Pioneer CDJ-200 Pro CD Player
3.5
based on 4 reviews
from $397.99 - $399.00
Ratings Distribution
5 star
0
4 star
2
3 star
2
2 star
0
1 star
0
Category Average
3.8
More Images
Pros
  • Easy to use (3)
  • Great sound quality (3)
  • Versatile (2)
  • Attractive design (1)
  • Consistent performance (1)
  • Easy setup (1)
  • Professional functions (1)
See less See more
Cons
  • Bad pith bend (1)
  • Difficult to use (1)
  • Not durable (1)
  • Pricey (1)
  • Slow to load (1)
  • Unreliable (1)
Best Uses
  • Home (3)
  • Amateurs (1)
  • Bar djs (1)
  • Bedroom (1)
  • Beginner / getting started (1)
  • Not recommend pioneer (1)
  • Professional (1)
Provided by PSSL.com - ProSound and Stage Lighting
CDJ200 Tabletop CD/MP3 Player: Packed With ExcitementThe Pioneer CDJ200 is an entry level CD turntable combining the key elements of Pioneers professional digital CD decks with a host of innovative features including fullfunction MP3 playback hot loop beat loop and the unique one button loop cutter for creating loops within loops until the beat has been cut to infinity. This technical excellence is complemented by a design thats both visually stunning and supremely practical. The unit is robust compact and portable not to mention truly affordable making it the ideal choice for serious home DJs bars and other installations where space and budget is limited. Features: Plays CDs and virtually all MP3 formats Large jog wheel Cool blue light illuminates CD slot when empty; blue light illuminates around jog wheel when loaded Builtin effects Auto BPM counter Unique resume function automatically picks up where accidentally ejected discs left off Headphone output with dedicated volume control for cueing no mixer required Cue/loop memoryRealtime seamless loop Realtime cue Auto manual cue Pitch bend Size: 8.5w x 315/16h x 111/2d. Wt. 7 lbs. Since the CDJ200 is MP3 compatible aspiring DJs can now include the very latest downloaded tracks in their sets without having to convert the audio from other formats. The MP3 functionality also allows DJs to locate tracks more quickly via folder search and to see the name of the disc artist and song on the units bright dotmatrix display window. This screen also has a bar graph showing the elapsed and remaining playing time of a track plus an Auto BPM Counter giving DJs the realtime information they need to create better mixes more quickly. The unit has a tempo readout as well as a separate Master Tempo button with three settings for locking the pitch of a track as its sped up or slowed down. The unit uses an electricblue light at strategic locations to give the DJ constant feedback about the status of the CD and the effects in use. The light above the CDslot for example shows that theres no disc onboard and also guides the DJ to the userfriendly quickload slot. With the disc inserted that light goes off and a blue illuminated ring appears around the edge of the jog wheel indicating that a CD is loaded and ready for playback. An established highlight of Pioneers Pro DJ CDJ players the jog wheel can be used to speed up or slow down the music; to finetune cue points manually; or to control the mix with the help of another proven feature the digital jog break. This has three effect buttons jet zip wah for creating original sounds as the DJ manipulates the jog wheel. When the digital jog break is on the blue ring flashes quickly. Once the HOLD/RESET button is used the flashing slows down. With the effects off the continuous blue light returns. The CDJ200 also has a unique resume function that takes effect if a CD is ejected accidentally. Once the DJ reinserts the disc it automatically starts playing from exactly the point where it stopped. The unit has a digital out socket so that all of the digital features available in DJ Mode can be carried over to a connected digital environment. The headphone jack with volume control allows the DJ to monitor a CD without connecting the CDJ200 to a mixer or external amplifier. Important Information Regarding Pioneer DealersAuthorized Pioneer Dealers:Pioneer offers a manufacturers limited warranty for products purchased from its authorized dealers. In addition, Pioneer from time to time offers rebates and other special opportunities for products purchased from its authorized dealers. Pioneer does NOT offer a manufacturers limited warranty for products purchased from anyone who is not an authorized dealer and it does NOT offer rebates or other special opportunities for products purchased from anyone who is not an authorized de
Specification Description
Model CDJ200, PCDJ200XX
UPC 012562735092
Audio Connections RCA Analog and Digital Outputs
Compatible Discs CD, CD-R, CD-RW
Compatible File Type CD, MP3
Dimensions 8.5 x 11.5 x 3.85
Display Type Fluorescent
Model CDJ200
Number of Cue Points 1
Number of Decks Single
Pitch Control Yes
Ports Fader Start, Relay Play
Product Weight 7.1
Sampling Yes
Scratching Yes
Series CDJ
Pioneer CDJ-200 Pro CD Player Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: May 10, 2009
Pioneer CDJ-200 Pro CD Player Reviews
Displaying 1 - 4 of 4 Reviews
Show
Sort by
Good basic starter CDJ player
3.0
    Pros
  • Attractive Design
  • Consistent Performance
  • Easy To Set Up
    Cons
  • Difficult To Use
  • Slow To Load
    Best Uses
  • Bedroom
  • Home
"This is a great beginner starter CD player. Some of the good things that I will comment on this CD player is that the features it contains in a small basic player. Although I'm not a big user of effects, this cd player comes with 3 basic effects, and looping capabilities; but among the effects the …"  Read Full Review »
Was this DVD Player & Recorder review on the Pioneer CDJ-200 Pro CD Player helpful to you?
May 10 2009
Patrick
So.Cal
I am:
  • Power User
Great Entry Level CDJ
4.0
    Pros
  • Clear Sound
  • Easy To Use
  • Versatile
    Cons
  • Pricey
    Best Uses
  • Amateurs
  • Bar Djs
  • Home
  • Professionals
"I have used both the CDJ-100/200. The CDJ-200 is pretty much the same unit, but has a few more features if you are thinking of upgrading. The first rad feature is the ability to mix mp3's into your mix. The second is the Loop Function, and lastly it's pitch resolution. Yeah it doesn't scratch, b …"  Read Full Review »
Apr 25 2007
Joe M.
San Francisco, CA
Hope Nothing Goes Wrong
3.0
    Pros
  • Clear Sound
  • Easy To Use
    Cons
  • Breaks Easily
  • Unreliable
    Best Uses
  • Not Recommend Pioneer
"I purchased this unit as a backup, after using it for 2 shows it stopped playing. I sent it in to be repaired under warranty. After getting it back (it is still a backup unit) and using it for 2 shows some months later it quite playing AGAIN and because I have owned for over 1 year pioneer refuses t …"  Read Full Review »
May 29 2007
Bob
Prescott Valley, AZ
lovely cdj but for beginers
4.0
    Pros
  • Clear Sound
  • Easy To Use
  • Professional Functions
  • Versatile
    Cons
  • Bad pith bend
    Best Uses
  • begineers
  • Home
"i dont like the jog dial of cdj 200, its a home studio not for clubs i thing is a lil bit dificulty to beatmacht "
Apr 12 2007
emilio
mexico
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
