Panasonic VIERA TH-50PX80U 50" Widescreen 720p HDTV Plasma
#4
4.8
based on 234 reviews
from $1,209.00
Ratings Distribution
5 star
187
4 star
42
3 star
2
2 star
1
1 star
2
Category Average
4.6
$1,209.00 at Rainbow Appliance
Find it at Amazon
Find it at Ebay
More Images
Pros
  • Great picture quality (81)
  • Fast setup (74)
  • Attractive design (72)
  • Simple controls (65)
  • High resolution (16)
  • Good connection options (15)
  • Wide viewing angle (14)
  • Good value (1)
  • Huge theatre like (1)
  • Viera link (1)
See less See more
Cons
  • Poor sound quality (3)
  • Difficult to set up (1)
  • Fast motion shadows (1)
  • Heavy / bulky (1)
  • Manual can be confusing (1)
  • Need 2 people to uncrate (1)
  • No hdmi cables (1)
  • No pip (1)
  • No tilt base (1)
Best Uses
  • Home (72)
  • Movies (54)
  • Wall mounting (15)
  • Video (12)
  • Home theater (6)
  • Office (5)
  • Bedroom (4)
  • Professional (4)
  • Great for ps3 (1)
  • Theatre surround (1)
Provided by Beach Audio
Treat yourself with the new Panasonic Viera Plasma 50" HDTV, youll enjoy watching your favorite shows and sporting events on the large 50" screen TV in high-definition. The Panasonic Viera Plasma gives you intense colors and the sharpest images. You can use this to display all your favorite photos from your Digital camera with the built-in SD card slot, giving you your own photo galley inside your living room.
Features:
- 50" Screen Size
- 720p Display Resolution
- 1080p/1080i/720p/480p Compatible Signal Formats
- 1024 x 768 Native Pixel Resolution
- 720 lines or more Moving Picture Resolution
- 1000000:1 Dynamic, 15000:1 Native Contrast Ratio
- 16:9 (Widescreen) Aspect Ratio
- G11 Progressive 1080p HD Plasma Display Panel Type
- Motion Adaptive 3D-Y/C Digital Comb Filter
- Two Full-range (L,R) Speakers, 20Watt (10% THD)(8ohms, 70Hz-17kHz)
- Integrated ATSC Tuners
- ATSC / QAM / NTSC Receiving System
- SD Card Slot, Photo Viewer
- Input Ports: 3 x HDMI (1 Front), 2 x Analog Audio Input (for HDMI), 2 x Composite Video (1 Front), 2 x S-Video (1 Front), 2 x Audio Input (1 Front) (for Video), 1 x Composite Video output, 1 x Audio Output, 1 x Digital Audio Out
Diagonal Screen Size
50" Class (41.6" diagonal)
Display Resolution 720p
Contrast Ratio
Native: 15000:1
Dynamic: 1000000:1
Compatible Signal Formats 1080p/1080i/720p/480p
Aspect Ratio 16:9 (Widescreen)
Shades of Gradation 4,096
Pixel Pitch (H x V) 0.81 x 0.81 mm
Panel Type G11 Progressive 1080p HD Plasma Display Panel
Aspect Control for TV/AV Modes 4:3, Zoom, Full, Just, H-Fill
Native Resolution (Number of Pixels) 1,049,088 (1,366 x 768)
Moving Picture Resolution 720 lines or more
Progressive Scan Yes
Video Noise Reduction Yes
Digital Comb Filter Motion Adaptive 3D-Y/C
Color Purity Optimizer (3D Color Management) Yes
Sub-Pixel Controller Yes
Motion Pattern Noise Reduction Yes
Digital Cinema Reality Yes
480 Hz Sub-field Drive Yes
24p Playback(2:3) Yes
Deep Color Yes
x.v.Color Yes
Audio
Speakers Full-range x 2 (L,R)
Number of Speakers 2
Audio Ouput 20W (10% THD) (8 ohms, 70Hz-17kHz)
Surround Sound Yes
Tuners Integrated ATSC
Photo Viewer Yes
SD Card Slot Yes
HDMI Input 3 (1 front)
Analog Audio Input (for HDMI) 2
Composite Video Input 2 (1 front)
S-Video Input 2 (1 front)
Audio Input (for Video) 2 (1 front)
Component Video Input [Y, PB(CB), PR(CR)] 2
Audio Input (for Component Video) 2
Composite Video Output 1
Audio Output 1
Digital Audio Out 1
VIERA Link Yes
Game Mode Yes
Pixel Shifter (Anti-Image Retention) Yes
Video Picture Memory Yes
On-Screen Display Languages
English/Spanish/French
V-Chip Program Lockout Yes
Built-In Closed Caption Decoder Yes
Timers - Sleep/On/Off
Sleep (Off only)
Video Input Labeling Yes
Power Supply AC 120 V, 60 Hz
Power Consumption 497 W
Safety Standard UL6500/C-UL
Receiving System ATSC/QAM/NTSC
Operating Temperature 32F - 104F
Pedestal Stand Included (TBLX0037)
Remote Control Included
Approximate Dimensions (H x W x D)
Including Pedestal Stand 33.1" x 47.6" x 15.2"
TV Set only 31.1" x 47.6" x 3.7"
Approximate Weight
Including Pedestal: 82.7 lbs
TV Set Only: 76.8 lbs
Shipping 101.5 lbs
Specification Description
Model 2072465, PANTH50PX80, TH-50PX80U, TH50PX80U
UPC 037988241798
Analog Audio (1) Front Input
Analog Audio (1) Rear Output
Analog Audio (5) Rear Input
Analog Audio / Video Front Input
Analog Audio / Video Rear Input
Aspect Ratio 16:9
Card Slot Secure Digital
color null
Compatible Formats 1080i
Compatible Formats 1080p
Compatible Formats 480i
Compatible Formats 480p
Compatible Formats 720p
Component Video (2) Rear Input
Composite Video Front Input
Composite Video Rear Input
Contrast Ratio 1000000:1
Contrast Ratio 15,000:1
Contrast Ratio 15000:1
Depth (Inches) 15.2
Dynamic Contrast Ratio 1000000:1
HDMI (1) Front Input
HDMI (2) Rear Input
HDTV HDTV Tuner Built In
HDTV Capable HD Tuner is included
HDTV Native Resolution 720p
Height (Inches) 33.1
Ports 1 x S-Video In Front
Resolution 1366 x 768
S-Video Front Input
S-Video Rear Input
Screen Format 16:9 Widescreen TV Imaging
Screen Size 50"
Screen Size 50" to 60"
Screen Size (inches) 50
Screen Size (Inches/Diagonal) 50
Select Plasma Units
size null
sku 132633
skuprice 1019.9900
style PANTH50PX80
taxable Y
Technology HDTV
Tuner ATSC
Weight (Pounds) 82.7
Width (Inches) 47.6
Panasonic VIERA TH-50PX80U 50" Widescreen 720p HDTV Plasma Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jun 12, 2009
Panasonic VIERA TH-50PX80U 50" Widescreen 720p HDTV Plasma Reviews
Most helpful positive review
Most helpful negative review
5.0
What a great TV and a great deal!
