Philips DVP5990 DVD Player
#121
3.6
based on 80 reviews
from $59.99
Ratings Distribution
5 star
34
4 star
19
3 star
6
2 star
4
1 star
17
Category Average
3.6
Low Price:
$59.99 at Best Buy
$59.99 at J&R Electronics
Find it at Amazon
More Images
Pros
  • Easy setup (11)
  • Easy to use (11)
  • Great picture quality (10)
  • Consistent performance (8)
  • Compact (4)
  • Attractive design (3)
  • Compatibility (1)
  • Usb input (1)
See less See more
Cons
  • Inconsistent (2)
  • Flimsy (1)
  • Slow to load (1)
Best Uses
  • Home (11)
  • Bedroom (4)
  • Dorm room (2)
  • Home theater (2)
  • High volume usage (1)
  • Office (1)
  • Travel (1)
Provided by B&H Photo Video
If you're searching for an affordable, quality DVD video playback solution, look no further. The Philips DVP5990/37 DVD Player features an HDMI output, 720p/1080i/1080p HD upconversion, progressive scan technology, 12-bit/108MHz video processing, DivX Ultra certification, USB Direct, and multi-format DVD/CD playback capabilities. It plays DVD Video, DVD-R/W, DVD+R/W, VCD, SVCD, CD, CD-R/W, and MP3. Enjoy the awesome power of Dolby Digital audio for a wider, more enveloping surround sound experience. This player brings your home theater experience to a whole new level, without breaking the bank. Moreover, it presents superb functionality and high-end features that will be hard to match. It features Windows Media Audio (WMA) compatibility, component video output, coaxial digital audio output, and 192KHz/24-Bit audio processing. With connectivity to multiple A/V components and multi-format playback capabilities, the Philips DVP5990/37 answers the call with superb versatility and reliability.
Specification Description
Model DVP5990/12, DVP5990/37
UPC 609585146617
Disc Capacity 1
Disc compatibility (Play) CD - CDR/W - DVD - DVDR/W
DiVX Play Compatible Yes
DVD Disc Compatibility (Record) DVD Play Only - Does not record
DVD Dual Layer Play Compatible Yes
DVD Dual Layer Record Compatible Does not Record
Power Supply 110 Volts AC
Scanning Modes Progressive Scan
Type of DVD Unit Component DVD Player
Video Standard Up to 480p
Philips DVP5990 DVD Player Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 10, 2009
Philips DVP5990 DVD Player Reviews
Most helpful positive review
[5 of 5 customers found this review helpful]
Most helpful negative review
[1 of 1 customers found this review helpful]
4.0
Second time around is better
"The bad part:A refurbished product should have all bugs worked out. This one didn't. The disc holder would not open right from the start, so I never had a chance to use it.[...] I got a quick replacement player.The best part:Not only does it play so many formats of CD's and provides a beautiful picture on my HDTV, but I am able to easily play slide-shows of my pics from a flash drive by plugging it in to the USB..." Read Full Review »
Apr 04, 2009 by Eighty year old fogie
See more positive Philips DVP5990 DVD Player reviews
1.0
One out of two not working on arrival
"When they work these are great players, allowing the viewing of both DVD's and of material off a USB card. I would be wary about buying these reconditioned units. I already had several others (non-reconditioned) and thought I'd take advantage of this to obtain two more for the last two TV's in my house which don't have a device with USB input.[...] One seems to work but the other was dead on arrival. It will not..." Read Full Review »
Jul 12, 2009 by Ron
See more negative Philips DVP5990 DVD Player reviews
Displaying 1 - 5 of 80 Reviews
Show
Sort by
4.0
    Pros
  • Compact
  • Consistent Performance
  • Easy To Set Up
  • Easy To Use
  • High Quality Picture
    Cons
  • None
    Best Uses
  • Home
"The bad part:A refurbished product should have all bugs worked out. This one didn't. The disc holder would not open right from the start, so I never had a chance to use it.[...] I got a quick replacement player.The best part:Not only does it play so many formats of CD's and provides a beautiful pict …"  Read Full Review »
Was this DVD Player review on the Philips DVP5990 DVD Player helpful to you?
 Report Abuse  (5)  (0)  0 comments
Apr 4 2009
orlando
I am:
  • Casual User
Reviewed at:
Price: $59.99
I've purchased a few of these already!
5.0
    Pros
  • Easy To Set Up
  • Easy To Use
    Cons
  • None
    Best Uses
  • Bedroom
  • Home
"I use it to watch movies/shows. It's a great product! I haven't had any problems with any of the Philips Divx Player I've purchased. I even got a couple as gifts for friends/family. The usb port is a PLUS as you can plug in an external hard drive. This model comes w/a sleeker remote; better than the …"  Read Full Review »
Nov 10 2009
midnight
Los Angeles, CA
I am:
  • Enthusiast
Reviewed at:
Price: $59.99
Worth the Price
4.0
    Pros
  • Compact
  • Easy To Set Up
  • Easy To Use
    Cons
  • None
    Best Uses
  • Bedroom
"This Player is worth for the price I got in J & R.
It plays all my divx videso thru USB with ease.
But get stuck with the dvd's even if they have minor scratches. "
Nov 9 2009
Dilli
Irvine
I am:
  • Enthusiast
Reviewed at:
Price: $59.99
[3 of 3 customers found this review helpful]
Good value for money
4.0
"I just bought this DVD player, and right out of the box it does what it claims to do. It's a simple unit, made for no frills use. The main reason for buying this is to use it with my stereo system (by the TV, also) to play
MP3-coded CD's. Overall, for the price, this was a fair purchase. Here's why: …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Jun 27 2008
Dexter999
Undisclosed
Reviewed at:
Price: $59.99
Best buy!!!!
5.0
"I bought this at Best Buy today. I was there picking up a 500GB WD USB HD for $90 on sale and thought i'd see what they had in the way of DivX players. I had read good things about this one and the 5992 (both have the improved USB 2.0). The 5990 was at Best Buy. So i have a great 500GB Divx/.wmv/.mp …"  Read Full Review »
Jul 7 2008
kalipada
Undisclosed
Reviewed at:
Price: $59.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
