Photoflex Shoe Mount Multiclamp with Umbrella Holder for Mounting Small Flashes to Light Stands.
#17
4.4
based on 81 reviews
Ratings Distribution
5 star
42
4 star
31
3 star
5
2 star
3
1 star
0
Category Average
4.2
Low Price:
$19.99 at B&H Photo Video
 Trusted:
$19.99 at Adorama
Find it at Amazon
$19.99
from 2 stores
More Images
Pros
  • Durable (42)
  • Attach securely (41)
  • Easy to use (17)
  • Lightweight (16)
  • Long-lasting (12)
  • Versatile (8)
  • Good color value (7)
  • Reliable (5)
  • Consistent output (4)
  • Powerful (4)
See less See more
Cons
  • Flimsy (2)
  • Weak (2)
  • Weak construction (2)
  • Adjustment handle (1)
  • Big (1)
  • Bulky (1)
  • Bulky/heavy (1)
  • Cheap accessory shoe (1)
  • Flash adapter weak (1)
Best Uses
  • General purpose (41)
  • Indoor (25)
  • Outdoors (18)
  • Special events (17)
  • Low light (16)
  • Portraits (13)
  • Fill flash (11)
  • Night time (10)
  • Lighting (8)
  • Photography (6)
Provided by B&H Photo Video
This is a Photoflex versatile bracket that will fit on almost any light stand. It includes two removeable reversible studs to adapt to light stands with top studs smaller than the standard 5/8 inch. It also includes a shoe mount which will accept virtually any shoe-mount flash unit.NOTE: The flash shoe included with this product is only intended for use with flashes that have a knurled locking ring. For flashes that use a lever or other method of locking it is necessary to buy an accessory flash shoe to replace the unit included with the clamp. The Stroboframe accessory shoe catalog #300405 is recommended.
Specification Description
Model AC-BSWCP, ACBSWCP
UPC 799245000868
Weight (Pounds) .7
Photoflex Shoe Mount Multiclamp with Umbrella Holder for Mounting Small Flashes to Light Stands. Questions
Questions and Answers
Where to Buy
$19.99
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$19.99
BizRate Rating Outstanding 9.2
Product Reviews
Last update: Nov 16, 2009
Photoflex Shoe Mount Multiclamp with Umbrella Holder for Mounting Small Flashes to Light Stands. Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
4.0
reasonable price and it works great
"I use this to connect my Speedlite flash adapter, lightstand and shoot-through umbrella together. It works great and is quite flexible. I'm very happy with this little gadget overall. Have used it for softening flash everywhere from photographing people and pets to museum exhibits and making stock photos. I did have some trouble finding this on the Adorama web site, because I didn't know exactly what these..." Read Full Review »
Feb 23, 2009 by Pete
See more positive Photoflex Shoe Mount Multiclamp with Umbrella Holder for Mounting Small Flashes to Light Stands. reviews
2.0
Cheap but it Works!
"This is priced cheap and it is cheap. I don't see it lasting. The hot shoe does not hold my 580EX II stable. You have to crank up the screw and a little movement loosens the crank. I bought one to try it out, now I know. I never used it! I did'nt say Photoflex is bad, just these type of umbrella swivels are. Photoflex makes other great products. For $16 more though, the Manfrotto 026 Swivel Umbrella Adapter is w..." Read Full Review »
Sep 08, 2008 by CR
See more negative Photoflex Shoe Mount Multiclamp with Umbrella Holder for Mounting Small Flashes to Light Stands. reviews
Displaying 1 - 5 of 81 Reviews
Show
Sort by
[2 of 2 customers found this review helpful]
Love it. But DON'T MOUNT A FLASH yet...
4.0
    Pros
  • Durable
  • Lightweight
    Cons
  • None
    Best Uses
  • Fill Flash
  • General Use
  • Night Photography
  • Portraits
"Frankly, I expected these to be broken by now. They certainly seem plasticky and cheap, but I...Just...Can't...Break...Them. That means they are light AND solid. That's nice.
Maybe I am being careful with them, but they keep working and working and working. Got my money's worth, so far.
NO …"  Read Full Review »
Was this Camera Light Accessory review on the Photoflex Shoe Mount Multiclamp with Umbrella Holder for Mounting Small Flashes to Light Stands. helpful to you?
 Report Abuse  (2)  (0)  0 comments
Dec 29 2008
Rick
Charlotte, NC
I am:
  • Semi-Professional
Reviewed at:
Price: $19.99
4.0
    Pros
  • Durable
  • Easy To Use
  • Lightweight
  • Versatile
    Cons
  • None
    Best Uses
  • General Use
  • Photojournalism
  • Portraits
"I use this to connect my Speedlite flash adapter, lightstand and shoot-through umbrella together. It works great and is quite flexible. I'm very happy with this little gadget overall. Have used it for softening flash everywhere from photographing people and pets to museum exhibits and making sto …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Feb 23 2009
Pete
Springfield, MA
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $19.99
Cheap but it Works!
2.0
    Pros
  • Great price
    Cons
  • Flimsy
  • Weak
    Best Uses
  • None
"This is priced cheap and it is cheap. I don't see it lasting. The hot shoe does not hold my 580EX II stable. You have to crank up the screw and a little movement loosens the crank. I bought one to try it out, now I know. I never used it! I did'nt say Photoflex is bad, just these type of umbrella swi …"  Read Full Review »
Sep 8 2008
CR
Las Vegas
I am:
Reviewed at:
Price: $19.99
Almost there
2.0
"This product is almost good, except the screw hole that would hold an umbrella in place has plastic threads and gets stripped. This means you need to use a bungie to actually hold it in place. "
Nov 10 2009
sbsnapper
Santa Barbara, Ca
I am:
  • Photo Enthusiast
Reviewed at:
Price: $19.99
[1 of 1 customers found this review helpful]
Best of Breed, Very Impressed
5.0
    Pros
  • Attach Securely
  • Durable
  • Long-Lasting
    Cons
  • None
    Best Uses
  • General Use
  • Location shooting
"WOW...folks, just buy this and it will restore your faith in sensible, high quality design and manufacture. I haven't gotten this excited about a little accessory product in a long time...usually they are a rip-off that ends up quickly in the bottom drawer for non-performance, or worse.
This is the …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jul 22 2008
K. J. Doyle
Andover, MA
I am:
  • Professional
Reviewed at:
Price: $19.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
