Peerless Flat Panel TV Stand with 2 Shelves for 32" - 50" Screens
#45
4.6
based on 14 reviews
from $345.25 - $449.00
Ratings Distribution
5 star
9
4 star
5
3 star
0
2 star
0
1 star
0
Category Average
4.4
More Images
Pros
  • Interfaces well with tv (12)
  • Sturdy (12)
  • Easy to install (9)
  • Adjustable (8)
  • Multiple viewing angles (6)
  • Can support weight (4)
  • Adequate weight capacity (1)
  • Adjustable height (1)
  • Great materials (1)
  • Height adjustability (1)
See less See more
Cons
  • Difficult to assemble (1)
  • Limited adjustability (1)
  • Tricky to assemble (1)
Best Uses
  • Home (8)
  • Family/living room (5)
  • Bedroom (4)
  • Office (4)
  • Changing viewing angle (2)
  • Classroom (1)
  • Corner with limited space (1)
  • Improve viewing angle (1)
  • Organization (1)
  • Workgroups (1)
Provided by TV Stands.com
Show off your plasma or LCD in style with the new Flat Panel TV Stand by Peerless. The Stand is designed to provide ideal screen viewing position, centralize audio/video component and accessory placement and match the decor of any enviroment. Its unique design allows the Flat Panel TV Stand to be positioned in a corner or against the wall, offering unlimited placement opportunities. Internal cable management hides all the A/V cabling, providing a clean, clutter-free look.
Features:
  • Fits most 32" to 50" LCD and plasma flat panel screens
  • Vertical adjustment for optimal viewing
  • Incremental tilt for viewing flexibility
  • Two adjustable tempered tinted glass shelves hold A/V equipment up to 50 lbs
  • High gloss piano black base is sure to impress
  • Choose black or silver scratch-resistant fused epoxy finish
Specifications:
  • Universal mounting brackets fit most 32"-50" screens: maximum height of mounting pattern is 18"
  • Incremental tilt of -2°, 0°, and +5° to achieve the ideal viewing angle
  • Vertical screen adjustment feature for optimal viewing height
  • Internal cable management neatly conceals all cords and cables for a clean, clutter-free look
  • Adjustable glass shelving for AV components and accessories
  • UL listed
  • Screen weight capacity: 150 lbs
  • Accessory shelf weight capacity: 50 lbs per shelf
  • Adjustable mounting pattern: 17.05" H x 28.75" W
  • Dimensions: 61" H x 40.1" W x 25.5" D
      SS550P Flat Panel TV Stand with 2 Shelves Technical Data
      Need professional installation? Use the or the ! Give us a call with any questions!
Specification Description
Model FST 550P, FST550P, SS550P
Color Black
Material Glass Shelf
Peerless Flat Panel TV Stand with 2 Shelves for 32" - 50" Screens Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 6, 2009
Peerless Flat Panel TV Stand with 2 Shelves for 32" - 50" Screens Reviews
Displaying 1 - 5 of 14 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Great Item[...]
4.0
    Pros
  • Easy To Adjust
  • Great materials
  • Interfaces Well With TV
  • Multiple Viewing Angles
  • More »
    Cons
  • Assembly a bit tricky
    Best Uses
  • Family/Living Room
  • Home
"This stand was the perfect fit for a corner in our 10.5'X16' den. PROS:1. The finishes are very shiny and the materials are of high quality. 2.We had a tough minute or two when figuring out how to assemble it but once we got it, it was easy. One thing to note is that it is a very sturdy, heavy pi …"  Read Full Review »
Was this TV Wall Mount review on the Peerless Flat Panel TV Stand with 2 Shelves for 32" - 50" Screens helpful to you?
 Report Abuse  (1)  (0)  0 comments
Apr 19 2009
Keerland
Long Island, NY
I am:
  • Enthusiast
Reviewed at:
Price: $449.00
Great stand!
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • None
    Best Uses
  • Changing Viewing Angle
  • Home
  • Office
"[...] I did, and the it was in perfect condition, as the manufacture packaged it very well. All parts were protected indivually.I read from others that had purchased the same stand and they complained about the assembly. I think the problem was installing the foot of the stand to the vertical column …"  Read Full Review »
Apr 18 2009
Louis-pop
New England
I am:
  • Casual User
Reviewed at:
Price: $449.00
Great solution for a corner Flat Screen
4.0
    Pros
  • Can Support Weight
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • None
    Best Uses
  • Bedroom
  • Classroom
  • Home
  • Office
"This stand is very sturdy and looks great in the corner. I've seen other comments that this stand is difficult to install but I think if you are reasonably handy the installation should go smoothly. A second pair of hands will make the job easier. I've seen other comments regarding wiring. True, o …"  Read Full Review »
May 9 2009
Art
Point Pleasant, NJ
I am:
  • Power User
Reviewed at:
Price: $449.00
BANKAI !
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • Limited Adjustability
    Best Uses
  • Bedroom
  • Home
  • Office
"for bedroom viewing its great. tilt allows to adjust to height of bed. but have to physically move left or right to change viewing angle...but this depends on viewing angle of tv. i use with a Samsung 40 inch LCD HDTV...and its great.!!!
also one person can assemble in less than 30 min with tool …"  Read Full Review »
Jul 22 2009
typhoon
IOWA...you can see the rainbow from here
I am:
  • Power User
Reviewed at:
Price: $449.00
This is a fantastic flat panel tv stand
5.0
    Pros
  • Easy To Install
  • Sturdy
    Cons
  • no cons
    Best Uses
  • Home
  • Office
"This product was exactly as advertised. It's very sturdy and is perfect in the corner of my office/exercise room. It took me about 90 minutes to install by myself. The only help I needed was lifting the tv. "
Oct 6 2009
Mykl 12
Fresno, CA
I am:
  • Enthusiast
Reviewed at:
Price: $385.00
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
