Pentax K2000 Digital SLR Camera with 18-55mm Lens & AF200FG Flash
#107
4.3
based on 14 reviews
from $541.60 - $569.99
Ratings Distribution
5 star
6
4 star
7
3 star
0
2 star
1
1 star
0
Category Average
4.7
Low Price:
$541.60 at Meijer.com
 Trusted:
$569.99 at Best Buy
Find it at Amazon
More Images
Pros
  • Easy to use (11)
  • Bright lcd (8)
  • Comfortable controls (8)
  • Great image quality (8)
  • Fast shutter speed (7)
  • Image stabilization (6)
  • Consistent output (3)
  • Durable (3)
  • Fast recycling (3)
  • Versatile (3)
See less See more
Cons
  • Cable release (1)
  • Exposed lcd (1)
  • Heavy / bulky (1)
  • Poor in low light (1)
  • Slow focus (1)
Best Uses
  • Fun (7)
  • Landscapes (7)
  • Portraits (5)
  • Travel (5)
  • Art (3)
  • General purpose (3)
  • Sports (3)
  • Photojournalism (2)
  • Fill flash (1)
  • Night photography (1)
Provided by RitzCamera.com
10.2 effective megapixels
10.2 megapixel CCD sensor offers superior image resolution with maximum control over noise.
Ultra-compact, lightweight design
One of the smallest and lightest available designs makes the K2000 perfect for spontaneity. Easy one-handed operation with a comfortable carrying weight makes transitioning from a point and shoot trouble-free.
PENTAX Auto Picture
Expect the right exposures with the settings you want. Auto Picture mode automatically calculates photographic factors to pick the best picture mode, optimizing the camera settings for any situation.
Scene modes
Ten intuitive Scene modes offer point-and-shoot ease by further optimizing the camera for common situations and subjects.
2.7 inch LCD monitor
A 2.7 inch high-resolution, wide-view LCD monitor beautifully displays your pictures, and provides intuitive, easy-to-read menus.
PENTAX-developed body-based Shake Reduction
With body-based Shake Reduction, the PENTAX SLR system will stabilize your shots, providing maximum flexibility with no compromise in optical quality. It increases your handheld shooting shutter speed range by 2.5 to 4 stops for blur-free pictures, and is compatible with every PENTAX lens ever produced.
Help Button
Leave the manual at home. The dedicated and reprogrammable Help Button on the K2000 is like having a built-in user's guide. It clearly explains camera settings to ease the transition from compact photography to DSLR mastery.
Dust Alert function
Dust Reduction and Dust Alert features eliminate the need for time-consuming retouching by minimizing dust and determining if and where any dust remains after the system is activated.
Pentax Real IMage Engine (PRIME)
PRIME image processing engine maximizes image properties and allows custom adjustment of image parameters, such as truer color tones, a wider dynamic range, and natural-looking high ISO images.
Full backward lens compatibility
PENTAX has manufactured over 25 million lenses in the last six decades; all DSLR bodies offer backward compatibility with every one.* Whichever lens is used, whether a most recent lens or a classic screwmount, it will faithfully capture the image desired.*With adapter for screwmount and 645/67 lenses.
Custom IMage modes
Custom IMage modes, with six preset options, offer superior control of how the PRIME processor develops images, and can be further modified to meet your needs. Get beautifully processed images in any shooting condition.
AA battery compatibility
Approximately 1,650 images can be taken when using AA size lithium batteries due to their energy-saving design. (Four Energizer lithium batteries are included with each camera.) Plus, AA power can be found anywhere in the world.
Specification Description
Model 17314, K2000, K2000LENSFLASH
UPC 027075147553
back light compensation Yes
Battery Type Product
Benefits 10.2 megapixel CCD sensor offers superior image resolution with maximum control over noise10 intuitive Scene modes offer point-and-sh
Cables Included USB cable
Camera Flash Built-in
Camera Flash Features Ext - hot shoe (P-TTL, high-speed sync avail), wireless w/ PENTAX dedicated flash; Synch spd 1/180
Camera/Camcorder Color Support Yes
Capacity 3000
Capacity UOM mAh
Chemistry Lithium
Connections USB 2.0 (1)Video out - NTSC, PAL (1)PictBridge (1)
Continuous Burst or Capture ModeĀ  Yes
Continuous Shooting Speed 3.5fps
Controls / Adjustments Wide-angle viewable
Country Of Origin Philippines
date/time insert Yes
Description Header Take a step up.
