Peerless SmartMount Tilt Wall Mount for 13"- 37" LCD Screens
#112
3.9
based on 13 reviews
Ratings Distribution
5 star
4
4 star
6
3 star
2
2 star
0
1 star
1
Category Average
3.9
$28.99 - $59.99
from 16 stores
More Images
Pros
  • Easy to install (4)
  • Interfaces well with tv (4)
  • Sturdy (4)
  • Adjustable (3)
  • Multiple viewing angles (2)
  • Easy assembly (1)
  • Easy to move (1)
  • Fast setup (1)
  • Simple controls (1)
See less See more
Cons
  • Difficult to adjust (1)
  • Flimsy (1)
Best Uses
  • Home (6)
  • Bedroom (4)
  • Office (2)
  • Classroom (1)
  • Convenience (1)
  • Movies (1)
  • Professional (1)
Provided by Television Wall Mounts.com
The SmartMount Universal Tilt Wall Mount for 13" - 37" screens offers 5 degrees upward and 15 degrees downward tilt. Tilt adjustment is very smooth and can be done easily with no tools required, or the tilt can be tensioned to restrict movement of the screen. It ships with a VESA 75mm/100mm and an additional plate for larger screens using 100mm x 200mm and 200mm x 200mm mounting patterns. It has a weight load capacity of 115 lbs on a single wood stud or concrete and uses one pre-installed fastener point for safety/security. Metal stud mounting requires an accessory metal stud wall fastener pack (ACC215).
Best of all, this mount is guaranteed to be in stock. Any orders placed before 1:00pm EST will ship out SAME DAY!
NOTE: This mount is NOT compatible with every 13" to 37" display. If you have questions about your specific TV, please call us.
Features:
  • Durable all-steel construction
  • Comprehensive fastener pack included
  • Available in black or silver
  • Adjustable tilt +15/-5 degrees
  • Hook-on design for ease of installation
  • Available with VESA 75mm/100mm and additional plate for larger screens using 100mm x 200mm and 200mm x 200mm mounting patterns
  • Discreet, integrated security features standard
  • Security screws require special wrench for removal (included); phillips-head screws can be removed with any standard screwdriver
  • UL listed
  • With option of Phillip's head or security screws
  • Distance from wall: 1.66"
  • Weight Capacity: 115 lbs
  • Dimensions: 6.2" H x 5.15" W
Installation Instructions for ST632 LCD Mount
Metal Stud Installation Instructions for ST632 LCD Mount
Technical Data for ST632 LCD Mount
Need professional installation? Use the or the ! Give us a call with any questions!
Specification Description
Model PEEST632P, PEEST632PS, ST-632, ST632
UPC 735029237242
Accessory Indicator Yes
Benefits Fits most 10-37" LCD TVs and monitors; weight capacity up to 115 lbs.Screen adapter plate compatible with VESA 75/100/200 x 100/200 x
Benefits VESA® 75, 100, 200x100, and 200x200 compatibleProvides 1-touch tilt for effortless adjustment without the use of toolsCo
Capacity UOM mAh
Country Of Origin United States
Description Header A great viewing experience is a tilt away.
Description Header Enjoy the view.
Display Catalog Number 55017546
Display Catalog Number 55017547
Enclosure Color Silver
Features Desired tilt angle can be locked in place if neededScreen tilts +15°/-5°
Features Hook-on design for ease of installation; comprehensive fastener pack includedUL listed
Included in the Box SmartMount Universal Tilt Wall Mount Includes:1 x Hook bracket1 x Tilt assembly1 x Adapter plate2 x Alliga
Included in the Box Tilting wall plateVESA 75/100 adapter plateAdditional 200x100/200x200 adapter plateMounting hardware
Manufacturer Labor Warranty 5
Manufacturer Part Number ST632P
Manufacturer Part Number ST632P-S
Manufacturer Parts Warranty 5
MAP Price 0.0
Model ST632P
Model ST632P-S
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Disclaimer Warranty is 5 years limited.
Product Height 5.2
Product Type Wall mounts
Product Weight 3.98
Product Weight UOM pounds
Product Width 5.15
Supported Languages English
Peerless SmartMount Tilt Wall Mount for 13"- 37" LCD Screens Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: May 7, 2009
Peerless SmartMount Tilt Wall Mount for 13"- 37" LCD Screens Reviews
Most helpful positive review
[0 of 1 customers found this review helpful]
Most helpful negative review
4.0
Flat wall mount
"I use this to mount my TV in my bedroom. it is small yet strong. Drill two holes and screw in two bolts. Four screws on the back of the TV and hang it. 20min. Turn it on and enjoy. I have priced other mounts and if you don't need a swing arm this is all you need. Ray..." Read Full Review »
May 07, 2009 by Ray
See more positive Peerless SmartMount Tilt Wall Mount for 13"- 37" LCD Screens reviews
1.0
"23-49"" is not ...
"23-49" is not realistic. I ordered this mount for my 32" LCD and I would not even consider trying to mount with this mount. It is way to small. This would be a decent mount for a 13-23" LCD but not a single inch bigger. Be very careful when placing orders for these mounts, they all seem to make unrealistic claims as to the size and weight you can hang on them...." Read Full Review »
Sep 21, 2006 by david n
See more negative Peerless SmartMount Tilt Wall Mount for 13"- 37" LCD Screens reviews
Displaying 1 - 5 of 13 Reviews
Show
Sort by
Flat wall mount
4.0
    Pros
  • Fast Setup
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Movies
  • Office
  • Professional
Ray "
Was this TV Accessory review on the Peerless SmartMount Tilt Wall Mount for 13"- 37" LCD Screens helpful to you?
 Report Abuse  (0)  (1)  0 comments
May 7 2009
Ray
Lewisville, TX
I am:
  • Casual User
Reviewed at:
Price: $28.99
Cheap, Easy and Strong
5.0
"If you can read and follow simple instructions, then this mount is the one for you. My wife and I put it up with in 30 minutes. We used two Phillips screw divers, 3/8 drill socket and a level. I could hang myself (180lbs) from the mount it is so strong. We have an old house with strong wood walls an …"  Read Full Review »
Nov 18 2008
Laurel,MS
Good Buy!
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Interfaces Well With TV
  • Multiple Viewing Angles
    Cons
  • Flimsy
    Best Uses
  • Bedroom
  • Home
"For the Money this purchase is great. Simple to install and fits a wide range of tv sizes. This mount fits closly to the wall ideal for your living room or bed room. "
Feb 21 2008
tk1
Small Town, KY
I am:
  • Practical
  • Professional
  • Technically Challenged
Reviewed at:
Price: $28.99
Simple, elegant, inexpensive-great combo
4.0
    Pros
  • Easy To Install
  • Sturdy
    Cons
  • Difficult To Adjust
    Best Uses
  • Home
"A 13/16" socket on an extension fits the adjustment knob perfectly so the viewing angle can be adjusted on the wall. Eliminates the major drawback. "
Jan 24 2008
DWS
Van Nuys, CA
I am:
  • Gearhead
  • Professional
Reviewed at:
Price: $28.99
Great price!
4.0
    Pros
  • Sturdy
    Cons
  • None
    Best Uses
  • Bedroom
"Do not recommend for any flat screen smaller than
23",due to the adapter plate required to accomodate the smaller tvs partially covers the terminal inputs. "
Aug 9 2007
Ric
Los Angeles Ca
Reviewed at:
Price: $28.99
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
