Pentax 16-45mm Zoom Lens for Digital Cameras
#291
4.6
based on 32 reviews
Ratings Distribution
5 star
20
4 star
11
3 star
0
2 star
1
1 star
0
Category Average
4.5
Low Price:
$334.95 at Abes of Maine
 Trusted:
$439.95 at B&H Photo Video
Find it at Amazon
$334.95 - $1,099.95
from 16 stores
More Images
Pros
  • Fast / accurate auto-focus (19)
  • Consistent output (15)
  • Well built / quality construction (13)
  • Lightweight (12)
  • Easily interchangeable (11)
  • Durable (10)
  • Rugged (9)
  • Easily mounted (6)
  • Clear glass (5)
  • Easy to clean (5)
See less See more
Cons
  • Heavy / bulky (4)
  • Slow focus (2)
  • Big honking lens shade (1)
  • Blurry focus (1)
  • Expensive (worth it) (1)
  • Extends far at wide end (1)
  • Lens cap difficult to use (1)
  • Not as sharp at 45mm (1)
  • Onboard flash blocked (1)
  • Pricey (1)
Best Uses
  • General purpose (19)
  • Landscapes (9)
  • Photojournalism (7)
  • Travel (7)
  • Upgrade (6)
  • Documentary (5)
  • Portraits (5)
  • Art (3)
  • Fun (3)
  • Night photography (3)
Provided by CameraWorld.com
The perfect companion lens for the *ist D digital SLR.
The compact, high-performance, interchangeable SMC Pentax DA 16mm-45mm f/4 ED AL lens features a three-times zoom ratio with focal lengths covering ultra-wide to moderate-telephoto ranges for the angle of view equivalent to 24.5mm-69mm in the 35mm format.
The DA-Series Lens lens features a responsive Quick-Shift Focus System that allows photographers to instantly switch the focus mode from auto to manual with a slight twist of the focus ring. Coupled with a simple, functional design and the elimination of an aperture ring, this new mechanism considerably improves the camera's operability. The lens also incorporates an Extra-low Dispersion (ED) glass lens element and two aspherical lens elements for true-to-life image reproduction and overall size reduction. The image circle in DA-series lenses, including the SMC Pentax DA 16mm-45mm f/4 ED AL, is designed to perfectly match the 23.5mm x 15.7mm size of the CCD used in Pentax digital SLRs, optimizing camera performance.
The new design also contributes to a drastic reduction in size, weight and production cost, compared to 35mm-format counterparts with similar specifications.
Specification Description
Model 21507
UPC 027075079762
Attachment Diameter 67mm
Fits Camera Made By Pentax
Lens or Filter Type Zoom Lens
Lens Type Zoom
Magnification 0.26x
Select Digital Specific Lenses
Select Lens Style Standard Zooms
Select Mount Pentax
Pentax 16-45mm Zoom Lens for Digital Cameras Questions
Questions and Answers
Where to Buy
$439.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$334.95
$465.99
Code SEARS5OFF50 : $5 Off Orders Over $50!
