Panasonic TC-32LX600 32" 16:9 HDTV LCD TV
5.0
based on 2 reviews
from
Ratings Distribution
5 star
2
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.4
More Images
Pros
  • Attractive design (1)
  • Fast setup (1)
  • Great picture quality (1)
  • Simple controls (1)
  • Wide viewing angle (1)
See less See more
Best Uses
  • Home (1)
  • Movies (1)
  • Video (1)
Provided by Beach Audio
TFT Active Matrix technology, 16:9 Aspect Ratio, 1366x768 Resolution, 8ms Response Time, 500 cd/m2 Brightness, 3000:1 Contrast Ratio, HDTV-Capable, with 2 HDMI Interfaces and 3-D Color Management
In Plane Switching (IPS) Plus: Assures Enhanced Viewing, Even at an Angle
The wide viewing angle provided by the In Plane Switching (IPS) LCD panel lets viewers enjoy an extraordinary picture from the left, right, above or below. This level of performance is further enhanced by IPS Plus technology in select models. Colors are clear and vivid even when the screen is viewed from a wide angle. With Panasonic, it?s easy for everyone in the room to enjoy the show.
Active Light Control System and Active Contrast/Gamma Control System
The Panasonic LCD AI incorporates two new technologies: the Active Light Control System and Active Contrast/Gamma Control System that adjust backlight brightness and contrast so that each scene has fantastic contrast and detail. Flowers look vivid and natural, while landscapes are remarkably bright and true to life.
3D Color Management: Vivid Mode
The 3D color management system helps to achieve precise control based on the color differences and brightness levels that are present in a picture. This remarkable technology independently detects color, brightness and luminosity levels in order to produce amazing quality in each. This fine degree of control helps to produce truly expressive images with colors that are beautifully reproduced with exceptional vibrancy.
A Single Cable Carries High-Quality Digital Audio and Video
If you have even a moderately complicated home theater setup, you probably have a pile of tangled cables on the floor behind it. Imagine replacing all those cables with a single cable that carries both digital video and audio at the same time. With the new HDMI standard, that's exactly what you get. The HDMI connectors on this TV accept high-quality digital video and audio via one thin cable, allowing you to run one cable from the source to the TV.
A Cinema-Style Viewing Experience At Home
This widescreen TV features a width-to-height ratio similar to movie theater screens, providing a theater-like experience at home. View HDTV broadcasts and widescreen DVDs the way they were meant to be seen.
Crisp, Lifelike Details
HDTV broadcasts and DVDs offer more detail and better color than analog broadcasts, and it takes a high-resolution display to deliver all that picture information. The high pixel count of this LCD TV provides fine detail for outstanding HDTV reproduction. More pixels also translate into less stair-stepping artifacts; curved and diagonal edges look smooth and natural.
High-Quality Fast Motion Imagery
Fast pixel response time is essential to accurate image reproduction on LCD displays. If the response time is too long, fast motion seen during sports broadcasts and action movies can cause blurring. This LCD TV features an impressive 8ms response speed, helping to ensure excellent detail and smooth motion during high-speed scene transitions.
Great Image Quality at Wide Angles
Some LCD displays require the viewer to sit within a very small sweet spot for good image quality. Move too far to the left or right and image quality drops off sharply. This LCD TV features an extremely wide viewing angle of 178, so whether you're right in front of the TV or sitting off to the side, you'll still get great image quality.
Progressive Scanning for Smooth, Rock Solid Images
Traditional analog TVs display video in an interlaced format that splits each film frame into two separate fields, resulting in visible scan lines and other image artifacts. A progressive scan display shows each film frame as one solid frame, helping to create a stable, solid image free of interlaced artifacts.
Panasonic TC-32LX600 32" 16:9 HDTV LCD TV Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: TC-32LX600 32" 16:9 HDTV LCD TV
See all eBay results
  at eBay.com
Product Reviews
Last update: Mar 7, 2007
Panasonic TC-32LX600 32" 16:9 HDTV LCD TV Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
great product at a great price
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Reduced Glare
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Movies
  • Video
"we were almost sold on the Samsung "DLP" but after reading about all the horror stories concerning "DLP" we decided on this TV because it was highly rated by various testing services not only for picture quality but also for reliability. "
Was this LCD TV review on the Panasonic TC-32LX600 32" 16:9 HDTV LCD TV helpful to you?
 Report Abuse  (1)  (0)  0 comments
Mar 7 2007
PaPa Bear
Tampa Bay, Fl.
Reviewed at:
Great results
5.0
"I have purchased this TV 3 weeks ago and I am truly impressed with it.The vivid mode is great with the kid's Gamecube. I get 21 perfectly clear HD digital channels with my UHF antenna pointed toward Philadelphia.It takes a little bit more time to change channels than I am used to but other than tha …"  Read Full Review »
Feb 13 2007
MAYP
York, PA
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