Display Catalog Number 55032723
Display Form Factor Built-in
Display Languages 19 languages
Display Size 2.7 inches
Effective Sensor Resolution 10200000 Pixels
Enclosure Color Black
End Product Indicator Yes
Exposure Compensation +/- 2 EV (1/2 or 1/3 steps)
Exposure Metering TTL open aperture, 16 segment metering;
Exposure Modes 16 segments; Center weighted
Features PENTAX DA 18-55mm F3.5-5.6 AL II has the ideal standard zoom focal range for a wide range of shotsImproved resolution takes full adva
Flash Modes On, off, redeye, wireless; flash exposure compensation
Focal Length 18-55mm
Focal Length Equivalent to 35mm Camera 27.5-82.5mm
Focus Adjustment Fully Automatic
High-speed shutter Yes
Image Storage 10M (3872x2592), 6M (3008x2000), 2M (1824x1216)
Included in the Box K2000 bodyDA-L 18-55 LensAF200FG FlashStrap O-ST84Eyecup FQBody Mount Cover4 "AA" Energi
JPEG, JPG Yes
Lens Aperture F3.5-5.6
Lens System Features Quick-shift focus, Filter window, SP (Super Protect) coating
Lens System Type PENTAX DA 18-55mm F3.5-5.6 AL II
Light Sensitivity Auto - 100-3200 ISO (1, 1/2, 1/3 steps), up to 1600 ISO in Bulb mode; Manual - 100-3200 ISO (1, 1/2, 1/3 steps), up to 1600 ISO in Bulb mode
MAC Operating System Support MacOS® X 10.3 or later
Manufacturer Labor Warranty 12
Manufacturer Part Number K2000
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Operating Temperature 104 Fahrenheit
Max Resolution 230000
Max Shutter Speed 30 seconds
Megapixel Range 8+MP
Min Operating Temperature 32 Fahrenheit
Model K2000
NightShot Yes
Operating Temperature UOM ° F
Optical Sensor Type Interline interlace CCD with primary color filter
PC Operating System Support Windows XP/Vista
PictBridge-enabled Yes
Power Device "AA" lithium batteries
Product Depth 2.7
Product Dimensions UOM inches
Product Height 3.6
Product Type Digital SLR
Product Weight 21
Product Weight UOM ounces
Product Width 4.8
Rechargeable Yes
Red Eye Reduction Yes
Required to function Windows: Windows XP/Vista, USB port Mac: MacOS-X 10.3 or later, USB 2.0 port
Resolution 10.75 Megapixels
Self Timer Yes
Self Timer Delay 12 Seconds
Shooting Programs Auto Picture (Portrait, Night Portrait, Landscape, Macro, Action), Picture (Portrait, Landscape, Macro, Action, Night Scene Portrait, Standard Flash O
Size AA
Software PENTAX Photo Lab 3, PENTAX Photo Browser
Special Effects High Contrast, Soft (3), Starburst, Retro, Color Extract, Illustration (Pastel, Watercolor), HDR (3), B&W, Sepia, Color (18), Slim (+/- 8), Brightness
Still Image Format RAW PEF/DNG, JPG (EXIF 2.21), DCF 2.0 (design rule for camera file system), DPOF, Prt Img Mtchng III
Supported Flash Memory SD/SDHC
Supported Languages English
Total Pixels 10750000 Pixels
Type Type - 2.7" TFT color LCD monitor, adjustable brightness
Viewfinder Type Penta-Mirror
Voltage 1.5
Voltage UOM Volts
White Balance Presets Auto preset modes - Auto, Daylight, Shade, Cloudy, Fluorescent (D, N, W), Tungsten, Flash; Manual mode; WB fine adjustment available
Zoom Adjustment 11 elements in 8 groups
Pentax K2000 Digital SLR Camera with 18-55mm Lens & AF200FG Flash Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 19, 2009
Pentax K2000 Digital SLR Camera with 18-55mm Lens & AF200FG Flash Reviews
Most helpful positive review
[6 of 6 customers found this review helpful]
Most helpful negative review
[0 of 1 customers found this review helpful]
4.0
My first digital SLR and I love it!!
