Panasonic ® Viera® TC-L32X1 32" LCD HDTV
#19
4.7
based on 59 reviews
Ratings Distribution
5 star
42
4 star
14
3 star
1
2 star
0
1 star
0
Category Average
4.4
$379.57 - $418.49
from 16 stores
More Images
Pros
  • High resolution (25)
  • Fast setup (23)
  • Great picture quality (23)
  • Attractive design (21)
  • Simple controls (21)
  • Good connection options (20)
  • Wide viewing angle (14)
  • Everything i wanted it to (1)
  • Great for media (1)
  • This tv (1)
See less See more
Cons
  • No sd card video playbac (1)
  • No swivel stand (1)
  • Poor cc option (1)
  • Poor connection options (1)
  • Poor sound quality (1)
  • Too trendy design (1)
Best Uses
  • Bedroom (21)
  • Home (13)
  • Movies (9)
  • Wall mounting (7)
  • Home theater (5)
Provided by nulime.com
Product Model: TC-L32X1
Lets you control and playback your iPod music and videos directly through your Viera TC-L32X1 HDTV. It provides a better way to share your digital photos with friends and family. Lets you control all compatible audio and video devices via a single remote and helpful on-screen menus.
Technical Information
Actual Screen Size: 26"
Compatible Technology: HDTV
Horizontal Viewing Angle: 178
Vertical Viewing Angle: 178
Aspect Ratio: 16:9
Maximum Response Time: 8ms
Features:
  • Channel Labeling
  • Closed Caption
HDTV Tuner: Yes
Video
Digital Tuner: ATSC
Analog Tuner: NTSC
Maximum Resolution: 1366 x 768
Contrast Ratio: 12000:1
Brightness: 400 Nit
Comb Filter: 3D Y/C
Scan Format:
  • 720p
  • 480p
  • 1080i
Audio
Number of Speakers: 2
Total Output Power: 20W
Audio Decoding: Stereo
Sound System: Surround
Interfaces/Ports
Ports:
  • 1 x Audio Line Out
  • 1 x Audio Line In Side
  • 3 x Audio Line In Rear
  • 1 x HDMI Digital Audio/Video In Side
  • 2 x HDMI Digital Audio/Video In Rear
  • 1 x Composite Video In Rear
  • 1 x Composite Video In Side
  • 1 x S-Video In Side
  • 1 x HD-15 VGA In
  • 1 x Component Video In
Controls/Indicators
Language Support:
  • English
  • French
  • Spanish
Power Description
Input Voltage: 110V AC
Power Consumption: 120W
Physical Characteristics
Dimensions: 20.2" Height x 31.5" Width x 3.9" Depth
Weight: 28.9 lb
Miscellaneous
Green Compliance: Yes
Green Compliance Certificate/Authority: Energy Star
Specification Description
Model 2392989, PANTCL32X1, TC-L32X1, TCL32X1
UPC 037988108718
16:9 Mode Yes
Audio Controls Bass, Treble, Balance, A.I. Sound, Surround, Volume leveler
Battery Type Remote
Benefits 32" (diagonal) widescreen display delivers great 16:9 aspect ratio and up to 1366x768 resolutionBuilt-in ATSC/NTSC tuners for DTV and
Brightness 450 cd/m2
Capacity UOM mAh
Channel Labeling Yes
Chemistry Alkaline
Closed Caption Capability Yes
Color Depth 16.7 million colors
Color Temperature Control Yes
Compliant Standards UL Listed, FCC/DHHS Certified, Energy Star compliant
Connections HDMI (2)Antenna (1)Component video in (1)Composite video in (1)S-video in (1)Analog audio in (2)<
Controls / Adjustments Contrast, Brightness, Color, Tint, Sharpness, Picture mode, Backlight, Color temperature, Color management, A.I. picture, Zoom adjustments, Color matr
Country Of Origin China
Description Header A lot of entertainment in one package.
