#14
based on 25 reviews
Ratings Distribution
| 5 star |
20 |
| 4 star |
4 |
| 3 star |
1 |
| 2 star |
0 |
| 1 star |
0 |
Category Average
Pros
Cons
Best Uses
Where to Buy
BizRate Rating
Good 8.6
Product Reviews
[2 of 2 customers found this review helpful]
[2 of 3 customers found this review helpful]
"I use the Pila charger to recharge my 18650's, 17670's, 14500's (uses the spacer included with the Pila), and 16340's (needs an extra 15mm spacer, NOT included with the Pila). I check the cells before and after recharging. The Pila occasionally terminates early at 4.05V to 4.15V. It never terminates too late (over 4.20V). I'd consider this behavior to be conservative - which is very good when recharging po..." Read Full Review »
Oct 24, 2008 by 1dash1
See more positive Pila IBC 4-stage Charger, AC Adapter, Carrying Case reviews
"I bought this charger because it was claimed on Candlepowerforums that it does not charge Li-on cells above the critical 4.20V level. However, I have measured >4.2V resting voltage more than once, which defeats the whole purpose of getting this charger versus using one of the inexpensive Ultrafire chargers...." Read Full Review »
Dec 16, 2008 by Flashlight Fanatic
See more negative Pila IBC 4-stage Charger, AC Adapter, Carrying Case reviews
Displaying 1 - 5 of 25 Reviews
Pila IBC 4-stage Charger, AC Adapter, Carrying Case Review
Pros
Cons
Best Uses
Read Full Review »
[0 of 1 customers found this review helpful]
Pros
Cons
Best Uses
"My first "18650" size charging unit purchased for use with my high-performance flashlight. It works as advertised and unlike the cheaper units available online, this charger tops off the cells at a solid 4.20~4.21v (measured with a Fluke 92B scopemeter <- it's accurate). This is a very good thing …" Read Full Review »
Pros
Cons
Best Uses
"I did a whole lot of research before purchasing this charger. It has the correct charging algorithm for charging lithium ions and I feel perfectly safe leaving it unattended. The manual recommends using only PILA batteries, however it will safely charge any lithium ion 18650, or even RCR123 although …" Read Full Review »
Pros
Cons
Best Uses
"I bought this charger because it was claimed on Candlepowerforums that it does not charge Li-on cells above the critical 4.20V level. However, I have measured >4.2V resting voltage more than once, which defeats the whole purpose of getting this charger versus using one of the inexpensive Ultrafire c …" Read Full Review »
Pros
Cons
Best Uses
"I use lithium ion rechargeable cells in higher end flashlights. It is a potentially dangerous chemistry and while I am value oriented, I would not consider using a 'value priced' cheaper charger. It is not worth the risk. This charger is the best in its class and that in itself is value. If you are …" Read Full Review »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
