Panasonic SH-FX67 Wireless Receiver Module
#191
4.3
based on 9 reviews
from $139.00
Ratings Distribution
5 star
3
4 star
6
3 star
0
2 star
0
1 star
0
Category Average
4.4
$139.00 at Rainbow Appliance
Find it at Amazon
Find it at Ebay
More Images
Pros
  • Great sound quality (9)
  • Accurate controls (6)
  • Easy setup (6)
  • Durable (4)
  • Good power output (4)
  • Easy to connect (1)
See less See more
Cons
  • Difficult to set up (1)
Best Uses
  • Home theater (8)
  • Basic systems (2)
  • Large rooms (2)
  • Smaller rooms / apartments (1)
Provided by B&H Photo Video
The Panasonic SH-FX67 Wireless Receiver Module is an ingenious way to connect the rear surround sound speakers to your home theater system without making unnecessary holes in your walls or floors. This kit eliminates the need to run messy wiring from the back of your receiver to the rear speakers located across the room. It's compatible with the SC-PT660, SC-PT760 SC-PT960, and SC-BT100 Home Theater Systems. It features digital wireless technology capable of receiving crystal clear audio within a 33' range. Just insert the Digital Transmitter (SH-FX67T) into your (compatible) home theater unit, and connect two rear speakers to the 2-channel wireless receiver module, it's that simple. If you want to surround yourself with sound - not wires - with a unified, stylish, and easy-to-set-up wireless speaker kit, look no further. You won't find a better solution than the Panasonic SH-FX67.
Panasonic SH-FX67 Wireless Receiver Module Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jan 15, 2009
Panasonic SH-FX67 Wireless Receiver Module Reviews
Displaying 1 - 5 of 9 Reviews
Show
Sort by
[2 of 2 customers found this review helpful]
Great Basic Wireless Rear Setup
4.0
    Pros
  • Accurate Controls
  • Clean Sound
    Cons
  • None
    Best Uses
  • Basic Systems
  • Home Theater
  • Smaller Rooms
"I live on the ground floor of an apartment building on a concrete slab, so running wires under the floor wasn't an option. I didn't want to spend a ton of money either, so for the price this was a great solution for me. The sound is adequate, and I like using the rear wireless when I am playing vi …"  Read Full Review »
Was this Speaker Stand & Mount review on the Panasonic SH-FX67 Wireless Receiver Module helpful to you?
 Report Abuse  (2)  (0)  0 comments
Aug 5 2008
robinaleea
Toledo, OH
I am:
  • Practical
Reviewed at:
Not really wireless but works well
4.0
    Pros
  • Clean Sound
    Cons
  • Difficult To Set Up
    Best Uses
  • Home Theater
  • Larger Rooms
"I will start by stating I used this as a 2nd receiver to get 7.1 sound. Once set-up it works awesome and you can forget about it. If you use it as the only wireless set it is no problem, plug it in, turn it on and it works. If you use 2 to get full 7.1 sound even though you set the switch on the …"  Read Full Review »
Jun 25 2008
skydiver
Ardmore,OK
I am:
  • Practical
Reviewed at:
[1 of 1 customers found this review helpful]
Great product but a little misleading
4.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • None
    Best Uses
  • Basic Systems
"It works great, however, we thought "wireless" speakers would mean no cords attached to each individual speaker. However, the "box" we bought is wireless and the two speakers have to be attached to it via wires. Thus, the speakers still have wires attached, but they don't have to go all the way ac …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jul 2 2008
Hubbell
Brooklyn, MI
I am:
  • Tech Savvy
Reviewed at:
Great Product
4.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • None
    Best Uses
  • Home Theater
  • Larger Rooms
"very good product, the only reason why it got a 4 is because it is technically wireless, it does essentially provide wireless support but does involve hooking up wires in another location to speakers for the system, also remember that you will need to insert the transmitter in the receiver firmly to …"  Read Full Review »
Sep 18 2008
iceman
Lawrenceville, GA
I am:
  • Tech Savvy
Reviewed at:
Great Product--Easy to Install
5.0
    Pros
  • Clean Sound
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • Home Theater
"Didn't want to drill through carpet and floor and rec room ceiling to run wires. Going wireless with the back speakers is great. "
Jun 16 2008
Redfox Reiner
Algonquin, Illinois
I am:
  • Technically Challenged
Reviewed at:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
