Panasonic TC-P50X1 Viera 50-Inch Class Plasma Flat Panel HDTV
#72
4.7
based on 118 reviews
Ratings Distribution
5 star
95
4 star
16
3 star
2
2 star
1
1 star
4
Category Average
4.6
Low Price:
$649.00 at Dell
 Trusted:
$819.95 at B&H Photo Video
$726.52 at pcRUSH
see all stores
$649.00 - $838.18
from 16 stores
More Images
Pros
  • Attractive design (33)
  • Fast setup (30)
  • Great picture quality (28)
  • Simple controls (27)
  • Bright image (6)
  • Good connection options (6)
  • High resolution (6)
  • Reduced glare (5)
  • Easy to use (1)
  • Good audioalthough i ju (1)
See less See more
Cons
  • Lacked usb port (1)
  • Only toslink audio output (1)
  • Poor sound quality (1)
  • Sound quality is fair (1)
  • Terrible manual (1)
Best Uses
  • Home (29)
  • Movies (17)
  • Wall mounting (9)
  • Home theater (6)
  • Don't buy for movies (1)
  • Office (1)
  • Professional (1)
Provided by RitzCamera.com
The new X1 Series Plasma HDTVs are ideal for sports, movies and gaming, with crisp, focused images during fast-moving scenes.
Watch Fast-Moving Scenes with Clear, Vivid Resolution
The 600Hz Sub-field Drive produces crisp, focused images for sports, dramatic action, and all other fast-moving scenes. Your full-HD movies and games never looked sharper.
Share Your Digital Photos on the Big Screen
VIERA Image Viewer provides a better way to share your digital photos. Just pop your SD memory card into the handy slot, and instantly display your digital photos for friends and family.
Network Your AV Devices, Quickly and Easily
With VIERA Link, you can control your compatible Panasonic DVD recorder, Blu-ray Disc, player, home theater sound system and HD camcorder, all with a single remote and helpful on-screen menus.
  • 720p Resolution
  • Contrast Ratio: 30,000:1 Native; Infinite Black Panel
  • 720 Lines of Moving Picture Resolution
  • 600Hz Sub-field Drive
  • VIERA Image Viewer
  • VIERA Link
  • AR (Anti-Reflective) Filter
  • Game Mode
  • 3 HDMI Inputs
  • 100,000 Hour Panel Life
  • Specification Description
    Model PAN TCP50X1, PANTCP50X1, PanasonicTCP50X1, TC-P50X1
    UPC 037988242276
    color null
    Contrast Ratio 30000:1
    Dynamic Contrast Ratio 2000000:1
    HDTV Capable HD Tuner is included
    Resolution 1024 x 768
    Screen Format 16:9 Widescreen TV Imaging
    Screen Size 50"
    Screen Size 50" to 60"
    Screen Size (Inches/Diagonal) 50
    Select Plasma Units
    size null
    sku 157571
    sku 162152
    skuprice 1099.9500
    skuprice 899.9900
    style PANTCP50X1
    style PanasonicTCP50X1
    taxable Y
    Technology HDTV
    TV Manufacturer’s Warranty (Labor) 1 Year
    TV Manufacturer’s Warranty (Parts) 1 Year
    Panasonic TC-P50X1 Viera 50-Inch Class Plasma Flat Panel HDTV Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Nov 12, 2009
    Panasonic TC-P50X1 Viera 50-Inch Class Plasma Flat Panel HDTV Reviews
    Most helpful positive review
    [6 of 6 customers found this review helpful]
    Most helpful negative review
    4.0
    Great TV
    "First HD TV, and very happy with it so far. Used in large room as primary TV for house. Excellant HD picture, great with the games, and standard def channels even look good on this set (from greater than about 5 feet away). Set up was very easy, and once I got calabrations set (go to [@] or other site to get recommendations)I was blown away with the quality of picture. I'm still grinning at the fact that I ha..." Read Full Review »
    Mar 01, 2009 by TN Jed
    See more positive Panasonic TC-P50X1 Viera 50-Inch Class Plasma Flat Panel HDTV reviews
    1.0
    Think twice before you by Panasonic
    "I thought I did adequate research before deciding on this Plasma TV. I was aware of image retention or "burn-in", but had read that newer Plasma TVs were less prone to it than older sets. I downloaded and read Panasonics manual before purchasing the TV. The manual raised more questions than it answered, so I called Panasonic tech support on numerous occasions. I was never told that watching wide screen movie..." Read Full Review »
    May 22, 2009 by Never Panasonic Again
    See more negative Panasonic TC-P50X1 Viera 50-Inch Class Plasma Flat Panel HDTV reviews
    Displaying 1 - 5 of 118 Reviews
    Show
    Sort by
    Great TV
    4.0
      Pros
    • Attractive Design
    • Bright Image
    • Fast Setup
    • Good Connection Options
    • Good Resolution
    • More »
      Cons
    • Poor Sound
      Best Uses
    • Home
    • Home Theater
    • Movies
    "First HD TV, and very happy with it so far. Used in large room as primary TV for house. Excellant HD picture, great with the games, and standard def channels even look good on this set (from greater than about 5 feet away). Set up was very easy, and once I got calabrations set (go to [@] or other …"  Read Full Review »
    Was this Plasma TV review on the Panasonic TC-P50X1 Viera 50-Inch Class Plasma Flat Panel HDTV helpful to you?
     Report Abuse  (6)  (0)  0 comments
    Mar 1 2009
    TN Jed
    Hills of TN
    I am:
    • Casual User
    Reviewed at:
    Price: $838.18
    [10 of 10 customers found this review helpful]
    New TC-P50X1
    5.0
    "After much researching about 720 vs. 1080 I decided to try this set myself. Even ask the Sear's salesman if I was not satisfied if I could exchange it for a 1080. Believe me, I have NO intentions of exchanging it. Unless you are going to set closer than 5 feet there will not be a problem with this s …"  Read Full Review »
     Report Abuse  (10)  (0)  0 comments
    Mar 21 2009
    Heavy
    Pennsylvania
    Reviewed at:
    Price: $799.99
    Your search ends here! BUY THIS TV
    5.0
    "I too have looked and researched the heck out of the lcd vs plasma, 720 vs 1080 debate. I decided on a 720 plasma, and am I ever glad that I did! For the price of this set, you can't possibly go wrong. The quality of picture is outstanding. The sound is mind blowing. We did get additional sound syst …"  Read Full Review »
    Mar 31 2009
    1234more
    Burton, Michigan
    Reviewed at:
    Price: $799.99
    Can't do better for the price
    5.0
      Pros
    • Attractive Design
    • Great Picture
    • Simple Controls
      Cons
    • None
      Best Uses
    • Home
    • Movies
    • Wall Mounting
    "Excellent color and dark scene details for an extremely affordable price. Looks pretty on my wall too. "
    Nov 10 2009
    TechRider
    Cerritos, CA
    I am:
    • Casual User
    Reviewed at:
    Price: $819.95
    [1 of 1 customers found this review helpful]
    HDTV Experience
    5.0
    "Review
    It has been 4 years since my last TV, a flat screen CRT with component video. Wow! After getting a feel for the LCD/Plasma markets and watching prices fall for years. I finally decided that the market was at a point where prices had fallen substantially for most TVs, the technologies on the …"  Read Full Review »
     Report Abuse  (1)  (0)  0 comments
    Mar 3 2009
    LeM22
    Stephens City, VA
    Reviewed at:
    Price: $799.99
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
