Close Login Module
Join
Panasonic TH-50PZ80U Viera 50" Widescreen Plasma 1080p HDTV
#1
4.8
based on 247 reviews
Ratings Distribution
5 star
206
4 star
38
3 star
0
2 star
1
1 star
2
Category Average
4.6
$1,089.00 - $1,784.10
from 4 stores
More Images
Pros
  • Attractive design (172)
  • Fast setup (172)
  • Great picture quality (148)
  • Simple controls (142)
  • Bright image (40)
  • High resolution (38)
  • Good connection options (34)
  • Reduced glare (27)
  • All-glass front (1)
  • Best sound picture makes (1)
See less See more
Cons
  • Bad interface (1)
  • Bad picture quality (1)
  • Base doesnt swivel (1)
  • Better sound is needed (1)
  • Bezel a little glary (1)
  • Can'tcustomize inputnames (1)
  • Cheesey remote (1)
  • Controls (1)
  • Controls look (1)
Best Uses
  • Home (172)
  • Movies (148)
  • Wall mounting (46)
  • Home theater (21)
  • Video (21)
  • Office (12)
  • Professional (12)
  • Sports (7)
  • Bedroom (5)
  • Games (3)
Where to Buy
$1,089.00
$1,499.99
Code SEARS5OFF50 : $5 Off Orders Over $50!
BizRate Rating Outstanding 9.1
$1,499.99
Show all 4 stores
Product Reviews
Last update: Mar 25, 2009
Panasonic TH-50PZ80U Viera 50" Widescreen Plasma 1080p HDTV Reviews
Most helpful positive review
[5 of 5 customers found this review helpful]
Most helpful negative review
5.0
AWESOME TV but needs just one thing
"Fantastic TV, amazing picture. Stick it in THX mode and you are done. There is just one problem. The brightness (as it tends to be w/plasmas) is not great in a room which has a lot of direct sunlight. This can be fixed in custom mode where I used all the THX settings but increased the brightness. So at night, I am in THX mode and during the day, I use custom mode. Pretty simple! Overall, awesome TV..." Read Full Review »
Aug 21, 2008 by Dan Happy with this TV
See more positive Panasonic TH-50PZ80U Viera 50" Widescreen Plasma 1080p HDTV reviews
1.0
Difficult to judge picture quality
"[...] CAUTION buying expensive electronics online. Not a good experience for me...." Read Full Review »
Dec 29, 2008 by Dicontented
See more negative Panasonic TH-50PZ80U Viera 50" Widescreen Plasma 1080p HDTV reviews
Displaying 1 - 5 of 247 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • None
    Best Uses
  • None
"Fantastic TV, amazing picture. Stick it in THX mode and you are done. There is just one problem. The brightness (as it tends to be w/plasmas) is not great in a room which has a lot of direct sunlight. This can be fixed in custom mode where I used all the THX settings but increased the brightness …"  Read Full Review »
TV, Me, and a 90 gallon fish tank.
  • Using Product
  • Picture of Product
Was this Plasma TV review on the Panasonic helpful to you?
 Report Abuse  (5)  (0)  0 comments
Aug 21 2008
NYC
I am:
  • Couch Potato
  • Practical
  • Tech Savvy
  • Technically Challenged
Reviewed at:
[1 of 1 customers found this review helpful]
Simply Amazing!!
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Movies
"I have been wanting to give Abe's a review on this Tv purchase and their service, but could not figure out how to do it, this Tv has been outta stock...ha ha glad I recieved this. As for the Panasonic TH50PZ800U VIERA 50" Plasma Flat Panel HDTV. I am going to say, this is just what you have heard..U …"  Read Full Review »
Great picture of a mountain
  • Using Product
I moved a little bit but you can see the color
  • Using Product
 Report Abuse  (1)  (0)  0 comments
Jan 26 2009
M Lippert
Fremont, Ohio
I am:
  • Power User
Reviewed at:
Better than I expected
4.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
    Cons
  • None
    Best Uses
  • Home
  • Movies
"Basic set up was quick and easy. Good points: Fabulous picture, even the standard def on analog channels was a great improvement. I don't have a Blu-Ray player yet, or even an up-converting player, but standard def DVDs are quite good. The THX picture setting seems to be just about right for most mo …"  Read Full Review »
The Boss in Hi Def
The Boss in Hi Def
Feb 2 2009
IBeachBoy
Monticello, IN
I am:
  • Enthusiast
Reviewed at:
Great Pruduct Greater Buy
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home
  • Movies
"The quality of the picture & sound is fantastic. We were able to set it up within a very short time & no, we are Not technicians. There is no glare fron the sunlight on the screen. Mainly used for sports & movies. Biggest problem is remembering which control button controls what.. "
Taken with Nikon camer also bought from Adorama !
Jan 17 2009
Ken & Jo W.
Fond du Lac, WI
I am:
  • Enthusiast
Reviewed at:
Price: $1,499.99
[6 of 6 customers found this review helpful]
Awsome!
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
  • THX Cert
    Cons
  • None
    Best Uses
  • Movies
"This is a great Plasma. The design is very minimal and simple with only one button one the front. The speakers are hidden on the bottom and fire downward so they do not take up any space.
The picture is great with deep blacks and a very clear overall image. I'd say it's on the same level with t …"  Read Full Review »
 Report Abuse  (6)  (0)  0 comments
May 22 2008
Shmoo
Washington DC
I am:
  • Gearhead
  • Professional
Reviewed at:
Price: $1,784.10
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$1,089.00
$1,499.99
$1,499.99
BizRate Rating Outstanding 9.4
$1,784.10
5% off orders at Abt.com
Out Of Stock
$899.96
$1.99 Shipping On Orders Over $100 at TigerDirect
$899.96
$1.99 Shipping on Orders Over $75
$1,288.99
$1,329.18
$1,349.99
BizRate Rating Outstanding 9.6
$1,379.95
No Tax Outside NY
$1,388.98
$1,449.99
15% Off A Single Item at DicksSportingGoods!
$1,491.95
BizRate Rating Outstanding 9.0
$1,516.32
$1,551.09
Shop CameraWorld with FREE Shipping/No Sales Tax!
$1,551.09
Shop WolfCamera with FREE Shipping & No Sales Tax!
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