Show all 16 stores
Product Reviews
Last update: Jul 6, 2009
Pentax 16-45mm Zoom Lens for Digital Cameras Reviews
Most helpful positive review
Most helpful negative review
[3 of 8 customers found this review helpful]
4.0
Forget the kit lens, get this one
"I waited a long time before buying this lens -- took a lot of photos with the kit lens that left me wanting... Don't make the mistake of waiting as this lens does a much better job. I jumped when I saw a couple of posts on the Pentax Forum that hinted that this lens might be discontinued.This lens makes my K20D images even more impressive. I particularly like the F4 across the entire zoom range. Lens lives on ..." Read Full Review »
Apr 27, 2009 by rickn
See more positive Pentax 16-45mm Zoom Lens for Digital Cameras reviews
2.0
Not sharp, Loud, Not-Pro Quality
"If you're looking for a professional quality lens, this is not it-spring for the 16-50mm f2.8 ED AL (IF) instead- the difference is night and day. For one this lens is not sharp, secondly it is very slow and very loud. You're wasting a really good sensor on your camera by using a sub-standard lens. For the price, it's a good enough lens, but don't think that it's as sharp as their more expensive lenses...." Read Full Review »
Jul 24, 2008 by drew
See more negative Pentax 16-45mm Zoom Lens for Digital Cameras reviews
Displaying 1 - 5 of 32 Reviews
Show
Sort by
4.0
    Pros
  • Consistent Output
  • Lightweight
  • Sharp Focus
    Cons
  • None
    Best Uses
  • General Use
  • Landscape Photography
  • Night Photography
  • Upgrade
"I waited a long time before buying this lens -- took a lot of photos with the kit lens that left me wanting... Don't make the mistake of waiting as this lens does a much better job. I jumped when I saw a couple of posts on the Pentax Forum that hinted that this lens might be discontinued.This lens …"  Read Full Review »
Taken with DA 16-45 lens
Was this Camera Lens review on the Pentax 16-45mm Zoom Lens for Digital Cameras helpful to you?
Apr 27 2009
rickn
Mechanicsburg, PA
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $334.95
Top affordable stand. zoom in any system
5.0
    Pros
  • Consistent Output
  • Durable
  • Easy To Clean
  • Rugged
  • Sharp Focus
  • More »
    Cons
  • Heavy
    Best Uses
  • General Use
"This lens has a few issues (compromises, actually), but this lens is the very reason I, after a long (2 years!) search, chose the Pentax system (I own a K200D). It was a rational choice for me, not a passionate one. I chose the system based on lens choice. This is not only a lens review, is a statem …"  Read Full Review »
Jun 11 2008
Gustavo Santos
Rio de Janeiro, Brazil
I am:
[5 of 5 customers found this review helpful]
Really Nice Lens
5.0
    Pros
  • Clear Glass
  • Easily Accessible Controls
  • Easily Mounted
  • Lightweight
  • Strong Construction
  • More »
    Cons
  • None
    Best Uses
  • Documentary
  • Fun
  • Great all around lens
  • Photojournalism
  • Travel
"Great lens with a moderately large F4.0 aperture throughout its full zoom range. Optically very sharp for a zoom lens. I would be a little happier if it had a little longer focal length on the long side,such as 60 or 70MM, but the Pentax 50-200mm zoom takes care of that. The very wide end of 16mm i …"  Read Full Review »
 Report Abuse  (5)  (0)  0 comments
Feb 5 2007
Art
Woodlawn, TN
Reviewed at:
Price: $599.95
[4 of 4 customers found this review helpful]
Imprssive zoom, great range
5.0
    Pros
  • consant aperture
  • Easily Mounted
    Cons
    Best Uses
  • Documentary
  • Photojournalism
  • Travel
"I purchased this lens some time ago, along with the *st D. It's shown to have very little distortion for a zoom, and the AF is actually fast and useful for an AF lens.
The feature I like best is the ability to "fine tune" the focus after AF without having to switch to MF. It's fast and accurate …"  Read Full Review »
 Report Abuse  (4)  (0)  0 comments
Feb 28 2007
Dana G
Worcester, Massachusetts
I am:
  • Professional
Reviewed at:
Price: $599.95
Pentax 16-45mm - a real nice surprise!!!
5.0
    Pros
  • Consistent Output
  • Durable
  • Easily Interchangeable
  • Lightweight
  • Sharp Focus
  • More »
    Cons
  • Slow Focus
    Best Uses
  • None
"I sold all of my Nikon gear (D200, some pretty good lenses) and switched to Pentax. The 16-45mm hooked to a K20D makes a phenominal combination for landscape photography. Sharpness, good color and low noise are the result, along with more sales. I can't be negative about Nikon - it's very nice eq …"  Read Full Review »
Aug 6 2008
Bob
Central Virginia
I am:
  • Semi-Professional
Reviewed at:
Price: $599.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
