Peerless SP850 Large Flat Panel Pull-Out Wall Mount with Adapter Plate
#174
5.0
based on 4 reviews
from $259.99
Ratings Distribution
5 star
4
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.4
Low Price:
$259.99 at CSN Stores
 Trusted:
$259.99 at Mounts and More
Find it at Amazon
Pros
  • Adjustable (3)
  • Easy to install (3)
  • Multiple viewing angles (3)
  • Sturdy (3)
  • Interfaces well with tv (2)
See less See more
Cons
  • Pricey (1)
Best Uses
  • Bedroom (1)
  • Home (1)
  • Tvliving room (1)
Provided by CSN Stores
The SP850 Pull-out Swivel mount is designed to work with virtually any 26" to 50" Plasma or LCD flat panel display. Compatible with VESA® 100 and 200 hole patterns through the integrated adapter plate, the 2" ultra-thin design keeps the screen close to the wall and the mount out of view.
With a boxed in wall plate that eliminates the view of the mount hardware from a side view, the SP850 is the perfect installation product for residential, public and digital signage, POS stations and office applications. Additional compatibility with Peerless’ PLP or LC adapter plates makes the mount a versatile product.
Features:
  • For screen sizes 26" to 50" (150 lbs max)
  • Some screens may require PLP adapter plate (included): please check cross-reference for compatibility
  • Easy pull-out swivel provides quick maintenance access
  • Built in adapter plate supports VESA 100 and 200 compatibility
  • Works with Peerless dedicated and universal PLP and LC adapter plates
  • Ideal for wall mount applications and attachment to false backsplashes
  • 2.25" deep when closed, swivel arms extend to 10.5"
  • When extended, screen can swivel up to 45° left and right depending on screen size
  • Mounts on 16" studs
  • Clean profile design hides wiring and mount within enclosed wall plate
  • Includes security screws for attachment at the screen(SP 850 and SP 850-S only)
  • Includes security lock out screw to eliminate pull out ability
SP850 Pull-Out LCD/Plasma Mount Installation Instructions
SP850 Pull-Out LCD/Plasma Mount Technical Data
Need professional installation? Use the or the ! Give us a call with any questions!
Peerless SP850 Large Flat Panel Pull-Out Wall Mount with Adapter Plate Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jun 6, 2008
Peerless SP850 Large Flat Panel Pull-Out Wall Mount with Adapter Plate Reviews
Displaying 1 - 4 of 4 Reviews
Show
Sort by
Great product
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Multiple Viewing Angles
  • Sturdy
    Cons
  • None
    Best Uses
  • TVLiving room
"I have a 50" Pioneer so the mount needed to be something more study then a traditional arm based mount.
Suggestion: when trying to figure out where you are going to position the mounting bracket on the wall, the directions do not remind you to add 1". This is from the mounting adapter plate conn …"  Read Full Review »
Was this TV Wall Mount review on the Peerless SP850 Large Flat Panel Pull-Out Wall Mount with Adapter Plate helpful to you?
Mar 10 2008
Pete
Grand Rapids, Michigan
I am:
  • Gearhead
  • Tech Savvy
Reviewed at:
Price: $259.99
Great product choices, great prices
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Interfaces Well With TV
  • Sturdy
    Cons
  • None
    Best Uses
  • Bedroom
  • Home
"The site was comprehensive. They had every conceivable mount. Electronics stores have about 2 or 3 different models for any given size of television - and their prices are high.
Mounts and more had hundreds of choices with prices that were a fraction of those in the stores. "
Jun 6 2008
cardiackf
Weston, FL
I am:
  • Gearhead
  • Practical
  • Professional
  • Tech Savvy
Reviewed at:
Price: $259.99
Worth the Money
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • Expensive
    Best Uses
  • None
"The install went smoothly and surprisingly quick. Very happy with the product. "
Sep 7 2007
Gary
Cambria, CA
I am:
  • Gearhead
Reviewed at:
Price: $259.99
Excellent
5.0
"Excellent service and price. Saved major dollars by using this company. Did allot of resarch prior to purchase. Would recommend them to anyone who needs mounts. Mount was easy to install and works just fine. "
Oct 26 2006
Mr. S. Wilson
Hendersonville, NC
Reviewed at:
Price: $259.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
