Pentax 10.2MP Compact Digital SLR Camera with 2.7" LCD, 15-55mm and 20-200mm Zoom Len
#143
4.1
based on 11 reviews
Ratings Distribution
5 star
4
4 star
6
3 star
0
2 star
0
1 star
1
Category Average
4.7
Low Price:
$519.99 at Best Buy
 Trusted:
$529.95 at Adorama
Find it at Amazon
$519.99 - $638.99
from 13 stores
More Images
Pros
  • Easy to use (10)
  • Bright lcd (8)
  • Fast shutter speed (8)
  • Comfortable controls (7)
  • Image stabilization (7)
  • Well built / quality construction (7)
  • Great picture quality (6)
  • Good battery life (1)
  • Good sized screen (1)
  • High resolution (1)
See less See more
Cons
  • Heavy (2)
  • Poor in low light (2)
  • Ac adaptor style (1)
  • Exposed lcd (1)
  • No dof preview (1)
  • Nose print on the monitor (1)
  • Slow focus (1)
  • Small viewfinder (1)
Best Uses
  • Fun (9)
  • Landscapes (9)
  • Travel (9)
  • Portraits (8)
  • Sports (5)
  • Photojournalism (4)
  • Art (2)
  • Everyday (1)
  • Outdoors (1)
  • Sports/action (1)
Provided by RitzCamera.com
10.2 effective megapixels
10.2 megapixel CCD sensor offers superior image resolution with maximum control over noise.
Ultra-compact, lightweight design
One of the smallest and lightest available designs makes the K2000 perfect for spontaneity. Easy one-handed operation with a comfortable carrying weight makes transitioning from a point and shoot trouble-free.
PENTAX Auto Picture
Expect the right exposures with the settings you want. Auto Picture mode automatically calculates photographic factors to pick the best picture mode, optimizing the camera settings for any situation.
Scene modes
Ten intuitive Scene modes offer point-and-shoot ease by further optimizing the camera for common situations and subjects.
2.7 inch LCD monitor
A 2.7 inch high-resolution, wide-view LCD monitor beautifully displays your pictures, and provides intuitive, easy-to-read menus.
PENTAX-developed body-based Shake Reduction
With body-based Shake Reduction, the PENTAX SLR system will stabilize your shots, providing maximum flexibility with no compromise in optical quality. It increases your handheld shooting shutter speed range by 2.5 to 4 stops for blur-free pictures, and is compatible with every PENTAX lens ever produced.
Help Button
Leave the manual at home. The dedicated and reprogrammable Help Button on the K2000 is like having a built-in user's guide. It clearly explains camera settings to ease the transition from compact photography to DSLR mastery.
Dust Alert function
Dust Reduction and Dust Alert features eliminate the need for time-consuming retouching by minimizing dust and determining if and where any dust remains after the system is activated.
Pentax Real IMage Engine (PRIME)
PRIME image processing engine maximizes image properties and allows custom adjustment of image parameters, such as truer color tones, a wider dynamic range, and natural-looking high ISO images.
Full backward lens compatibility
PENTAX has manufactured over 25 million lenses in the last six decades; all DSLR bodies offer backward compatibility with every one.* Whichever lens is used, whether a most recent lens or a classic screwmount, it will faithfully capture the image desired.*With adapter for screwmount and 645/67 lenses.
Custom IMage modes
Custom IMage modes, with six preset options, offer superior control of how the PRIME processor develops images, and can be further modified to meet your needs. Get beautifully processed images in any shooting condition.
AA battery compatibility
Approximately 1,650 images can be taken when using AA size lithium batteries due to their energy-saving design. (Four Energizer lithium batteries are included with each camera.) Plus, AA power can be found anywhere in the world.
