Peavey PR-15D Powered Loud Speaker 15 Inch 2-Way
#297
5.0
based on 1 review
from $479.99
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.4
$479.99 at PSSL.com - ProSound and Stage Lighting
Find it at Amazon
Find it at Ebay
Pros
  • Great sound quality (2)
  • Attractive design (1)
  • Easy to connect (1)
  • Powerful (1)
See less See more
Best Uses
  • Basic systems (1)
  • Outdoors (1)
  • Smaller rooms / apartments (1)
Provided by PSSL.com - ProSound and Stage Lighting
PR 15D The Peavey PR 15D is a powered, bi-amplified, two-way speaker system engineered to provide very high levels of performance in a compact powered loudspeaker. The PR 15D is capable of up to 120 dB peak SPL. The enclosure utilizes tough polypropylene in an injection-molded plastic trapezoidal form, with a coated steel grille to offer an attractive yet-durable powered speaker system. This two-way powered system is comprised of a 150 W class D power amplifier driving a 15" heavy duty woofer. The RX™14 compression driver is driven by a 50 W class D power amplifier and features a 1.4” titanium diaphragm coupled to an extremely smooth and well-controlled constant directivity horn (with a coverage pattern of 90° by 40°) that is molded integrally into the enclosure. A balanced input to the preamp/EQ electronics consists of one combo female XLR and 1/4” TRS phone jack. It is switchable between mic-level and line-level sensitivity. Two 1/4” phone jacks are provided for link-out / direct-in capability. The link-out is post- level and pre-crossover. While the direct-in is a direct pre-crossover input. A woofer servo senses back-EMF from the woofer voice coil that is not a result of the drive signal, and subtracts the error so that the woofer cone follows the drive waveform precisely. Constant Loudness (Fletcher-Munson) circuit for accenuating bass and treble at low listening volume levels. The power amplifiers providing the bi-amplification are low-distortion units providing 150 W continuous RMS into the nominal 8 ohm load of the woofer, and a 50 W continuous RMS into the nominal 8 ohm load of the tweeter. They were selected for their reliability and superb musical performance capability. Both amplifiers feature our patented DDT™ compression, which virtually eliminates audible power amplifier clipping. A molded-in handle provides ease of transport, while multiple mounting points (top and bottom) for the Peavey Versamount™ allow maximum utility. Features: Bi-amplified powered system with 200 watts maximum output Both power amps have DDT(TM) compression One 15" neodymium, 2.375" voice coil woofer Woofer servo RX(TM) 14 1.4" titanium compression driver Automatic equal loudness (Fletcher-Munson) compensation Combo jack with 1/4" TRS & female XLR mic or line-level balanced input Two 1/4" phone jack inputs for link-out/ link-in capability Molded-in horn has exceptionally smooth response & pattern control Top & side handgrips Pole mount molded-in Top & bottom flyng point inserts
Peavey PR-15D Powered Loud Speaker 15 Inch 2-Way Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jun 3, 2009
Peavey PR-15D Powered Loud Speaker 15 Inch 2-Way Reviews
Displaying 1 - 1 of 1 Reviews
Show
Sort by
great buy
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Great Sound Quality
  • Powerful
    Cons
  • None
    Best Uses
  • Basic Systems
  • Outdoors
  • Smaller Rooms
"use the peaveys pr15ds for dj use, very loud good thump no need for sub in smaller rooms highly recommended. "
Was this Speaker & Subwoofer review on the Peavey PR-15D Powered Loud Speaker 15 Inch 2-Way helpful to you?
Jun 3 2009
berto
newburgh.ny
I am:
  • Practical
  • Tech Savvy
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
