Phoenix Gold 8" 200-Watt 2-Way In-Wall Speaker
#820
4.3
based on 3 reviews
from $117.22
Ratings Distribution
5 star
1
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.4
$117.22 at pcRUSH
Find it at Amazon
Find it at Ebay
More Images
Pros
  • Great sound quality (3)
  • Easy to connect (1)
  • Easy to install (1)
  • Good value (1)
  • High quality (1)
  • Powerful (1)
See less See more
Cons
  • Grill hard to remove (1)
Best Uses
  • Home theater (1)
Provided by Beach Audio
  • Power handling: 200 watts
  • 8" carbon filled polypropylene cone with butyl rubber surround
  • 1" pivoting ferrofluid cooled tweeter
  • Frequency response: 40Hz-20kHz
  • Paintable frame and grill includes paint shield
  • Cut out: 8 3/4" W x 12 3/4" H
  • Mounting depth: 3 3/8"
  • Specification Description
    Model ATI-8
    UPC 083713067287
    Accessory Indicator Yes
    Additional features 8"
    Benefits Handles up to 200W power1" pivoting ferrofluid-cooled tweeter ensures clear, crisp treblesFrequency response of 40-20000Hz c
    Capacity UOM mAh
    Connectivity technology Wired
    Country Of Origin China
    Description Header Environment enhancement.
    Display Catalog Number 55016471
    Features 8.75Wx12.75" cut out lets you wall-mount the speakers3.31" mounting depth is required
    Frequency response 38Hz-20kHz
    Impedance 8 ohms
    Manufacturer Labor Warranty 5
    Manufacturer Part Number ATI-8
    Manufacturer Parts Warranty 5
    MAP Price 0.0
    Model ATi8
    Operating Temperature UOM ° F
    Power range 15-200 watts
    Product Depth 3.375
    Product Dimensions UOM inches
    Product Height 12.75
    Product Type Home speakers
    Product Weight UOM pounds
    Product Width 8.75
    Sensitivity 90 dB
    Speaker type Ceiling & in-wall
    Speakers included 2
    Supported Languages English
    Tweeter size 0.98 inches
    Tweeter type Pivoting parachute silk dome
    Woofer size 8 inches
    Woofer surround Butyl Rubber
    Woofer type Polypropylene
    Phoenix Gold 8" 200-Watt 2-Way In-Wall Speaker Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Sep 6, 2009
    Phoenix Gold 8" 200-Watt 2-Way In-Wall Speaker Reviews
    Displaying 1 - 3 of 3 Reviews
    Show
    Sort by
    Very good for in the ceiling also.
    4.0
      Pros
    • Crisp Sound
    • Easy To Connect
      Cons
      Best Uses
    • None
    "This is a very good sounding and value priced speaker. My particular use is out of the ordinary as I installed a pair in the ceiling of my garage. I typically spends hours there and enjoy listening to music. Since I have truss type ceilings there is not enought depth for a ceiling specific speaker. …"  Read Full Review »
    Was this Speaker & Subwoofer review on the Phoenix Gold 8" 200-Watt 2-Way In-Wall Speaker helpful to you?
    Sep 6 2009
    cappy
    NJ
    I am:
    • Audiophile
    Reviewed at:
    [1 of 1 customers found this review helpful]
    very capable speakers
    4.0
      Pros
    • Crisp Sound
    • Great Sound Quality
    • Powerful
      Cons
    • None
      Best Uses
    • Home Theater
    "We have four of these hooked up to a Sony 7.1 surround sound receiver used as the rear and side speakers. They work quite well and were relatively easy to install. The quality probably isn't quite good enough if used as front speakers, but definitely capable of producing solid surround sound at a re …"  Read Full Review »
     Report Abuse  (1)  (0)  0 comments
    Jun 13 2009
    clags54
    Bolan, IA
    I am:
    • Practical
    • Tech Savvy
    Reviewed at:
    Great sound at a Great price
    5.0
      Pros
    • Easy Installation
    • Good Value
    • High Quality
      Cons
    • None
      Best Uses
    • None
    "I put these in the wall on either side of my plasma for front sound,they are everything I had hoped they'd be.
    They come with templates to make do it yourself installation a breeze.
    You'll need a sub to compliment them, don't expect them to deliver tons bass. "
    Nov 30 2008
    Sound Nut
    Cornelius NC
    Reviewed at:
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
