#519
based on 10 reviews
Ratings Distribution
| 5 star |
6 |
| 4 star |
2 |
| 3 star |
2 |
| 2 star |
0 |
| 1 star |
0 |
Category Average
$78.82 - $80.00
from 3 storesPros
Cons
Best Uses
Where to Buy
BizRate Rating
Good 8.8
BizRate Rating
Good 7.8
Product Reviews
[2 of 2 customers found this review helpful]
"After much research, decided on this product. It holds my Sony 52xbr4 LCD perfectly. Very sturdy, and as low profile as possible, any closer to the wall and adding/removing cables would be impossible. Great experience would definitely buy from mounts and more again...." Read Full Review »
Jul 27, 2008 by DB
"Already owned one of these mounts. It came with a long enough allen wrench to adjust its locking screws. This one requires a Phillips Screwdriver but there's not enough room to use one effectively to adjust the mount. Need a special, long screwdriver in order to change the tilt, etc...." Read Full Review »
Jul 11, 2009 by Hi Def is fab!
Displaying 1 - 5 of 10 Reviews
Peerless Paramount Universal Tilting LCD/Plasma Wall Mount(37" to 60" Screens) Review
Pros
Cons
Best Uses
"After much research, decided on this product. It holds my Sony 52xbr4 LCD perfectly. Very sturdy, and as low profile as possible, any closer to the wall and adding/removing cables would be impossible. Great experience would definitely buy from mounts and more again. "
[1 of 1 customers found this review helpful]
Pros
Cons
Best Uses
"Solid construction. Difficult to lock the tilt angle because the screws don't line up well with the holes. But then again, I don't care because once my 58" Samsung Plasma was on the wall, why mess with it. I recommend using the wall spacers because once it's on the wall it's almost impossible to plu …" Read Full Review »
Pros
Cons
Best Uses
"Already owned one of these mounts. It came with a long enough allen wrench to adjust its locking screws. This one requires a Phillips Screwdriver but there's not enough room to use one effectively to adjust the mount. Need a special, long screwdriver in order to change the tilt, etc. "
Pros
Cons
Best Uses
"price and quality are good. Wall anchors alone will not support weight of 50" plasma "
Pros
Cons
Best Uses
"This mount is being used for my 46" Samsung LCD. Mount is sturdy and assembled easily to TV. Lots of mounting screws provided which was nice but I am guessing that is standard fare on wall mounts. "
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Good 8.8
BizRate Rating
Good 7.8
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