Display Catalog Number 55035156
Display Languages English, Spanish, French
Display Menu Language English, Spanish, French
Display Size 32 inches
Enclosure Color Black
End Product Indicator Yes
Expansion Slot(s) SD
Image Aspect Ratio 16:9
Included in the Box Panasonic® Viera® TC-L32X1 32" LCD HDTVPedestalAssembly screws (10)Remote control"AA" batteries (2
Manufacturer Labor Warranty 12
Manufacturer Part Number TC-L32X1
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Operating Temperature 104 Fahrenheit
Min Operating Temperature 32 Fahrenheit
Model TC-L32X1
Operating Temperature UOM ° F
Output Power / Total 20 watts
Parental controls Yes
Pixel Response Time 8 ms
Power Consumption Operational 120W
Product Depth 8.6
Product Dimensions UOM inches
Product Height 21.7
Product Type Flat-panel TVs
Product Weight 37.5
Product Weight UOM pounds
Product Width 31.5
Reception System NTSC/ATSC/QAM
Screen Size Range 31-40"
Size AA
Sound Output Mode Stereo
Speaker(s) Built-in, 10W + 10W
Speakers Included 2 Speakers
Supported Languages English, Spanish, French
Technology IR
TV Diagonal Size 32 inches
TV Image Contrast Ratio 12000:1
TV Resolution 1366x768
TV Technology LCD
Type LCD
V-Chip Control Yes
Voltage 1.5
Voltage Required 120VAC, 60Hz
Voltage UOM Volts
Widescreen Modes 480i, 480p, 720p, 1080i
Panasonic ® Viera® TC-L32X1 32" LCD HDTV Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 14, 2009
Panasonic ® Viera® TC-L32X1 32" LCD HDTV Reviews
Most helpful positive review
[3 of 4 customers found this review helpful]
Most helpful negative review
5.0
Great TV [...]
"Another quality product from Panasonic. If you have been waiting to pull the trigger on buying a 32" LCD, you would be hard pressed to find a better deal than this. Out of the box, the color is perfectly balanced and the controls, menus and remote are functional and intuitive. The sound is great too. [...]..." Read Full Review »
Jun 19, 2009 by D
See more positive Panasonic ® Viera® TC-L32X1 32" LCD HDTV reviews
3.0
Lacks some basic features
"I got this a "second" tv for the den. When I got it, I did a quick setup and check out to make sure it was working. I was then out of town for 2 weeks on business. I finally got a chance to thoroughly check it out about 10 days ago. As others have noted, the picture quality is very good - certainly not "right-out-of-the-box", but it can be adjusted to produce a solid HD picture. I have Directv but I also use an ..." Read Full Review »
May 20, 2009 by LittleChubby
See more negative Panasonic ® Viera® TC-L32X1 32" LCD HDTV reviews
Displaying 1 - 5 of 59 Reviews
Show
Sort by
[2 of 3 customers found this review helpful]
Great TV [...]
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Bedroom
  • Home
  • Home Theater
  • Movies
  • Wall Mounting
"Another quality product from Panasonic. If you have been waiting to pull the trigger on buying a 32" LCD, you would be hard pressed to find a better deal than this. Out of the box, the color is perfectly balanced and the controls, menus and remote are functional and intuitive. The sound is great too …"  Read Full Review »
Front side
Front side
  • Picture of Product
Back
Back
Was this LCD TV review on the Panasonic ® Viera® TC-L32X1 32" LCD HDTV helpful to you?
 Report Abuse  (2)  (1)  0 comments
Jun 19 2009
D
Montville
I am:
  • Enthusiast
Another Winner from Panasonic
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home
  • Home Theater
  • Movies
  • Wall Mounting
"The image adjustment options are wonderful.
The "jacks" for connecting DVD, tape players, etc. provide for very easy access.
The provision for use of "SD" photo memory cards to view digital photos is great. "
Nov 21 2009
Ken
Grayslake, IL
I am:
  • Enthusiast
Great HDTV
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Bedroom
"Use the set in our bedroom about 10 foot await and find the image sharp. I thought about upgrading to a 37 inch but glad I stayed with a 32inch. "
Nov 10 2009
Chuck
San Antonio
I am:
  • Enthusiast
Wonderful TV
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Bedroom
  • Home
  • Home Theater
  • Movies
  • Wall Mounting
"I couldn't be happier. This is the first time buying a LCD TV. After doing my homework, this seemed the best fit for me. Easy set up, wonderful picture, and the sound was the best. You cannot beat the price here either. "
Nov 11 2009
Sweetjenn
Kentucky
I am:
  • Casual User
Reviewed at:
Price: $399.99
[2 of 2 customers found this review helpful]
Perfect HD for those on a budget
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Good Resolution
  • Simple Controls
    Cons
  • Poor Sound
    Best Uses
  • Home
  • Home Theater
  • Movies
"Delighted with how easy it is to switch picture proportions. We watch HD and standard satellite feed, stuff saved on the old Tivo, DVDs, which means many different formats and resolutions, and everything looks better than on our old set-up. Can't wait to get the Blu-Ray box and a HDMI capable A-V …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Oct 8 2009
cj
Baltimore, MD
I am:
  • Enthusiast
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