"Overall I an very pleased with this camera. My first SLR was a Pentax K1000. My next was a used KSX with a Sears label. I have been wanting a digital SLR for years but the cost was prohibitive for me. I read several positive reviews and discovered that the K200D and K2000 used any Pentax lenses, I was sold.I was amazed at the quality of the pictures compared to my old point & shoot digital. The camera is well b..." Read Full Review »
Mar 27, 2009 by Vernon
See more positive Pentax K2000 Digital SLR Camera with 18-55mm Lens & AF200FG Flash reviews
2.0
Poor Picture
"Too [*] big and heavy, no better then my Canon 650,interchangeable with the K1000 lens system, maybe, but not mine.Too [*] complicated, I have over 25 SLR's and more then 15 digital point and shooters, none are as hard to use as this thing, this will be used as a door stop...." Read Full Review »
Apr 16, 2009 by Magman
See more negative Pentax K2000 Digital SLR Camera with 18-55mm Lens & AF200FG Flash reviews
Displaying 1 - 5 of 14 Reviews
Show
Sort by
[5 of 5 customers found this review helpful]
4.0
    Pros
  • Bright LCD
  • Comfortable Controls
  • Great Image Quality
    Cons
  • Poor In Low Light
  • Slow Focus
    Best Uses
  • Fun
  • Landscape
"Overall I an very pleased with this camera. My first SLR was a Pentax K1000. My next was a used KSX with a Sears label. I have been wanting a digital SLR for years but the cost was prohibitive for me. I read several positive reviews and discovered that the K200D and K2000 used any Pentax lenses, I …"  Read Full Review »
One of the pictures mentioned in the review.
  • Made with Product
  • Using Product
  • Made with Product
Was this Digital SLR Camera review on the Pentax K2000 Digital SLR Camera with 18-55mm Lens & AF200FG Flash helpful to you?
 Report Abuse  (5)  (0)  0 comments
Mar 27 2009
Vernon
Maryland
I am:
  • Casual Photographer
Reviewed at:
[1 of 1 customers found this review helpful]
I love this camera!!
4.0
    Pros
  • Bright LCD
  • Easy To Use
  • Fast Shutter Speed
  • Great first time DSLR
  • More »
    Cons
  • None
    Best Uses
  • Art
  • Fun
  • Landscape
  • Portraits
"I am a first time DSLR user and I'm in love. This camera is so easy to use and the pictures are so clear. I was ready for the step up and this was the perfect camera to do that on. "
One of the girls.
One of the girls.
  • Using Product
Love me.
Love me.
  • Using Product
 Report Abuse  (1)  (0)  0 comments
Mar 31 2009
Miss Alissa
Berwyn, NE
I am:
  • Photo Enthusiast
Reviewed at:
Love this camera
4.0
    Pros
  • Bright LCD
  • Easy To Use
  • Great camera for price
  • More »
    Cons
  • None
    Best Uses
  • Fun
  • Landscape
  • Sports
  • Travel
"I have always had Pentax film cameras and have been watching for a Pentax digital at my level of use and a great price. This was the perfect find for me. "
My favorite subject
My favorite subject
Aug 5 2009
Old Pentax Man
Lansing, MI
I am:
  • Photo Enthusiast
Reviewed at:
Price: $541.60
I'm very please with this purchase
5.0
    Pros
  • Consistent Output
  • Durable
  • Easy To Use
  • Fast Recycling
  • Powerful Output
  • More »
    Cons
  • None
    Best Uses
  • General Use
  • Night Photography
  • Photojournalism
  • Portraits
"I've been shooting with Pentax SLRs for about 30 years now. When I decided to make the jump to digital SLR and did some research, this camera outfit is the one that most suited my needs. The price was almost unbelievable and I was very pleased knowing that I would still be able to use some of my o …"  Read Full Review »
Jun 6 2009
Libbie on the Lable
McMinnville, TN
I am:
  • Semi-Professional
Reviewed at:
[3 of 3 customers found this review helpful]
Iwould recomend this product to my frien
5.0
    Pros
  • Bright LCD
  • Easy To Use
  • More »
    Cons
  • Cable release
    Best Uses
  • Art
  • Fun
  • Landscape
  • Portraits
  • Travel
"I was amazed at the number of features this Camera has.I have always been a Pentax fan ,and all of my existing Lenses work fine with this camera. It is a true SLR camera,so I can continue to take impressive photographs using my depth of field and time Exposures.
It is lightweight ,comfortable in my …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Mar 29 2009
Capt'n Ken
Minnetonka Minnesota
I am:
  • Photo Enthusiast
Reviewed at:
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
