Philips SRM7500/37 Prestigo 7-Device Multimedia Infrared Remote
#106
3.7
based on 3 reviews
Ratings Distribution
5 star
2
4 star
0
3 star
0
2 star
0
1 star
1
Category Average
4.2
$179.99 at RadioShack
Find it at Amazon
Find it at Ebay
$179.99
from 1 store
More Images
Pros
  • Easy setup (1)
  • Fast setup (1)
  • Nice features (1)
  • Versatile (1)
See less See more
Cons
  • Big (1)
  • Difficult to program (1)
  • Incompatible (1)
  • Weak signal (1)
Best Uses
  • Complete control (1)
  • Home (1)
  • Upgrade (1)
Provided by RitzCamera.com
Instantly browse your music collection
The SRM7500 acts as a second screen for your multimedia PC. It shows your songs in a convenient layout, sorted by artist, album or genre in the palm of your hand. It gives you freedom to choose your music from almost anywhere in the home.
Navigate your music files without using your TV/monitor
On-screen media selection is the ability to view and select a list of songs, pictures and movies from your PC on the LCD screen of a remote control. The 2-way RF communication incorporated in the remote and the USB dongle provided with it, ensures the content of the PC is transmitted to the remote. So, no need to turn on your TV or monitor to view the menu and select your favorite files.
Operates through walls via radio frequency-based USB adaptor
A USB adaptor is an adaptor that can be connected to your device's USB port to enable control of that device when in a cabinet or in another room. The USB adaptor and the remote have a Radio-Frequency (RF) module incorporated. Over RF, the two communicate with eachother. The commands of the remote will be executed through the USB adaptor, and the content of the MediaCenter PC will be visible on the remote's LCD screen via the USB adaptor.
Specification Description
Model SRM7500/37, SRM750037
UPC 609585113541
Battery Type Product
Benefits Controls up to 6 A/V devices and your PC media centerNavigate your music files without using your monitorRF communication be
Capacity UOM mAh
Chemistry Alkaline
Country Of Origin Taiwan
Description Header Instantly browse your music collection.
Display Catalog Number 55031569
End Product Indicator Yes
Included in the Box Philips© SRM7500 Multimedia Remote ControlUSB transceiver"AAA" batteries (3)
Manufacturer Labor Warranty 12
Manufacturer Part Number SRM7500/37
Manufacturer Parts Warranty 12
MAP Price 0.0
Model SRM7500
Operating Temperature UOM ° F
Power Device "AAA" batteries (3)
Product Type Pushbutton remotes
Rechargeable Yes
Size AA
Supported Languages English
Technology RF
Voltage 1.5
Voltage UOM Volts
Philips SRM7500/37 Prestigo 7-Device Multimedia Infrared Remote Questions
Questions and Answers
Where to Buy
$179.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Jun 28, 2009
Philips SRM7500/37 Prestigo 7-Device Multimedia Infrared Remote Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
very useful
5.0
    Pros
  • Fast Setup
  • Versitile
    Cons
  • Too large
    Best Uses
  • Complete control
  • Home
"I am very happy with this product. I use it for my entire entertainment system, PC, tuner, TV, cable box, DVD player and CD player. Just for the heck of it, I tried the 'learn a function' option to see if it would work for my remote controlled lights and it did. Amazing. "
Was this Remote Control review on the Philips SRM7500/37 Prestigo 7-Device Multimedia Infrared Remote helpful to you?
Feb 5 2009
Dale
New york
I am:
  • Enthusiast
Reviewed at:
[1 of 1 customers found this review helpful]
1.0
    Pros
  • None
    Cons
  • Difficult To Program
  • Incompatible
  • Weak Signal
    Best Uses
  • None
"THIS IS THE WORST PIECE OF NONESENSE THING I HAVE BOTH IN YEARS. FIRST, IT IS SO HARD TO UNDERSTAND YOU CANT PROGRAM IT ONCE YOU FINALLY DO U NEED TO READ A 134 PAGE BOOK TO LEARN HOW TO USE IT. THIS THING IS SO HARD TO CONTROL GOOD LUCK "
 Report Abuse  (1)  (0)  0 comments
Jun 28 2009
BIG THANGS
DOWNEY, CA
I am:
  • Professional
  • Technically Challenged
Reviewed at:
Price: $179.99
quite nice overall
5.0
    Pros
  • Easy To Set Up
  • Nice Features
    Cons
  • None
    Best Uses
  • Upgrade
"works well in general. The range on the PC part isn't terribly far. I ended up putting the USB key on a USB extension and mounting it centrally - works much better. Otherwise, it's a universal remote as any other. "
Aug 7 2008
Bredlen
Brantford, ON. Canada
I am:
  • Gearhead
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
