Philips Dect 6.0 Hi Def Cordless Phone w/ Answering Machine, Caller ID, Call Waiting & Speakerphone
#145
3.9
based on 24 reviews
from $109.88 - $179.99
Ratings Distribution
5 star
9
4 star
10
3 star
0
2 star
4
1 star
1
Category Average
3.8
Low Price:
$109.88 at Walmart
 Trusted:
$124.30 at pcRUSH
Find it at Amazon
More Images
Pros
  • Nice sound (11)
  • Compact design (8)
  • Easy setup (8)
  • Big range (7)
  • Nice features (6)
  • Strong signal (6)
  • Easy to use (5)
  • Comfortable handset (4)
  • Quality construction (3)
  • Great sound quality (2)
See less See more
Cons
  • Plastic construction (2)
  • Difficult to set up (1)
  • Hard to set up (1)
  • Lacks features (1)
  • Message light always on (1)
  • Message light stays on (1)
  • Uninuitive user interface (1)
Best Uses
  • Everyday (9)
  • Outdoors (2)
  • Replacement (2)
  • Great look (1)
  • Upgrade (1)
Provided by Overstock.com
Philips ID9371B Enhanced High Def Voice Digital cordless phone answering machine . Offers up to 100 greater battery life and ultra private calls which are virtually interference free. Advanced acoustic chamber offers unsurpassed call clarity. Exclusive crafted design has a stunning high resolution color display. Enhanced speakerphone for hands free conversations and a SIM-card copying facility for information transfer from your mobile phonebook to your home phone in a matter of seconds. Phone has a unique soft-touch feel, 3 embedded games and an alarm clock.
Features
  • Description: PHILIPS ID 937 Enhanced High DefVoice Single Handset Cordless Phone with Answering Machine
  • Enhanced High DefVoice Speaker Phone
  • Virtually Interference Free
  • Advanced Acoustic Chamber for Unsurpassed Call Clarity
  • SIM Card Copying Facility/ Up to 100 Percent Greater Battery Life
  • Unique soft touch feel
Specification Description
Model ID9371B, ID9371B/37
UPC 609585127869
color Black
Display Screen CSTN LCD - Backlight - White
Phone Lines 1
size null
sku 71524
skuprice 179.9900
style ID9371B/37
taxable Y
Philips Dect 6.0 Hi Def Cordless Phone w/ Answering Machine, Caller ID, Call Waiting & Speakerphone Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Mar 17, 2009
Philips Dect 6.0 Hi Def Cordless Phone w/ Answering Machine, Caller ID, Call Waiting & Speakerphone Reviews
Most helpful positive review
Most helpful negative review
[3 of 3 customers found this review helpful]
5.0
Design + no wireless netwrk interference
"Great design AND this new frequency range eliminates interference from your home wireless network. I had Vonage and thought Vonage was this issue - it wasn..." Read Full Review »
Jun 27, 2007 by Keizers
See more positive Philips Dect 6.0 Hi Def Cordless Phone w/ Answering Machine, Caller ID, Call Waiting & Speakerphone reviews
2.0
Looks and Sounds Great but horrible UI
"Unfortunately, I think I am going to return my iD phone. I am really disappointed because I love the way this phone looks, feels, and sounds. But the user interface is awful. Try putting a call on hold and transferring to another handset. It doesn't work the way every phone has worked for the last 20 years. Put handset on hold, pick up other handset and select "talk." Instead you have to hold down the "con..." Read Full Review »
Aug 29, 2007 by shadowbox
See more negative Philips Dect 6.0 Hi Def Cordless Phone w/ Answering Machine, Caller ID, Call Waiting & Speakerphone reviews
Displaying 1 - 5 of 24 Reviews
Show
Sort by
2.0
    Pros
  • Big Range
  • Comfortable Handset
  • Easy To Set Up
  • Good Sound
  • Looks great
  • More »
    Cons
    Best Uses
  • None
"Unfortunately, I think I am going to return my iD phone. I am really disappointed because I love the way this phone looks, feels, and sounds. But the user interface is awful. Try putting a call on hold and transferring to another handset. It doesn't work the way every phone has worked for the la …"  Read Full Review »
Was this Cordless Telephone review on the Philips Dect 6.0 Hi Def Cordless Phone w/ Answering Machine, Caller ID, Call Waiting & Speakerphone helpful to you?
 Report Abuse  (3)  (0)  0 comments
Aug 29 2007
shadowbox
New York
I am:
  • Quality Oriented
Reviewed at:
5.0
    Pros
  • Easy To Set Up
  • Easy To Use
  • Quality Construction
    Cons
  • None
    Best Uses
  • None
"Great design AND this new frequency range eliminates interference from your home wireless network. I had Vonage and thought Vonage was this issue - it wasn "
Stands flat on the desk
  • Picture of Product
Jun 27 2007
Keizers
Minneapolis
I am:
  • Tech Savvy
Reviewed at:
[2 of 2 customers found this review helpful]
Big Disappointment
2.0
    Pros
  • Compact design
  • Good Sound
    Cons
  • Lacks Features
    Best Uses
  • Everyday Use
"This phone is sleek in design and has good sound quality. What is driving us crazy is the red blinking light whenever there is a "new episode" (which is any call coming in to your line). If ANY call is made to your line, whether you answer it or not or whether they hang up or not, the red light bl …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Jan 5 2008
RG
Fairfax, VA
I am:
  • Quality Oriented
Reviewed at:
Looks great AND works well
5.0
    Pros
  • Big Range
  • Compact design
  • Easy To Set Up
  • Good Sound
  • More »
    Cons
  • None
    Best Uses
  • Everyday Use
  • Outdoors
"I've had this phone for about 2 weeks and I'm very impressed with the quality. The sound on it is great. Even the speaker phone doesn't have that cheap "tinny" sound that most portable phones have. I love that fact that it holds up to 250 telephone numbers. My old phone only held 50 and that got …"  Read Full Review »
Sep 13 2007
Diana
Long Island, NY
I am:
  • Quality Oriented
  • Value Oriented
Reviewed at:
[1 of 1 customers found this review helpful]
Nice phone but a bit pricey
4.0
    Pros
  • Easy To Use
    Cons
  • Message Light always on
    Best Uses
  • Great looks
"Had some issues getting the add on phones set up because I thought I had changed the security code, but really had not. The directions for setting the code were not clear so I did not realize I had to enter the factory code (0000) first. One very annoying feature is that the call /answer Machine lig …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jul 12 2007
Dano the mano
NJ
I am:
  • Gearhead
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
