based on 60 reviews
Ratings Distribution
| 5 star |
7 |
| 4 star |
11 |
| 3 star |
7 |
| 2 star |
8 |
| 1 star |
27 |
Category Average
Where to Buy
at Amazon.com | ||||
eBay listings for: Pinnacle 8230-10020-71 Pctv Hd Ultimate Stick (Pinnacle 82301002071)
See all eBay results |
at eBay.com | |||
Product Reviews
[2 of 2 customers found this review helpful]
"This stick is a bit heavier than the standard USB stick. I managed to position it where there is no weight on the USB port so no longer an issue. Manufacturer's software is not compatible with Windows WMC so be warned it can mess you up. I get many more chanels not using WMC so won't use it. This device is supposed to also pull in QAM, open digital cable broadcast channels. It is hardware-ready but the drivers a..." Read Full Review »
Feb 17, 2008 by MJN222
"Review: Ease of use: This product is easy to use, you plug it in and it installs itself. It takes several minutes however, and asks you to restart your machine in the middle of the installation. Do not do so. Setting up the channels is easy, and otherwise the software is easy to use. Reception: This product requires excellent reception. At 75% signal quality (according to the device) many artifacts are seen in t..." Read Full Review »
Jan 20, 2008 by HenryTheEighth
Displaying 1 - 5 of 60 Reviews
Pinnacle Systems Pinnacle 8230-10020-71 Pctv Hd Ultimate Stick (Pinnacle 82301002071) Review
"Review:
Reception: This
Read Full Review »
"Let me preface this with I have worked in technical support and software testing for the last five years so I have a pretty good idea of what I was doing.
I live in Iowa and one thing about Iowa is that if you don't have cable or a dish you do not get very good reception, so I thought I'd bit the b
Read Full Review »
This de
Read Full Review »
[1 of 1 customers found this review helpful]
"Bought the product for the Clear Qam capabilities. Did not work. Was told by tech support at Pinnacle that it was a software issue. The tuner is Clear Qam capable but will need a software update. Available sometime in November. Hopefully it will work. (This is the main reason for purchasing this pro …" Read Full Review »
"I had installed this on my XP laptop according to the instructions. The software and drivers are preloaded onto the device, so all you need to do is plug it in. After finally getting it installed and scanned for channels (which it does not automatically do upon first launch), the playback was choppy …" Read Full Review »
Email Address: (required)
Comments:
or Cancel
Where to Buy
at eBay.com | |||
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
