Panasonic TH-37PH10UK 37" Plasma Display
#46
4.3
based on 6 reviews
Ratings Distribution
5 star
2
4 star
4
3 star
0
2 star
0
1 star
0
Category Average
4.6
Low Price:
$699.00 at B&H Photo Video
 Trusted:
$749.95 at pcRUSH
Find it at Amazon
$699.00 - $749.95
from 2 stores
Pros
  • Great picture quality (5)
  • Simple controls (5)
  • Attractive design (4)
  • Fast setup (4)
  • Easy to use (1)
  • High quality (1)
  • Lots of features (1)
See less See more
Cons
  • No speakers or stand (1)
Best Uses
  • Movies (3)
  • Professional (3)
  • Home (2)
  • Office (2)
  • Video (2)
  • Computer monitor (1)
  • Home movies (1)
Provided by photoalley.com
Do you have a limited amount of space? This 37" plasma is perfect size for delivering high quality video and messaging with impact.
With an up to 10,000:1 contrast ratio and industry-leading 16-bit processing, the TH-37PH10UK incorporates significant image quality improvements to produce an unforgettable visual experience. With Panasonic's multi-function input slot system, this 37" panel offers seamless integration in virtually any AV, PC or interactive environment, so it can be used in the widest range of vertical or horizontal display applications. This space-saving panel is more light weight and energy efficient, and its ultra-stylish design looks ultra sleek even when the panel's turned off. The TH-37PH9UK is currently the smallest size plasma display available. Panasonic combines the very best in image quality, customization and size selection in its new Professional Series plasma family.
The TH-37PH10UK comes standard with PC Input, Audio Input (for PC), Serial Control (RS-232C) Input, BNC Component Video/RGB Input and Audio Input, BNC Composite Video Input, S-Video Input, and Audio Input (for Video). You can remove the standard boards and mount one or two optional boards.
  • Industry's leading 16-bit processing produces 3,072 steps of gradation
  • Up to 10,000:1 contrast level with new Real Black Creation technology
  • New Deep Black Filter achieve highest contrast ratio when viewing in brightly-lit rooms
  • Plug-in architecture allows the addition of multi-function terminal boards for added connectivity and functionality
  • Outstanding 60,000-hour service life
  • Newly-developed phosphor significantly resists burn-in as effectively as CRT displays
  • New Advanced Dual Picture mode and built-in image enlarging function enhances multi-screen systems
  • Expanded configurations for multi-screen displays and the ability to enlarge an image up to 4X vertically and horizontally
  • 1024 x 720 resolution
  • Supports VGA and SVGA (uncompressed); XGA, SXGA, and UXGA (compressed) PC signal compatibility
  • Supports 1080/60i, 1080/50i, 1080/24p, 1080/24sf, 1080/25p, 1080/30p, 720/60p, 720/50p, 480/60p, 480/60i signal compatibility
  • From an on-board PC to CAT5 to HD-SDI, Panasonic offers the widest array of optional boards to customize a panel to meet practically any application
  • Specification Description
    Model TH-37PH10UK, TH37PH10UK
    UPC 037988241583
    Aspect Ratio 16:9
    Ports 1 x BNC Video In
    Resolution 1024x720
    Screen Size 37"
    Standard Warranty 1 Year(s) Limited
    Panasonic TH-37PH10UK 37" Plasma Display Questions
    Questions and Answers
    Where to Buy
    $699.00
    No Tax Outside NY ends 09/09/15
    BizRate Rating Outstanding 9.7
    $749.95
    Product Reviews
    Last update: Aug 21, 2008
    Panasonic TH-37PH10UK 37" Plasma Display Reviews
    Displaying 1 - 5 of 6 Reviews
    Show
    Sort by
    Best 37
    5.0
      Pros
    • Attractive Design
    • Fast Setup
    • Great Picture
    • Simple Controls
      Cons
    • None so far
      Best Uses
    • Computer Monitor
    • Home
    • Movies
    • Video
    "This product is real gud one for the budget pricing. You find Sony, sharp and that too 32 inch screen around the same price. But panasonic leads both in HDTV with wider screens. Its really simple to setup and watch, I use it as a PC monitor and i have been watching all movies in regular DVDs and the …"  Read Full Review »
    Was this Plasma TV review on the Panasonic TH-37PH10UK 37" Plasma Display helpful to you?
    Jul 23 2008
    Ram
    Washington DC
    I am:
    • Practical
    Reviewed at:
    Great TV!!!!!
    4.0
      Pros
    • Attractive Design
    • Fast Setup
    • Great Picture
    • Simple Controls
      Cons
      Best Uses
    • Home
    • Movies
    • Office
    • Professional
    "I also have a 58 in Panasonic plasma, and the picture on the 37 in is just as good as the bigger set. I got it for a bargain price of [$] on Ritzcamera. I have a 32 in Samsung LCD, the Panasonic picture is much better than the Samsung. Definitely a good buy & very reliable.John "
    Aug 21 2008
    gambler
    dfw
    I am:
    • Tech Savvy
    Reviewed at:
    [1 of 1 customers found this review helpful]
    Best HD Picture available
    5.0
      Pros
    • Easy To Use
    • Lots Of Features
    • Professional Quality
      Cons
    • None
      Best Uses
    • Home Movies
    "The picture quaity is second to none and setup is a breeze. I have always preferred the life like look of th picture on the Panasonic displays; this set does not disappoint.
    I am happy that I was able to avoid payign for a tuner and audio deices built into the system - who int he heck needs thos …"  Read Full Review »
     Report Abuse  (1)  (0)  0 comments
    May 4 2008
    Nick
    Everett WA
    I am:
    • Hobbyist
    Reviewed at:
    Price: $699.00
    Excellent Display for the price
    4.0
      Pros
    • Attractive Design
    • Fast Setup
    • Great Picture
    • Simple Controls
      Cons
    • None
      Best Uses
    • Movies
    • Professional
    • Video
    "The smallest Plasma I could find - 37". Panasonic quality, easy to set up (doesn't come with stand, speakers or tuner) and designed for professionals (BNC terminal boards). Rich, deep blacks, excellent color, made to last. Great price! "
    Aug 19 2008
    Video Pro
    Detroit, MI
    I am:
    • Professional
    Reviewed at:
    great picture--no stand with it,nospeake
    4.0
      Pros
    • Great Picture
    • Simple Controls
      Cons
    • None
      Best Uses
    • None
    "As other TVs come with stand and speakers, it seemed misleading not to mention this was a component rather than a functional system.
    Love the picture quality. "
    Aug 19 2008
    larry
    Oregon
    I am:
    • Practical
    Reviewed at:
    pages: 1 2 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