"[...] Initially I assembled it on a sturdy magazine table using the pedestals provided. I'm an able guy and was able to lift and lower the TV onto the pedestal myself. I eventually plan to wall mount it but this game me a chance to connect the wires and see how things worked; I'm glad I did it this way. Initially I hooked up the TV using an RCS audio cables/S-video cord to my cable box. This gave me an OK pictur..." Read Full Review »
Dec 22, 2008 by GFLJO boss Andy
See more positive Panasonic VIERA TH-50PX80U 50" Widescreen 720p HDTV Plasma reviews
3.0
I loved it until
"I have owned the th-50X77U for a year. Everything was great until December when a 4 inch stripe of blue appeared on the left side of the screen, but it went away after a few days. Then, in October the stripe returned. fortunately, I still have the plasma concierge service from panasonic. I called and they set up an appointment for a local company to come fix it. but when that time came they did not come. I calle..." Read Full Review »
Oct 20, 2008 by panch02
See more negative Panasonic VIERA TH-50PX80U 50" Widescreen 720p HDTV Plasma reviews
Displaying 1 - 5 of 234 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • No PC connection
    Best Uses
  • Home
  • Movies
  • Wall Mounting
"[...] Initially I assembled it on a sturdy magazine table using the pedestals provided. I'm an able guy and was able to lift and lower the TV onto the pedestal myself. I eventually plan to wall mount it but this game me a chance to connect the wires and see how things worked; I'm glad I did it this …"  Read Full Review »
My TH-50PX80U, soon to go on the wall above
  • Picture of Product
Was this Plasma TV review on the Panasonic VIERA TH-50PX80U 50" Widescreen 720p HDTV Plasma helpful to you?
Dec 22 2008
GFLJO boss Andy
Stanley, NY
I am:
  • Enthusiast
Reviewed at:
[8 of 8 customers found this review helpful]
Excellent Brand, Excellent Product
5.0
"After a few months of shopping around I finally decided on the Panasonic 50" 720p Flat-Panel Plasma HDTV. I got it on sale for $999, plus about $200 for the 4 year waranty and about $70 sales tax. It really is an excellent deal at that price, especially for a Panasonic Plasma TV.
I have only had th …"  Read Full Review »
 Report Abuse  (8)  (0)  0 comments
Nov 10 2008
Joe67
Connecticut
[3 of 3 customers found this review helpful]
Stunning right out of the box
4.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
    Cons
    Best Uses
  • Great for PS3
  • Home
  • Movies
  • Video
"This TV looks great right out of the box and works well with my other Panasonic equipment. The manuals can be a little confusing as they don't go into great detail about advanced set up or what the picture modes are best for. A little bit of experimentation and a home theater set up disc such as the …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Mar 29 2008
P40whk
Cincinnati Ohio
I am:
  • Tech Savvy
Reviewed at:
Underpriced!!
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Huge theatre like
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Movies
  • Theatre surround
"We bought this plasma while looking for a dryer. We can't get away from the darn thing. Movie after movie, HD tv channel after another. The picture is awesome. Clear picture and sound.I did a lot of research on all kinds of Plasma TVs and realized that if you stick to the basics features like stere …"  Read Full Review »
Mar 8 2008
Sal
Barrington Illinois
I am:
  • Practical
Reviewed at:
BEST VALUED 50" HDTV ON THE MARKET!
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
  • VIERA LINK
    Cons
  • None
    Best Uses
  • Home
  • Movies
  • Office
  • Professional
  • Wall Mounting
"PLASMA IS THE WAY TO GO HANDS DOWN, NO DOUBT ABOUT IT!I'VE DONE A TON OF RESEARCH AND FOUND THAT THIS PANASONIC 720P HDTV, FOR UNDER $1,000 HAS EXCEPTIONAL QUALITY FOR THE VALUE, BEING THAT 1080P HDTV'S ARE A COMPLETE WASTE AT ANY SIZE 55" AND SMALLER, ACORDING TO [@]. 720P IS THE WAY TO GO. IN FACT …"  Read Full Review »
Feb 3 2009
DEAL HUNTER
COLUMBUS, OHIO
I am:
  • Enthusiast
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