Specification Description
Model 17313, K2000 KIT, PTXK20002LENS
UPC 027075147546
*Megapixels 10.2
Anti Shake Mode Yes
color null
Compatible with Macintosh Yes
Compatible with Windows PC Yes
Electronic Flash Built-in
LCD Viewer 2.7 Inch
Lens Zoom Lens
Manufacturer’s Warranty - Hardware 1 Year
Optical Viewfinder Yes
Optical Zoom 3x
PictBridge Compatible
Pixel Count 10 Megapixel
Select Camera Style Interchangeable Lens SLR's
Self Timer Yes
size null
sku 155019
skuprice 649.9500
Still Picture Capture Yes
Storage Media Type Secure Digital (SD)
style 17313
taxable Y
Pentax 10.2MP Compact Digital SLR Camera with 2.7" LCD, 15-55mm and 20-200mm Zoom Len Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 31, 2009
Pentax 10.2MP Compact Digital SLR Camera with 2.7" LCD, 15-55mm and 20-200mm Zoom Len Reviews
Most helpful positive review
Most helpful negative review
[0 of 1 customers found this review helpful]
5.0
Great handling
"Small, lightweight entry level D-SLR. Great for starting out with an SLR or as reliable and capable great handling lightweight second camera for anyone else. Really outstanding for the price...." Read Full Review »
Oct 06, 2009 by Silent Thunder
See more positive Pentax 10.2MP Compact Digital SLR Camera with 2.7" LCD, 15-55mm and 20-200mm Zoom Len reviews
1.0
Dont spend your money on this junk
"This outfit is way over priced for what you get. The zoom lens are slow and very poor in low light Pentax service and support is very poor there is no warranty cards with there products now and you can't register your stuff on there web site it took me over one month to get a lens hood for the 18-55mm lens and the AA batterys are a big joke I used the camera for sports photos continous hi shoting eats batterys I..." Read Full Review »
Oct 31, 2009 by Chuck the photo guy
See more negative Pentax 10.2MP Compact Digital SLR Camera with 2.7" LCD, 15-55mm and 20-200mm Zoom Len reviews
Displaying 1 - 5 of 11 Reviews
Show
Sort by
Great handling
5.0
Great Customer Photo
    Pros
  • Comfortable Controls
  • Easy To Use
  • Fast Shutter Speed
  • Great Image Quality
  • Image Stabilization
  • More »
    Cons
  • None
    Best Uses
  • Art
  • Fun
  • Landscape
  • Photojournalism
  • Portraits
  • More »
"Small, lightweight entry level D-SLR. Great for starting out with an SLR or as reliable and capable great handling lightweight second camera for anyone else. Really outstanding for the price. "
Was this Digital SLR Camera review on the Pentax 10.2MP Compact Digital SLR Camera with 2.7" LCD, 15-55mm and 20-200mm Zoom Len helpful to you?
Oct 6 2009
Silent Thunder
Albuquerque, NM
I am:
  • Semi-pro Photographer
Reviewed at:
1.0
    Pros
  • None
    Cons
  • Poor In Low Light
    Best Uses
  • Landscape
  • Photojournalism
  • Portraits
  • Sports
  • Travel
"This outfit is way over priced for what you get. The zoom lens are slow and very poor in low light Pentax service and support is very poor there is no warranty cards with there products now and you can't register your stuff on there web site it took me over one month to get a lens hood for the 18-55 …"  Read Full Review »
 Report Abuse  (0)  (1)  0 comments
Oct 31 2009
Chuck the photo guy
Portage,IN
I am:
Reviewed at:
Price: $529.95
[3 of 4 customers found this review helpful]
loved it
4.0
    Pros
  • Bright LCD
  • Easy To Use
  • More »
    Cons
  • Ac adaptor style
    Best Uses
  • Fun
  • Landscape
  • Portraits
  • Travel
"I went on a family camping trip and was changing the lenses all the time to get great W/angle and macro shots and landscapes to long telephotos and portraits. Took some getting used to, it had been so long since I last used an SLR with interchangeable lenses.
The "night scene" setting was great f …"  Read Full Review »
 Report Abuse  (3)  (1)  0 comments
May 28 2009
Mark the camper
Memphis TN
I am:
  • Casual Photographer
[5 of 5 customers found this review helpful]
I've come back to Pentax!
4.0
    Pros
  • Bright LCD
  • Easy To Use
  • More »
    Cons
  • No DOF Preview
  • Small viewfinder
    Best Uses
  • Art
  • Fun
  • Landscape
  • Photojournalism
  • Portraits
  • More »
"For the past few years I've been using a super-zoom type camera with manual shooting capabilities. When I decided to go back to a real SLR, I did a lot of research and finally decided to go with the manufacturer of my very first SLR back in the 80s - Pentax. The K2000 does not disappoint - except fo …"  Read Full Review »
 Report Abuse  (5)  (0)  0 comments
Jun 24 2009
madeditor
Sarasota, FL
I am:
  • Photo Enthusiast
Reviewed at:
Price: $529.95
Very Pleased
5.0
    Pros
  • Bright LCD
  • Easy To Use
  • More »
    Cons
  • None
    Best Uses
  • Fun
  • Landscape
  • Photojournalism
  • Portraits
  • Sports
  • More »
"I very much so like this camera, it is excellent in making the transition from a "point and shoot" to a SLR camera. I am still gaining a full understanding of all the available adjustments, while still being able to use it quickly as a "point and shoot". My wife was fusing about my decision at first …"  Read Full Review »
Jun 23 2009
Fun with Photos
Boonville, N.C.
I am:
  • Photo Enthusiast
Reviewed at:
Price: $539.95
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
