Peerless SmartMount Universal Tilt Mount 61"- 102" Screens
#53
5.0
based on 4 reviews
from $110.00 - $168.00
Ratings Distribution
5 star
4
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.4
More Images
Pros
  • Easy to install (3)
  • Interfaces well with tv (3)
  • Sturdy (3)
  • Adjustable (2)
  • Can support weight (2)
See less See more
Cons
  • Difficult to adjust (1)
Best Uses
  • Family/living room (2)
  • Home (1)
  • Office (1)
Provided by CSN Stores
Verstile functionality and solid engineering make the ST680 tilting plasma mount an intelligent choice for you boardroom, restaurant/bar, or home theater. Everything you need for a quick and easy installation is included: flat panels engage with an audible click to simple-to-align universal brackets. Fifteen degrees of forward tilt give unobstructed access to cables and an open-design wall plate allows easy access to junction boxes and cable management. This tilt mount is compatible with most 61" to 102" flat panels and holds the screen just over 3" from the wall.
NOTE: This mount is NOT compatible with every 61" to 102" display. If you have questions about your specific TV, please call us.
Features:
  • Fits plasma screens with mounting hole patterns up to 43.96" W and 29.31" H
  • Adjustable +/- 15 degrees tilt
  • Self-balancing, one-touch tilt for effortless adjustment
  • Tilt lock of 15/10/5/0/-5 degrees
  • Horizontal screen adjustment up to 12"
  • Easy-glide bracket design ensures screen is securely attached to wall plate
  • Mounts to two or three wood studs, concrete, cinder block, or metal studs (ACC 415 accessory required)
  • Comes with Peerless Sorted-For-You fastener pack with all necessary screen attachment hardware
  • Security screws require special wrench for removal (included); phillips-head screws can be removed with any standard screwdriver
  • UL listed
  • Available in black or silver
  • Adjustable Mounting Pattern: 29.31" H x 44" W
  • Distance from wall: 3"
  • Weight capacity: 350 lbs
ST680 Tilting Plasma Mount Installation Instructions
ST680 Tilting Plasma Mount Metal Stud Installation Instructions
ST680 Tilting Plasma Mount Technical Data
Need professional installation? Use the or the ! Give us a call with any questions!
Peerless SmartMount Universal Tilt Mount 61"- 102" Screens Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 22, 2009
Peerless SmartMount Universal Tilt Mount 61"- 102" Screens Reviews
Displaying 1 - 4 of 4 Reviews
Show
Sort by
Great Mount, Very Easy!
5.0
    Pros
  • Easy To Install
  • Interfaces Well With TV
  • Sturdy
    Cons
  • Difficult To Adjust
    Best Uses
  • Family/Living Room
  • Home
"I have this mount in the living room , Used 3 wood studs to hang it, all the hardware was there. It is on a Sharp 65"LCD, All my connection's are behind the TV. It is better to have all IN and OUT connector's above the mount, You will have more room to adjust later.
Takes 2 Guy's to lift it on the …"  Read Full Review »
Was this TV Wall Mount review on the Peerless SmartMount Universal Tilt Mount 61"- 102" Screens helpful to you?
Feb 23 2009
OPA
Kensington CA
I am:
  • Casual User
Reviewed at:
Price: $110.00
[1 of 1 customers found this review helpful]
Nice mount, no problems
5.0
"The mount went up quickly and easily and does exactly what it should. The Peerless mount is obviously high quality, so I would strongly recommend it or any other sizes to anyone looking to wall-mount a flat panel. "
 Report Abuse  (1)  (0)  0 comments
Nov 16 2006
Chris
Yorktown, VA
Reviewed at:
Price: $110.00
I would buy this product again.
5.0
    Pros
  • Can Support Weight
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • None
    Best Uses
  • Office
"All worked as advertised. "
Apr 18 2009
cesmo
Rochester, NY
I am:
  • Power User
Reviewed at:
Price: $110.00
Excellant...
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • None
    Best Uses
"Excellant product. "
Aug 22 2009
Raj
Brentwood, TN
I am:
  • Casual User
Reviewed at:
Price: $110.00
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
