Parrot MINIKIT Slim Bluetooth® Handsfree Vehicle Kit
#169
3.8
based on 9 reviews
Ratings Distribution
5 star
2
4 star
5
3 star
1
2 star
0
1 star
1
Category Average
3.6
$74.99 - $99.99
from 3 stores
More Images
Pros
  • Clear sound (4)
  • Lightweight (3)
  • Simple / intuitive controls (3)
  • Versatile (2)
  • Battery life seems good (1)
  • Comfortable (1)
  • Great sound quality (1)
  • Highly compatible (1)
See less See more
Cons
  • Poor design (2)
  • Flimsy (1)
  • Softwear not current (1)
Best Uses
  • Travel (6)
  • Good for commuting (3)
  • Long talks (2)
  • With my phone (1)
Provided by Buzzillions.com
Slim Bluetooth Speakerphone: The Parrot Minikit Slim Makes It Very Easy To Make And Receive Calls Without Taking Your Eyes Off The Road To Look At Your Phone---Automatically Download The Phonebook And Gives You Quick Access To Entries Via Voice Command And Rotary Encoder Sets The Parrot Minikit Slim Apart From Your Average Speakerphone. Nxt Flat Panel Speaker Technology Creates An Exceptionally Light And Thin Design---Compact Portable Rechargebale
Specification Description
Model MINIKIT SLIM, MINIKITSLIM, MiniKitSlim, Minikit Slim
UPC 715663212621
Accessory Indicator Yes
Battery Average Run Time 15
Battery Average Run Time UOM HOURS
Battery Type Product
Benefits Pair up to 5 Bluetooth-compatible devices with this Bluetooth handsfree vehicle kitFeatures 2 LEDs, one green and one redHas
Benefits Pair up to 5 Bluetooth-compatible devices with this Bluetooth handsfree vehicle kitHas 3 buttons and one rotary button which lets you
Capacity UOM mAh
Chemistry Lithium Ion
Connections USB (1)
Connectivity Technology Wireless
Country Of Origin China
Description Header Handsfree calling.
Description Header Sport the Slim.
Display Catalog Number 17-4745
Display Catalog Number 55032291
Enclosure Color Black/Silver
End Product Indicator Yes
Headphones Technology Bluetooth
Included in the Box Parrot MINIKIT SlimVehicle chargerHome charger
Manufacturer Labor Warranty 12
Manufacturer Part Number MINIKIT SLIM
Manufacturer Parts Warranty 12
MAP Price 0.0
MAP Price 99.0
Model MINIKIT SLIM
New Date Thu Sep 10 00:00:00 CDT 2009
Operating Temperature UOM ° F
Power Device Vehicle adapter/charger, home adapter/charger both included
Power Device Vehicle charger, home charger
Product Depth 0.75
Product Depth 4.33
Product Dimensions UOM inches
Product Height 1.14
Product Height 4.25
Product Type Speakerphones
Product Weight 2.93
Product Weight 3.2
Product Weight UOM ounces
Product Width 2.36
Product Width 3.3
Radio Frequency Range 2.4GHz
Recharge Time 4
Recharge Time UOM HOURS
Rechargeable Yes
Response Bandwidth 2.4GHz
Size Specialty
Supported Languages English
Transmission Range 33 feet
Parrot MINIKIT Slim Bluetooth® Handsfree Vehicle Kit Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 3, 2009
Parrot MINIKIT Slim Bluetooth® Handsfree Vehicle Kit Reviews
Displaying 1 - 5 of 9 Reviews
Show
Sort by
Dysfunctional
1.0
    Pros
  • Clear Sound
    Cons
  • Poor Design
    Best Uses
  • Travel
"The voice command worked for a day and then quit working. The website suggested resetting by holding down a button on the front and one on the back...there is no button on the back. The website does not provide a way to download an updater but they do say one exists. I suggest you skip this product. …"  Read Full Review »
Was this Cell Phone Accessory review on the Parrot MINIKIT Slim Bluetooth® Handsfree Vehicle Kit helpful to you?
Sep 3 2009
Dawgdrum
Santa Rosa CA
I am:
  • Practical
Works Great
4.0
    Pros
  • Clear Sound
  • Easy Controls
  • Lightweight
    Cons
  • None
    Best Uses
  • Commuting
  • Long Talks
  • Travel
"So far this unit has only been used for personal use and it does the trick. I was afraid it would not work with my iPhone 3G because of the phones limitations, but it works perfectly. The Minikit Slim downloaded my address book from the phone right at initial set up.
My only problem is controlling …"  Read Full Review »
Jan 21 2009
Iceman
Boston, MA
I am:
  • Gearhead
  • Practical
Reviewed at:
Price: $74.99
[2 of 2 customers found this review helpful]
Caw Caw Parrot!!!!
4.0
    Pros
  • Clear Sound
  • Easy Controls
  • Versatile
    Cons
  • Flimsy
  • Poor Design
    Best Uses
  • Commuting
  • Long Talks
  • Travel
"Wow the syncing of the phone's contacts and the bluetooth is great. no more flipping through the digital pages of your celly, just sync it and talk it up! Good sound, just wish the clip was stronger, the unit HAS fell off my visor a few times going over bumps. Other than that, no other complaints …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Jul 15 2009
Techy Gearhead Man
Honolulu, HI
I am:
  • Gearhead
Not as good as expected
3.0
    Pros
    Cons
    Best Uses
  • Travel
"First one was bad out of box. Retailer exchanged. This was the 2nd one purchased and both needed their softwear updated to use all functions.
Retaging phone book names can be tedious. "
May 29 2009
Traveling man.
DE
I am:
  • Business Professional
  • Practical
Reviewed at:
Price: $74.99
Good Bluetooth speakerphone
4.0
"I bought the Parrot a week ago. Very easy set up with my two phones. After reading the user guide that came with the speakerphone, it did not list a few of the functions - Discreet mode,, who would you like to call, I went to the parrot web site (parrot.com) to find a more descriptive user guide wit …"  Read Full Review »
Jun 7 2009
adb401
Chandler,az
Reviewed at:
Price: $99.99
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
