Peerless PT632 Paramount Universal Tilting TV Mount
#20
5.0
based on 7 reviews
from $20.99 - $34.99
Ratings Distribution
5 star
7
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.4
Low Price:
$20.99 at Mounts and More
$29.99 at CSN Stores
Find it at Amazon
More Images
Pros
  • Easy to install (7)
  • Adjustable (6)
  • Sturdy (6)
  • Interfaces well with tv (5)
  • Can support weight (3)
  • Multiple viewing angles (3)
  • Small but very sturdy (1)
See less See more
Best Uses
  • Bedroom (7)
  • Home (4)
  • Office (3)
  • Changing viewing angle (2)
  • Classroom (2)
  • Den (1)
  • Kitchen (1)
Provided by Mounts and More
This sleek, compact tilt wall mount delivers a big impact for small – mid-size screens. Its simple three step installation combined with its adjustable tilt angle enable flat panel screens to be installed and adjusted quickly. This mount delivers big results.
Features:
  • Fits screens with VESA® 75, 100, 200x100, or 200x200 mm hole patterns
  • Adjustable 15° forward and -5° backward tilt for finding the optimal viewing angle
  • Tilt angle locks into place with simple tightening of screws
  • Screen held only 2.25” from wall, perfect for a low profile application
  • Mounts to wood studs, concrete, cinder block or metal studs (metal stud accessory required)
  • UL Listed
  • 115 lbs weight capacity
  • High Gloss Black
PT632 Installation Instructions
PT632 Specifications
Need professional installation? Use the or the ! Give us a call with any questions!
Specification Description
Model PT632
# of Mount Studs 1
Assembly Required Yes
Brand Peerless
Depth From Wall 2.25 inches
Dimensions 8.75L x 2.25W x 9.35H inches
Placement Wall
Tilt/Roll Adjustment 15 Degrees Forward
TV Screen Size 10
Type Code Tilting Mounts
VESA Compliant Yes
Warranty 5 Year Limited Warranty
Weight Capacity 115 lbs.
Peerless PT632 Paramount Universal Tilting TV Mount Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 3, 2009
Peerless PT632 Paramount Universal Tilting TV Mount Reviews
Displaying 1 - 5 of 7 Reviews
Show
Sort by
Easy to install and works great!
5.0
    Pros
  • Can Support Weight
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • None
    Best Uses
  • Bedroom
"Excellent Product. Simple sturdy design that has a good finish and was quite easy to install. I read other reviews prior to purchasing the wall mount. It mounts the TV close to the wall and the price was right. I have no complaints at all with the Paramount Universal Tilting LCD Wall Mount (10" …"  Read Full Review »
Was this TV Wall Mount review on the Peerless PT632 Paramount Universal Tilting TV Mount helpful to you?
Aug 2 2009
TP
PA
I am:
  • Enthusiast
Reviewed at:
Price: $20.99
Terrific Product
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Interfaces Well With TV
  • Multiple Viewing Angles
  • More »
    Cons
  • none
    Best Uses
  • Bedroom
  • Den
  • Home
  • Kitchen
"I recently installed this product with a 26 inch Flat Panel Toshiba with a built in DVD player.
It was a snap and no difficulty with installation what so ever.
Very sturdy and easy to follow installation instuctions.
All necessary hardware was included.
Mounts close to the wall. "
Oct 7 2008
Ray
Madison, NJ
I am:
  • Enthusiast
Reviewed at:
Price: $20.99
Great mount for the price
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • None
    Best Uses
  • Bedroom
  • Classroom
  • Home
  • Office
"I used this mount in my bedroom for a simple clean mounting of my new LCD at the foot of my bed. It works great. "
Jan 11 2009
Mark
Hartsville, SC
I am:
  • Casual User
Reviewed at:
Price: $20.99
excellent quality product
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • None
    Best Uses
  • Bedroom
  • Changing Viewing Angle
  • Classroom
  • Home
  • Office
"Used to mount TV in bedroom. Easy installation, easy adjustment, fit tv perfectly. "
Apr 18 2009
Dave
Mechanicsburg, PA
I am:
  • Casual User
Reviewed at:
Price: $20.99
For the price this unit works great for
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • None
    Best Uses
  • Bedroom
"For the bedroom it works great. "
Nov 3 2009
JPR
Prairie City Or.
I am:
  • Casual User
Reviewed at:
Price: $20.99
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
