Panasonic Viera TCL37X1 37 LCD HDTV
#92
4.9
based on 9 reviews
from $499.00 - $569.98
Ratings Distribution
5 star
7
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.4
Low Price:
$499.00 at US Appliance
 Trusted:
$529.95 at Beach Camera
Find it at Amazon
More Images
Pros
  • Attractive design (1)
  • Fast setup (1)
  • Good connection options (1)
  • Great picture quality (1)
  • High resolution (1)
  • Simple controls (1)
  • Wide viewing angle (1)
See less See more
Best Uses
  • Bedroom (1)
  • Home (1)
  • Home theater (1)
  • Movies (1)
Provided by Buzzillions.com
The new X1 Series LCD HDTVs are ideal for lovers of music and videos. The iPod® Entertainment Kit lets you control and play back your iPod music and videos.
Control and Play Back Music and Videos from Your iPod
With the included iPod Entertainment Kit, a universal iPod dock provides a convenient way to enjoy music, videos and photos on your VIERA HDTV. Intuitive on-screen menus make it a breeze to control the action with the TVs remote.
Share Your Digital Photos on the Big Screen
VIERA Image Viewer provides a better way to share your digital photos. Just pop your SD memory card into the handy slot, and instantly display your digital photos for friends and family to enjoy.
Network Your AV Devices, Quickly and Easily
With VIERA Link, you can control your compatible Panasonic DVD recorder, Blu-ray Disc player, home theater sound system and HD camcorder, all with a single remote and helpful on-screen menus.
  • 720p Resolution
  • Contrast Ratio: 12,000:1
  • iPod Entertainment Kit
  • Intelligent Scene Controller
  • VIERA Image Viewer
  • VIERA Link
  • PC Input
  • Game Mode
  • 3 HDMI Inputs
  • Specification Description
    Model TC-L37X1, TCL37X1
    UPC 037988108701
    16:9 Mode Yes
    Audio Controls Bass, Treble, Balance, A.I. Sound, Surround, Volume leveler
    Battery Type Remote
    Benefits 37" (diagonal) widescreen display delivers great 16:9 aspect ratio and up to 1366x768 resolutionBuilt-in ATSC/NTSC tuners for DTV and
    Brightness 450 cd/m2
    Capacity UOM mAh
    Channel Labeling Yes
    Chemistry Alkaline
    Closed Caption Capability Yes
    Color Depth 16.7 million colors
    Color Temperature Control Yes
    Compliant Standards UL Listed, FCC/DHHS Certified, Energy Star compliant
    Connections HDMI (3)Antenna (1)Component video in (1)Composite video in (1)S-video in (1)Analog audio in (2)<
    Controls / Adjustments Contrast, Brightness, Color, Tint, Sharpness, Picture mode, Backlight, Color temperature, Color management, A.I. picture, Zoom adjustments, Color matr
    Country Of Origin China
    Description Header A lot of entertainment in one package.
    Display Catalog Number 55035158
    Display Languages English, Spanish, French
    Display Menu Language English, Spanish, French
    Display Size 37 inches
    Enclosure Color Black
    End Product Indicator Yes
    Expansion Slot(s) SD
    Image Aspect Ratio 16:9
    Included in the Box Panasonic® Viera® TC-L37X1 37" LCD HDTVPedestalAssembly screws (10)Remote control"AA" batteries (2
    Manufacturer Labor Warranty 12
    Manufacturer Part Number TC-L37X1
    Manufacturer Parts Warranty 12
    MAP Price 0.0
    Max Operating Temperature 104 Fahrenheit
    Min Operating Temperature 32 Fahrenheit
    Model TC-L37X1
    Operating Temperature UOM ° F
    Output Power / Total 20 watts
    Parental controls Yes
    Pixel Response Time 8 ms
    Power Consumption Operational 150W
    Product Depth 11.3
    Product Dimensions UOM inches
    Product Height 24.5
    Product Type Flat-panel TVs
    Product Weight 35.9
    Product Weight UOM pounds
    Product Width 36.1
    Reception System NTSC/ATSC/QAM
    Screen Size Range 31-40"
    Secondary Audio Program (SAP) Yes
    Size AA
    Sound Output Mode Stereo
    Speaker(s) Built-in, 10W + 10W
    Speakers Included 2 Speakers
    Supported Languages English, Spanish, French
    Technology IR
    TV Diagonal Size 37 inches
    TV Image Contrast Ratio 12000:1
    TV Resolution 1366x768
    TV Technology LCD
    Type LCD
    V-Chip Control Yes
    Viewing Angle 178 Degrees
    Viewing Angle (Vertical) 178 Degrees
    Voltage 1.5
    Voltage Required 120VAC, 60Hz
    Voltage UOM Volts
    Widescreen Modes 480i, 480p, 720p, 1080i
    Panasonic Viera TCL37X1 37 LCD HDTV Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Nov 16, 2009
    Panasonic Viera TCL37X1 37 LCD HDTV Reviews
    Displaying 1 - 5 of 9 Reviews
    Show
    Sort by
    Excellent!
    5.0
      Pros
    • Attractive Design
    • Bright Image
    • Fast Setup
    • Good Connection Options
    • Good Resolution
    • More »
      Cons
    • None
      Best Uses
    • Bedroom
    • Home
    • Home Theater
    • Movies
    "I'm 60 years old and absolutely despise new products that require a lot of programing before you can use them. So, I was absolutely delighted when I connected the cable and found that it worked, perfectly, without any set-up! The picture is not so great when viewed from an extreme angle, but I thi …"  Read Full Review »
    Was this LCD TV review on the Panasonic Viera TCL37X1 37 LCD HDTV helpful to you?
    Nov 16 2009
    Nancy
    Clearfield, KY
    I am:
    • Casual User
    Reviewed at:
    Price: $559.99
    This does even more than whats listed
    5.0
    "I'll try to be concise, check my enthusiasm and provide an analytical review....
    Boring stuff:
    Physical Setup: took longer to remove the box/protective shrink wrap than to put it together (quick and easy).
    TV Menu/channels Setup: Very intuitive, you don't really need to read the short portion of …"  Read Full Review »
    Apr 11 2009
    honestbabe
    Berkeley, CA
    [2 of 2 customers found this review helpful]
    Review:This TV is ...
    5.0
    "Review:This TV is fantastic, especially for the price. I don't even have HD service--I've got it displaying a standard definition cable signal--and it's the best picture I've seen with SD on an HD set. I've also fed it video content from a computer via the VGA connection, which is crystal clear.
    Th …"  Read Full Review »
     Report Abuse  (2)  (0)  0 comments
    Sep 19 2009
    MiS
    Undisclosed
    Reviewed at:
    Price: $550.00
    [1 of 1 customers found this review helpful]
    Love this TV
    5.0
    "Review:I am thrilled with this TV! At first I was worried about the picture, but I just needed to adjust the picture settings. The menus and remote are very easy to use. The speakers are lacking but I use a sound surround system with the TV. Love the IPOD dock.
    Great TV! I highly recommend it, espe …"  Read Full Review »
     Report Abuse  (1)  (0)  0 comments
    Oct 5 2009
    Mitch11
    Dayton, Ohio
    Reviewed at:
    Price: $550.00
    Best value for your money without over spending.
    5.0
    "I bought this product about three weeks ago. I had to special order this item because the store didn't have it in stock. I was not dissapointed when I got this LCD TV. WOW!!!! Picture was crystal clear on my direct TV satellite. Good sound, loud not even reaching at the halfway point. I wanted to ge …"  Read Full Review »
    May 8 2009
    49ers164
    Texas
    pages: 1 2 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
