Pentax D-BG2 Battery Grip for K20D & K10D Digital SLR Cameras
#13
4.7
based on 49 reviews
Ratings Distribution
5 star
39
4 star
7
3 star
3
2 star
0
1 star
0
Category Average
4.3
$5.99 - $195.99
from 8 stores
More Images
Pros
  • Reliable (29)
  • Long-lasting (21)
  • Easy to install (20)
  • Good value (12)
  • Solid construction (12)
  • Lightweight (9)
  • Versatile (9)
  • Fast recharge (6)
  • Charges quickly (5)
  • Durable (3)
See less See more
Cons
  • Bulky (2)
  • Adds weight when attached (1)
  • Battery status awkward (1)
  • Can't recharge directly (1)
  • Poor design (1)
  • Too bulky (1)
Best Uses
  • Travel (17)
  • Digital photography (15)
  • Professional cameras (11)
  • Back-up (10)
  • Portraits (9)
  • Photography (7)
  • Upgrade (4)
  • Mobility (2)
  • Power equipment (2)
  • Battery pack (1)
Provided by B&H Photo Video
The Pentax D-BG2 Battery Grip offers additional power to ensure maximum shooting performance for the K10D & K20D cameras while it's in continuous use. The grip atttaches a second high-capacity D-Li50 Li-Ion battery (sold separately) to the camera and features as well an additional shutter release an adjusting dial for selecting aperture or shutter speed and other functional controls - making it particularly practical when shooting vertically. The ergonomic design of the grip ensures that the camera fits firmly and comfortably in the hand and is weatherproof - like the K10D & K20D cameras themselves. Furthermore the battery compartment provides storage space for an extra memory card and a remote control.
Specification Description
Model 39557, 9557, BG-2, D-BG2 Battery Grip
UPC 027075123632
color null
Compatible Battery D-LI50
Compatible With Pentax
Select Power Accessories
size null
sku 153395
skuprice 195.0000
style 39557
taxable Y
Pentax D-BG2 Battery Grip for K20D & K10D Digital SLR Cameras Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 9, 2009
Pentax D-BG2 Battery Grip for K20D & K10D Digital SLR Cameras Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
5.0
Perfect accessory for Pentax digitals
"It lives on the camera. I never shoot without it. The battery draw also has storage for one extra SD card. It's perfect for using the camera in the portrait orientation because the second shutter release and controls are right there. It's possible to half press the second shutter release when handling the camera or chimping, however this is not a problem when shooting. The second power on/preview switch is ..." Read Full Review »
Jul 29, 2008 by Chris
See more positive Pentax D-BG2 Battery Grip for K20D & K10D Digital SLR Cameras reviews
3.0
Large palms and the case for memory card
"Indeed, I count on more. Could use a standard battery, which works together with the inside chamber. Because I have "no female" palms, it is very convenient. Join him once, I do not remove more of it:). Very convenient that inside there is room for memory cards and remote control. For vertical shooting - very narrow in scope...." Read Full Review »
Aug 22, 2008 by Pharmaman
See more negative Pentax D-BG2 Battery Grip for K20D & K10D Digital SLR Cameras reviews
Displaying 1 - 5 of 49 Reviews
Show
Sort by
5.0
    Pros
  • Good Value
  • Lightweight
  • Long-Lasting
  • Reliable
  • Versatile
    Cons
  • None
    Best Uses
  • Intensive shooting
  • Professional Cameras
  • Travel
It's possible to half press the second shutter release when …"  Read Full Review »
Was this Standard Camera Battery review on the Pentax D-BG2 Battery Grip for K20D & K10D Digital SLR Cameras helpful to you?
 Report Abuse  (3)  (0)  0 comments
Jul 29 2008
Chris
Bribie Island, Qld., Australia
I am:
  • Professional
Reviewed at:
Price: $129.95
I finally have the grip
4.0
    Pros
  • Easy to Install
  • Long-Lasting
  • Solid Construction
    Cons
  • None
    Best Uses
  • Back Up
"It was everything I thought it would be. My only complaint is that my hand touches the auto focus button on the battery grip. Not a huge problem. It startles me from time to time when my hand brushes against the button. "
Nov 9 2009
Joel
Kailua, HI
I am:
  • Photo Enthusiast
Reviewed at:
Price: $129.95
Perfect Built for the K20D
5.0
    Pros
  • Easy to Install
  • Reliable
    Cons
    Best Uses
  • Back Up
  • Portrait Photography
"I couple the BG2 with my k20D because I want a grip that can provide a shutter-release button for portrait shooting. This is not an after-market grip, this is the real McCoy by Pentax that fits the K20D perfectly!
The pull-out tray can accept an extra battery which can be served as a second batter …"  Read Full Review »
May 13 2009
WinkieM3
Boston, MA
I am:
  • Semi-pro Photographer
Reviewed at:
best bang for your buck!
5.0
    Pros
  • Easy to Install
  • Fast Recharge
  • Long-Lasting
  • Reliable
    Cons
  • Bulky
    Best Uses
  • Digital Photography
  • Travel
"I don't know how I went this long without a battery grip, this thing gives you so many more options in vertical mode.I now take as many pictures in portrait as I do in landscape.also, the grip holds my infra red remote and an extra memory card. I also have 2 very heavy lenses,pentax da*50-135 and a …"  Read Full Review »
Jul 28 2009
neal
philadelphia
I am:
  • Photo Enthusiast
Reviewed at:
Price: $129.95
Yes Please
5.0
    Pros
  • Handy
    Cons
  • Bulky
    Best Uses
  • Photography
"Before I even had a lens picked out, this was the first thing I bought after the camera (k10d) and I won't take it off my camera. It adds that right amount of weight to the camera to make it easier to hold steady and the extra length to make my large hands feel comfortable all day along with the por …"  Read Full Review »
Jun 29 2009
Chad
Grand Rapids
I am:
Reviewed at:
Price: $126.36
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
