Panasonic TH-50PH9UK 50" Plasma Display
4.6
based on 5 reviews
Ratings Distribution
5 star
3
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.6
More Images
Pros
  • Great picture quality (4)
  • Attractive design (3)
  • Simple controls (2)
  • Fast setup (1)
See less See more
Cons
  • Bad interface (2)
  • Difficult to set up (1)
Best Uses
  • Home (4)
  • Movies (4)
  • Video (3)
  • Office (2)
  • Professional (2)
Provided by Beach Audio
A 50" plasma display with the size and the exceptional image quality that is equally at home in the broadcast studio, a corporate boardroom, or on the set.Panasonic combines the very best in image quality, customization and size selection in its new Professional Series plasma family. With industry-leading 16-bit processing, 3,072 shades of gradation and an up to 10,000:1 contrast ratio, the TH-50PH9UK provides significant image quality improvements to produce an unforgettable visual experience. With Panasonics multi-function input slot system, this large-screen panel offers seamless integration in virtually any AV, PC or interactive environment, so it can be used in the widest range of vertical or horizontal display applications. This 50" panel is more light weight and energy efficient, and its ultra-stylish design looks ultra sleek even when the panels turned off.The TH-50PH9UK comes standard with PC Input, Audio Input (for PC), Serial Control (RS-232C) Input, BNC Component Video/RGB Input and Audio Input, BNC Composite Video Input, S-Video Input, and Audio Input (for Video). There is an available slot for an optional terminal board. Or, you can remove the standard boards and mount up to three optional boards.
Key Features
Industrys leading 16-bit processing to produces 3,072 steps of gradation
Up to 10,000:1 contrast level with new Real Black Creation technology
New Deep Black Filter achieves highest contrast ratio when viewing in brightly-lit rooms
Plug-in architecture allows the addition of multi-function terminal boards for added connectivity and functionality
Outstanding 60,000-hour service life
Newly-developed phosphor significantly resists burn-in as effectively as CRT displays
New Advanced Dual Picture and built-in image enlarging function enhances multi-screen systems
Expanded configurations for multi-screen displays and the ability to enlarge an image up to 4X vertically and horizontally
1366 x 768 resolution
Supports VGA, SVGA and XGA (uncompressed); SXGA, and UXGA (compressed) PC signal compatibility
Supports 1080/60i, 1080/50i, 1080/24p, 1080/24sf, 1080/25p, 1080/30p, 720/60p, 720/50p, 480/60p, 480/60i signal compatibility
From an on-board PC to CAT5 to HD-SDI, Panasonic offers the widest array of optional boards to customize a panel to meet practically any application
The benefits of the Plasma Concierge program including priority service scheduling and an exclusive toll-free hot line
Key Specifications
Screen Size (inches) 50
Aspect Ratio 16:9
Native Resolution 1366 x 768
Contrast Ratio Up to 10000:1
Viewing Angle (degrees) More than 160
New Real Black Creation Yes
Dimensions (H x W x D) 28.5 x 47.6 x 3.7
Weight 81.6 lbs
Specification Description
Model PBTTH50PF9UK, PBTTH50PH9UK, TH-50PF9UK, TH-50PH9UK
UPC 037988241170
Aspect Ratio 16:9
Contrast Ratio 10000:1
Contrast Ratio 5000:1
contrast ratio 3000:1
Resolution 1366x768
Resolution 1920 x 1080
resolution 1366x768
Screen Size 50 Inch
Screen Size 50"
screen size 50 inch
Widescreen Yes 16:9
widescreen yes 16:9
Panasonic TH-50PH9UK 50" Plasma Display Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: TH-50PH9UK 50" Plasma Display
See all eBay results
  at eBay.com
Product Reviews
Last update: Jun 26, 2007
Panasonic TH-50PH9UK 50" Plasma Display Reviews
Displaying 1 - 5 of 5 Reviews
Show
Sort by
Unrivaled Picture, No Consumer Features
4.0
    Pros
  • Attractive Design
  • Great Picture
    Cons
  • Bad Interface
  • Difficult to Setup
    Best Uses
  • Home
  • Movies
  • Video
"This product is the much bally-hooed TV that put Panasonic on the Plasma map. With top mentions in Consumer Reports, it's a tough TV to beat. But beware, it's an industrial monitor, not a TV. It will lack many of the features that are now expected on a plasma, and it's not the easiest TV on Earth to …"  Read Full Review »
Was this Plasma TV review on the Panasonic TH-50PH9UK 50" Plasma Display helpful to you?
Feb 19 2007
Jammer
Chicago
Reviewed at:
"Great ...
4.0
"Great professional-quality 50"" HD Monitor at a really great price.
Pros: Color is outstanding. Black level is inky black. Non-HD DVD's, shown via the separately-purchased HDMI input module, are amazing. I love the way each input has separate memory for settings. (I use HDMI, Component, and VGA inp …"  Read Full Review »
Nov 21 2006
Kenny O
Undisclosed
Reviewed at:
This is an Excellent DEAL!!!
5.0
    Pros
  • Great Picture
    Cons
  • None
    Best Uses
  • Home
  • Movies
  • Office
  • Professional
  • Video
"This is an excellent looking plasma. Great specs. At this price with the free mount and 5 year warranty , WHAT A DEAL!!! You cannot ask for anything more. "
Feb 9 2007
hither
San diego, Ca
Reviewed at:
picture quality
5.0
    Pros
  • Attractive Design
  • Great Picture
  • Simple Controls
    Cons
  • Bad Interface
    Best Uses
  • Home
  • Movies
  • Video
"great picture quality and 5yr plan with wall mount cant beat that. "
Jun 26 2007
paul
New York
I am:
  • Tech Savvy
Reviewed at:
Great Buy
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Movies
  • Office
  • Professional
"Best contrast and definition I have seen. "
Feb 9 2007
duede
tampa, Fl
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
