Peerless Paramount Universal Tilting LCD/Plasma Wall Mount
#532
4.3
based on 10 reviews
Ratings Distribution
5 star
6
4 star
3
3 star
0
2 star
0
1 star
1
Category Average
4.4
$43.99 - $77.99
from 12 stores
More Images
Pros
  • Easy to install (7)
  • Adjustable (6)
  • Interfaces well with tv (6)
  • Sturdy (6)
  • Can support weight (5)
  • Multiple viewing angles (2)
See less See more
Cons
  • Additional hw required (1)
  • Did not fit 42" panasonic (1)
  • Modification required (1)
Best Uses
  • Bedroom (3)
  • Changing viewing angle (3)
  • Home (3)
  • Family/living room (1)
Provided by Mounts and More
The NEW Paramount Series from Peerless offers many mounting solutions for all your home entertainment needs!
Features:
  • Fits most flat panels 23" to 46"
  • One-touch tilt for effortless adjustment
  • Adjustable 15° forward and -5° backward tilt for finding the optimal viewing angle
  • Easy locking handle locks the screens position into place without the use of tools
  • Includes Sorted-For-You™ fastener packs for installation to wood studs, concrete and cinder block
  • Low profile
  • Wide open wall plate design allows for total acces and a wide array of cable management options
  • Universal screen mounting brackets hook onto the wall plate for quick, easy and safe installation
  • High Gloss Black
Specifications
  • Universal mount fits screens with mounting hole patterns up to 12.94" H x 17.5" W
  • Optional IncreLok feature offers fixed tilts at -5°, 0°, 5°, 10° and 15° increments
  • Horizontal adjustment of up to 6" (depending on screen model)
  • Screen held only 2.5" from wall
  • 150 lbs weight capacity
PT640 Installation Instructions
Need professional installation? Use the or the ! Give us a call with any questions!
Specification Description
Model PT640
UPC 735029254874
Mount Adjustability Tilt
Mount Compatibility Universal
Mount designed for TV Screens
Mount Size Range (from) 24
Mount Size Range (up to) 42
Peerless Paramount Universal Tilting LCD/Plasma Wall Mount Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 18, 2009
Peerless Paramount Universal Tilting LCD/Plasma Wall Mount Reviews
Most helpful positive review
[4 of 4 customers found this review helpful]
Most helpful negative review
[6 of 10 customers found this review helpful]
5.0
get this tilt mount, it spans your studs
"If you are thinking about a tilt versus non-tilt mount, get the tilt - you can reach your plugs in the back by simply tilting the tv. The extra ten bucks is worth not having to take your tv down. Also, I've seen mounts out there that only install to one stud. Get this one instead - it spans the studs and gives you six inches or so of horizontal adjustment - good for if you are trying to center your tv...." Read Full Review »
Nov 10, 2008 by user
See more positive Peerless Paramount Universal Tilting LCD/Plasma Wall Mount reviews
1.0
42" panasonic plasma did not fit
"false advertising you should be put in jail for misleading the consumer..." Read Full Review »
Sep 02, 2008 by stellar
See more negative Peerless Paramount Universal Tilting LCD/Plasma Wall Mount reviews
Displaying 1 - 5 of 10 Reviews
Show
Sort by
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Interfaces Well With TV
  • Multiple Viewing Angles
  • Sturdy
    Cons
  • None
    Best Uses
  • Home
Also, I've seen mounts out there that only install to one stud. Get this one instead - it spans the stu …"  Read Full Review »
Was this TV Wall Mount review on the Peerless Paramount Universal Tilting LCD/Plasma Wall Mount helpful to you?
 Report Abuse  (4)  (0)  0 comments
Nov 10 2008
user
New York, NY
I am:
  • Casual User
Reviewed at:
Price: $49.99
[2 of 2 customers found this review helpful]
Works great but ...
4.0
    Pros
  • Can Support Weight
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • Modification Required
    Best Uses
  • Bedroom
  • Changing Viewing Angle
  • Family/Living Room
  • Home
"Although advertised to fit up to 46" LCD sets, the included hardware is not suitable (came with 6mm screws but required 8mm screws). This also required the slight modification (with a drill) of the TV side of the mount to make the slot big enough to fit the larger screws. The good thing is the scr …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Jul 31 2009
CharlieG
LI, NY
I am:
  • Power User
Reviewed at:
Price: $43.99
[1 of 1 customers found this review helpful]
Works Perfectly with Vizio 32"
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • None
    Best Uses
  • Bedroom
"This mount works perfectly. I needed a mount that would fulfill four criteria:
1) Would fit a Vizio 32"'s unusual (non-standard) 400mm x 200mm mounting holes.
2) Wouldn't be bigger than the TV itself.
3) Could tilt vertically.
4) Wouldn't cost a fortune.
This mount fit the bill nicel …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Mar 22 2009
SuperC142
Southern California
I am:
  • Enthusiast
Reviewed at:
Price: $43.99
1.0
    Pros
  • None
    Cons
    Best Uses
  • None
"false advertising you should be put in jail for misleading the consumer "
 Report Abuse  (6)  (4)  0 comments
Sep 2 2008
stellar
long branch, nj
I am:
  • Professional
Reviewed at:
Price: $43.99
Good
4.0
    Pros
  • Easy To Install
  • Sturdy
    Cons
  • None
    Best Uses
  • Bedroom
"Easy to install. Very sturdy. Not easy to adjust. You must take the TV off to make adjustments. Overall, very good and great for the price. "
May 21 2009
asdf
sdf
I am:
  • Casual User
Reviewed at:
Price: $43.99
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
