Philips 8-in-1 Remote Control (Model #PMDVR8)
#125
4.0
based on 2 reviews
Ratings Distribution
5 star
1
4 star
0
3 star
1
2 star
0
1 star
0
Category Average
4.2
Low Price:
$20.49 at Universal Remotes Direct
 Trusted:
$34.23 at pcRUSH
Find it at Amazon
$20.49 - $34.23
from 3 stores
More Images
Pros
  • Nice features (2)
  • Durable (1)
  • Easy setup (1)
  • Easy to program (1)
  • Ergonomic design (1)
  • Nice button configuration (1)
See less See more
Cons
  • Incompatible (1)
Best Uses
  • Replacement (1)
  • Upgrade (1)
Provided by Universal Remotes Direct
For some, a remote control is a task in itself, but how does one handle 8 of them? Philips has the simple solution in their 8-Device Universal Remote Control. Combining all your television and audio devices together, this universal remote provides the ultimate experience in home theater management. An advanced learning function and extensive code library will make you forget about your remote control confusion in no time!
Features:
  • Controls 8 devices: TV, DVD, DVR, VCR, satellite, cable box, CD player and audio
  • Compatible with most major device brands and models
  • Includes all original TIVO® remote keys
  • Learning remote feature learns the functions of your existing remotes
  • Advanced DVD, DVR, audio and satellite functions
  • Extensive code library
  • Code search function helps find the right codes for your devices
  • Permanent memory retention
  • Closed captioning
  • Sleep timer
  • Battery saver function
  • Requires 2 AAA batteries
  • Dimensions: 11" H x 4" W x 1.75" D
Specification Description
Model PM-DVR8, PMDVR8, US2-PMDVR8, pmdvr8
UPC 026616617180
Benefits Convenient backlighting makes it easy to program and use your remote even in dark roomsDedicated DVR keys are included on this remote
Capacity UOM mAh
Country Of Origin Taiwan
Description Header Take control of the situation.
Display Catalog Number 55031580
Enclosure Color Silver
End Product Indicator Yes
Included in the Box Philips® 8-in-1 remote controlUser's guide
Manufacturer Labor Warranty 90
Manufacturer Part Number US2-PMDVR8
Manufacturer Parts Warranty 90
MAP Price 0.0
Model US2-PMDVR8
Operating Temperature UOM ° F
Power Device "AAA" batteries (2)
Product Type Pushbutton remotes
Required to function "AAA" batteries (2)
Required to function SKU 2300877
Supported Languages English
Technology IR
Philips 8-in-1 Remote Control (Model #PMDVR8) Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 26, 2009
Philips 8-in-1 Remote Control (Model #PMDVR8) Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
[2 of 2 customers found this review helpful]
This remote is my hero...
5.0
    Pros
  • Durable
  • Easy To Program
  • Easy To Set Up
  • Ergonomic Design
  • Nice Button Configuration
  • More »
    Cons
  • None
    Best Uses
  • Replacement
  • Upgrade
"I purchased this remote primarily as a replacement for my original television remote. I was frustrated by the cost of buying from the company that made my television but I couldn't find a remote that would support the video and PIP functions of my set.
On a whim, I checked out the Radio Shack sit …"  Read Full Review »
Was this Remote Control review on the Philips 8-in-1 Remote Control (Model #PMDVR8) helpful to you?
 Report Abuse  (2)  (0)  0 comments
Oct 26 2009
lolligirl
KY
I am:
  • Tech Savvy
Not compatible
3.0
    Pros
  • Nice Features
    Cons
  • Incompatible
    Best Uses
  • None
"Not compatible with Comcast "
Jan 11 2009
Roy
Cranbury NJ
I am:
  • Tech Savvy
Reviewed at:
Price: $20.49
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
