Pioneer DV-410V-K Multi-Format 1080p Upconverting DVD Player
4.3
based on 62 reviews
Ratings Distribution
5 star
32
4 star
22
3 star
4
2 star
1
1 star
3
Category Average
3.6
More Images
Pros
  • Easy setup (35)
  • Easy to use (35)
  • High quality picture (33)
  • Consistent performance (30)
  • Durable (18)
  • Attractive design (2)
  • Reputation as sturdy (1)
  • Skip the blue ray player (1)
See less See more
Cons
  • 3 menus is confusing (1)
  • Dark picture (1)
  • Hard to control 7 ft away (1)
  • Requires careful setup (1)
  • Unattractive design (1)
Best Uses
  • Home (35)
  • Dorm room (4)
  • High volume usage (3)
  • Home theater (2)
  • Office (2)
Provided by B&H Photo Video
If you're searching for the finest quality high-definition video playback solution that will transform your room into a powerful home theater experience, look no further. The Pioneer DV-410V-K DVD Player features an HDMI 1080p HD output, component video output, coaxial digital audio output, PureCinema Progressive-Scan, USB direct input, Windows Media Video (WMV) compatible, MPEG-4 AAC decoding, HD-JPEG, and multi-format DVD playback capabilities. It brings your home theater experience to a whole new level, without breaking the bank. Your current DVD library will look and sound better than ever before, because this player is backwards compatible, capable of upconverting your DVDs to a 1080p high-definition experience. In addition, the Pioneer DV-410V features Dolby Digital and DTS audio surround-sound processing, offering improved fidelity and sonic realism to your DVD movie soundtracks.
Specification Description
Model DV-410V-K
UPC 012562893433
Compatible Formats CD
Compatible Formats CD-R
Compatible Formats CD-RW
Compatible Formats DVD
Compatible Formats DVD+R
Compatible Formats DVD+RW
Compatible Formats DVD-R
Compatible Formats DVD-R DL
Compatible Formats DVD-RW
Compatible Formats DiVX
Compatible Formats JPEG
Compatible Formats MP3
Compatible Formats MPEG4
Compatible Formats SVCD
Compatible Formats VCD
Compatible Formats WMA
Compatible Formats WMV
D/A Converter 24-bit/96kHz
Depth (Inches) 8.46
HDMI Yes
Height (Inches) 1.9
Remote Control Included
Surround Modes DTS
Surround Modes Virtual Surround
USB Port Yes
Video Conversion to HDMI
Weight (Pounds) 3.7
Width (Inches) 16.5
Pioneer DV-410V-K Multi-Format 1080p Upconverting DVD Player Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: DV-410V-K Multi-Format 1080p Upconverting DVD Player
See all eBay results
  at eBay.com
Product Reviews
Last update: Mar 3, 2009
Pioneer DV-410V-K Multi-Format 1080p Upconverting DVD Player Reviews
Most helpful positive review
Most helpful negative review
5.0
Great product for a small price
"This multi-format DVD player is loaded with features that you would expect on a much higher priced player. I connected it to my Samsung LCD TV with an HDMI cable and was watching a movie right away. The factory settings will get you running immediately. The custom setting are easily accessible through a simple to use on-screen menu. The player has the ability to adjust a large number of aspects of both the p..." Read Full Review »
Dec 15, 2008 by Rob the Laser Guy
See more positive Pioneer DV-410V-K Multi-Format 1080p Upconverting DVD Player reviews
3.0
Average excepty for Divx
"At first glance, this dvd player is stylish, and it has the Pioneer name. Controls are easy to work, easy to understand. It plays Divx format, although I don't notice any picture difference between the Pioneer and the Xbox 360 on Divx dvd's. But it does play them. Second, it doesn't recognize all DVD-/+ R dvd's. I played some DVD-/+ R dvd's, and the picture quality is ok at best. Not much different from the dvd ..." Read Full Review »
Aug 10, 2008 by Anonymous
See more negative Pioneer DV-410V-K Multi-Format 1080p Upconverting DVD Player reviews
Displaying 1 - 5 of 62 Reviews
Show
Sort by
5.0
    Pros
  • Consistent Performance
  • Durable
  • Easy To Set Up
  • Easy To Use
  • High Quality Picture
    Cons
  • None
    Best Uses
  • Dorm Room
  • High Volume Usage
  • Home
  • Office
"This multi-format DVD player is loaded with features that you would expect on a much higher priced player. I connected it to my Samsung LCD TV with an HDMI cable and was watching a movie right away. The factory settings will get you running immediately. The custom setting are easily accessible th …"  Read Full Review »
Was this DVD Player review on the Pioneer DV-410V-K Multi-Format 1080p Upconverting DVD Player helpful to you?
Dec 15 2008
Rob the Laser Guy
Lake Forest, CA
I am:
  • Enthusiast
Reviewed at:
[1 of 3 customers found this review helpful]
good player
4.0
"I had the chance to test the player (dv-410 US version) a little bit, and here is my opinion:
BAD:
- The subs for divx are bad. Small, wrong font, the white color is not good enough also. Of course this can be solved with firmware flash.
- The usb port is slow, works fine with small files, but more …"  Read Full Review »
 Report Abuse  (1)  (2)  0 comments
Jun 17 2008
piovanil
Buenos Aires, Argentina
Reviewed at:
[1 of 1 customers found this review helpful]
excellent upconverting dvd player
4.0
    Pros
  • Easy To Set Up
  • Easy To Use
    Cons
  • None to complain about
    Best Uses
  • Home
"Although I have upgraded to a Pioneer Elite DV-48AV since purchasing this model, I have nothing but good things to say about it..It really had a better picture quality (color saturation, sharpness, cinematic depth) than my Sony DVP-NS75H (and that's saying a lot..the Sony is a quite capable player i …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jul 28 2008
JAS Old Man From VA.
Virginia
I am:
  • Practical
Reviewed at:
Lives up to expectations
4.0
    Pros
  • Durable
  • Easy To Set Up
  • Easy To Use
    Cons
  • None
    Best Uses
  • None
"I use this in conjunction with a 37 inch lcd to upconvert standard dvd's..haven't tried the usb port yet, but plan to do so..Picture quality after customization exceeds that of my Sony 75H and delivers excellent resolution when set to 1080P..Structure seems sturdy, menu easily accessible, looks good …"  Read Full Review »
Jul 15 2008
Jas the old man
Somewhere in Virginia
I am:
  • Practical
Reviewed at:
3.0
"At first glance, this dvd player is stylish, and it has the Pioneer name. Controls are easy to work, easy to understand. It plays Divx format, although I don't notice any picture difference between the Pioneer and the Xbox 360 on Divx dvd's. But it does play them. Second, it doesn't recognize all DV …"  Read Full Review »
Aug 10 2008
Undisclosed
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
