Peerless PM47W Adjustable DVD/VCR Standard Brackets TV Wall Mount
#42
4.6
based on 14 reviews
Ratings Distribution
5 star
11
4 star
1
3 star
2
2 star
0
1 star
0
Category Average
4.4
$15.71 - $49.00
from 8 stores
More Images
Pros
  • Easy to install (7)
  • Interfaces well with tv (7)
  • Adjustable (6)
  • Sturdy (6)
  • Multiple viewing angles (4)
  • Easy assembly (2)
  • Smooth edges (2)
  • Supports weight (2)
  • Attractive design (1)
  • Can support weight (1)
See less See more
Cons
  • Difficult to adjust (1)
Best Uses
  • Bedroom (6)
  • Home (4)
  • Office (3)
  • Changing viewing angle (2)
  • Classroom (2)
  • Space saver (2)
  • Convenience (1)
  • Kitchen (1)
Provided by Beach Audio
VCR attachment, adjustable in both height and width, these mounts accommodate most front-loading VCRs, VCPs, and DVD players. The security version uses tamper resistant adjustment screws, which lock the equipment in place. Kit includes all hardware for easy attachment to Peerless TV mounts. Units are stackable. The VCR Mount shall be a Peerless model PM47 and shall be attached to a Peerless TV Mount. It shall include all fasteners for attachment to the TV wall mount. It shall be constructed of 16 gage cold rolled steel. It shall feature adjustable height and width in a design that surrounds and clamps the VCR. The finish shall be scratch resistant Black, Silver or White Fused Epoxy. It shall be UL Listed and CSA Certified. Assembly and installation shall be done according to instructions provided by the manufacturer.
Specification Description
Model PEEPM47, PM 47, PM47, PM47W
UPC 735029202479
Capacity UOM mAh
Country Of Origin Mexico
Display Catalog Number 55031707
Manufacturer Part Number PM47W
MAP Price 0.0
Model PM47W
Operating Temperature UOM ° F
Product Type Wall mounts
Supported Languages English
Peerless PM47W Adjustable DVD/VCR Standard Brackets TV Wall Mount Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 28, 2009
Peerless PM47W Adjustable DVD/VCR Standard Brackets TV Wall Mount Reviews
Most helpful positive review
Most helpful negative review
5.0
Great product - perfect!!!!
"I had been looking for something to mount our cable box to the tv mount already in place without having to buy an entire new tv mount. This was PERFECT! Very easy to install. Works great!..." Read Full Review »
Apr 17, 2009 by Natalie
See more positive Peerless PM47W Adjustable DVD/VCR Standard Brackets TV Wall Mount reviews
3.0
head of maintenance
"for a good installation it takes 2 people to get the frame tight against the vcr. the old one with the adjusting screws was very easy to set up with only one person. i personnaly prefer the old style to the new...." Read Full Review »
May 23, 2007 by rick
See more negative Peerless PM47W Adjustable DVD/VCR Standard Brackets TV Wall Mount reviews
Displaying 1 - 5 of 14 Reviews
Show
Sort by
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Interfaces Well With TV
    Cons
  • None
    Best Uses
  • Bedroom
"I had been looking for something to mount our cable box to the tv mount already in place without having to buy an entire new tv mount. This was PERFECT! Very easy to install. Works great! "
Was this TV Wall Mount review on the Peerless PM47W Adjustable DVD/VCR Standard Brackets TV Wall Mount helpful to you?
Apr 17 2009
Natalie
Palm Harbor, FL
I am:
  • Casual User
Reviewed at:
Price: $17.00
Just what I was looking for!
4.0
    Pros
  • Attractive Design
  • Easy To Assemble
  • Holds All Components
  • Smooth Edges
  • Supports Weight
    Cons
  • None
    Best Uses
  • Space Saver
"I used this mount to save space. I was able to get my HD FIOS receiver off of kitchen counter and hang below the upper cabinets. "
Aug 2 2009
Don
La Verne, Ca
I am:
  • Practical
Reviewed at:
Price: $17.00
Works great, easy to install
5.0
    Pros
  • Easy To Assemble
  • Smooth Edges
  • Supports Weight
    Cons
  • None
    Best Uses
  • Convenience
  • Space Saver
"I didn't use it for the purpose it was designed for, but it works great for what I needed. Staff were very helpful on the phone. "
Jun 25 2009
The Bomb
PA
I am:
  • Practical
Reviewed at:
Price: $17.00
This VCR mount is an excellent solution!
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Multiple Viewing Angles
  • Sturdy
    Cons
  • None
    Best Uses
  • Bedroom
  • Changing Viewing Angle
  • Classroom
  • Home
  • Office
"This VCR mount is an excellent solution and was an easy adaptation under our TV arm wall mount. "
Mar 4 2008
Tom R
Oregon
I am:
  • Practical
  • Tech Savvy
Reviewed at:
Price: $17.00
As advertised
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • None
    Best Uses
  • Bedroom
  • Kitchen
"Item works well with the TV wall mount. It is easy to use and fulfilled all advertising and then some. "
Nov 30 2007
Big Mac
SLC Ut.
I am:
  • Gearhead
Reviewed at:
Price: $17.00
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
