Panasonic Panasonic® SC-PTX7 DVD 80GB Home Theater System
5.0
based on 1 review
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.1
$366.54 - $499.99
from 14 stores
More Images
Pros
  • Confusing / difficult controls (1)
  • Easy setup (1)
  • Great sound quality (1)
  • Interfaces well with tv (1)
  • Thundering bass (1)
See less See more
Best Uses
  • Living room (1)
  • Movies (1)
  • Smaller rooms / apartments (1)
  • Surround sound solution (1)
  • Television shows (1)
Provided by Buzzillions.com
Smart, Compact Style with All the Entertainment
This Jukebox Theater System is a perfect combination of design excellence and entertainment features you need in today's flat-panel TV age. It's designed to deliver great entertainment, but without all the cluttered look of many other home theater systems. There's no visible center speaker, because it's built into the right and left speakers - so all you see are the compact main unit and the right and left speakers.
Digital Age Jukebox Entertainment
Thanks to a high-capacity internal hard drive, you can store hours of music recorded from CDs, MP3 and WMA files from your PC, FM and AM radio, and other sources. For easy access, titles and artist names are stored on the hard drive, and Music Shuffle categorizes music into four different moods. Just select the category that fits your mood, and automatically hear the right songs every time.
Gripping Sound for Movies and Music
There are no bad seats in your home theater, with the Panasonic Twin Center System. Because the center speaker is integrated into the right and left speakers, dialogue seems to pour right out of the screen, and sound has a more natural presence than with conventional center speaker setup. Dolby virtual speaker technology gives high-quality sound and a lifelike surround effect. Plus MP3 and WMA music files take on new richness and depth, with built-in digital re-mastering technology that restores high-frequency data.
A Better Way to Fill Your Home with Music
There's no need to keep your music in the living room. Just add the SH-FX85 Wireless Multi-Room Speaker Kit (sold separately) and your home theater can serve up music from its built-in hard drive, CDs, AM/FM radio, and other sources, for music in your bedroom, in the den, or even in the garage. You'll have the ability to play, stop and skip selections in up to three additional rooms. Add the included SH-PD10 Universal Dock for iPod?, and play, control and recharge your iPod directly through your home theater system.
  • Hard Disk Drive for Storing Music from Analog & Digital Sources
  • Easy Connection with 3.1-Ch System
  • EZ Sync HDAVI Control with HDMI Connection
  • Included Panasonic Universal Dock for iPod Playback & Recharging
  • Expandable to Multi-Room Wireless Audio with Optional SH-FX85 Wireless Kit
  • Specification Description
    Model SC-PTX7, SCPTX7
    UPC 037988254873
    # of AM/FM Tuner Presets 30
    AM/FM Radio Yes
    Antenna Type FM wire antennaAM loop antenna
    Audio Input Optical
    Battery Type Remote
    Benefits Video upconversion via the HDMI interface scales standard DVD video output to up to 1080pBuilt-in 80GB hard drive stores over 1,000 h
    Capacity UOM mAh
    Channels 3.1 Channels
    Chemistry Alkaline
    Connections HMDI out (1)Component out (1)Composite video out (1)Analog audio out (1)Optical audio in (1)Optic
    Connectivity Technology Wired
    Country Of Origin Singapore
    Description Header Performance and versatility in one compact package.
    Detachable grille Yes
    Display Catalog Number 55031552
    Enclosure Color Black
    End Product Indicator Yes
    Equalizer Yes
    Equalizer Factory Preset Qty 5 Presets
    Humidity Range Operating 35%~80%
    Included in the Box Panasonic® SC-PTX7 recieverFront speakers (2)SubwooferRemote control"AA" batteries (2)FM wire
    Magnetic Shield Yes
    Manufacturer Labor Warranty 12
    Manufacturer Part Number SC-PTX7
    Manufacturer Parts Warranty 12
    MAP Price 0.0
    Max Operating Temperature 104 Fahrenheit
    Min Operating Temperature 32 Fahrenheit
    Model SC-PTX7
    Operating Temperature UOM ° F
    Output Power / Total 300 watts
    Power Consumption Operational 90.0
    Product Disclaimer ¹Song capacity based on 4 minutes per song and 128kbps AAC encoding; actual capacity varies by content.²requires XM subscription and opt
    Product Type DVD systems
    Size AA
    Speaker(s) Front: 50W x 2 (1kHz, 8 ohms, 10% THD)Center: 50W x 2 (1kHz, 8 ohms, 10% THD)Subwoofer: 100W (100Hz, 4 ohms, 10% THD)
    Speakers Included 3 Speakers
    Supported Languages English, Spanish, French
    Surround Sound Effects Dolby Digital®, DTS® and Dolby Pro Logic
    Technology IR
    Total Harmonic Distortion 10 %
    Type LED, On-Screen
    Voltage 1.5
    Voltage UOM Volts
    Panasonic Panasonic® SC-PTX7 DVD 80GB Home Theater System Questions
    Questions and Answers
    Where to Buy
    $499.99
    $10 Off Orders Of Orders Over $85 + Free Shipping
    $376.91
    $366.54
    Show all 14 stores
    Product Reviews
    Last update: Oct 23, 2009
    Panasonic Panasonic® SC-PTX7 DVD 80GB Home Theater System Reviews
    Displaying 1 - 1 of 1 Reviews
    Show
    Sort by
    As Advertised!!!!
    5.0
      Pros
    • Clear Sound
    • Easy To Setup
    • Interfaces Well With TV
    • Intuitive Controls
    • Thundering Bass
      Cons
    • None
      Best Uses
    • Living Room
    • Movies
    • Smaller Rooms
    • Surround Sound Solution
    • Television Shows
    "Delivered exactly what I wanted. Only 3 speakers and getting the job done!!! setup was simple. I have it connected to my HD LCD TV using the hdmi port. I also have it connected to my HD DVR Cable box using the digital fiber optic port. Just a matter of pressing the input button on my TV remote to ge …"  Read Full Review »
    Was this Home Theater review on the Panasonic Panasonic® SC-PTX7 DVD 80GB Home Theater System helpful to you?
    Oct 23 2009
    Roberto
    Queens, NY
    I am:
    • Movie Enthusiast
    • Practical
    • Technically Challenged
    Reviewed at:
    Price: $499.99
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
