#26
based on 24 reviews
Ratings Distribution
| 5 star |
13 |
| 4 star |
9 |
| 3 star |
2 |
| 2 star |
0 |
| 1 star |
0 |
Category Average
$43.95 - $45.99
from 2 storesPros
Cons
Best Uses
Where to Buy
| No Tax Outside NY ends 09/09/15 |
BizRate Rating
Outstanding 9.7
BizRate Rating
Outstanding 9.1
Product Reviews
[3 of 3 customers found this review helpful]
"I've used this a couple of times and the photo's have looked good. I use it ontop of a stroboframe at outdoor events or one where the roof is very high and dark so I can't use the strobo with a big bounce card. It's worlds better than direct flash with diffuser or omnibounce type diffuser. drawbacks are the universal mount is too expensive but yeah it's superuniversal but a much cheaper generic mount should b..." Read Full Review »
Oct 07, 2008 by Jagdtiger_Jones
"A little tricky to figure out how to put together at first, but if you don't have a lot to spend on light equipment and just want that softbox light look without a lot of equipment to carry, I would recommend this product. I'm very pleased with my purchase...." Read Full Review »
Aug 15, 2008 by Melissa
Displaying 1 - 5 of 24 Reviews
Photoflex LiteDomeQ39 X-Small, 12" x 16" x 9" (30 x 41 x 23cm) Softbox with Basic Connector & Case Review
Pros
Cons
Best Uses
draw
Read Full Review »
Pros
Cons
Best Uses
"the installation is a bit sketchy as it seems like the frame will snap. I haven't taken it apart since I've had it assembled.
It unfolds out to fit into a bag that comes with the package and it is very easy to store.
It's awesome to control light when used off camera. When positioned relativel
Read Full Review »
Pros
Cons
Best Uses
"For small jobs and outside use in portraits, this unit is ideal. Works great. Light weight, portable. Use this instead of a paid assistant ! "
[2 of 2 customers found this review helpful]
Pros
Cons
Best Uses
"I used the LiteDome Q39 for my first outdoor portraits and was very pleased with the soft and even lighting it provided. The dome is lite but sturdy - will buy another soon. "
Pros
Cons
Best Uses
"If you're using Speedlights, this is a great addition. I use it with an SB-800 for outdoor portraits. It produces great soft light. "
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Outstanding 9.7
BizRate Rating
Outstanding 9.1
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
