:
  • Power User
Reviewed at:
[2 of 2 customers found this review helpful]
Stunning
5.0
"I've had this t.v. for about 3 weeks and it's the best thing that I have ever gotten. I have been researching tv's for a while and was down to this model the special edition 65" sharp and the 65" panasonic plasma. The reason I didn't want a plasma originally is the fact that i do a lot of gaming. An …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Aug 2 2008
deltona, fl
Reviewed at:
Price: $6,499.98
I've owned numerous LCD / ...
5.0
"I've owned numerous LCD / Plasma TV's.
The 'best' TV always was wall mounted in the living room.
That was a 2001 Pioneer Plasma 43inch... No LCD could ever match it's image quality and motion ability.
Well my wife surely would not be happy if I returned with a like-size flat panel and it looked " …"  Read Full Review »
Aug 2 2009
DaytonaBob
Daytona Beach, FL
Reviewed at:
Price: $6,499.98
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
