Panasonic KX-TG6411T DECT 6.0 Cordless Phone
4.3
based on 21 reviews
Ratings Distribution
5 star
24
4 star
17
3 star
3
2 star
3
1 star
1
Category Average
3.8
$33.00 - $64.99
from 12 stores
More Images
Pros
  • Easy setup (41)
  • Compact design (38)
  • Nice sound (37)
  • Comfortable handset (36)
  • Strong signal (35)
  • Nice features (33)
  • Good speakerphone (32)
  • Wide range (26)
  • Big lcd screen (1)
  • Easy to read number displ (1)
See less See more
Cons
  • Poor sound quality (5)
  • Lacks features (2)
  • Complex deletion (1)
  • Not durable (1)
  • Operates differently (1)
  • Poor battery life (1)
  • Size too compact (1)
Best Uses
  • Home use (37)
  • Everyday (30)
  • Office (11)
  • Outdoors (5)
  • Occasional use (1)
Provided by DollarRite
Panasonic KX-TG6411T DECT 6.0 Expandable Cordless Phone
Wont interfere with other wireless devices
- Call blocking ability
- Silent mode
- Expandable up to 6 handsets
- Up to 3-way conference capability
- Ringer ID
- Light-up Indicator with ringer/charge Alert
- Lighted handset keypad
- Call waiting caller ID
- Handset locator
- Handset intercom
- 5 Hour battery talk life 11 day standby time
- Black metallic
- DECT 6.0 Technology means less Interference
Engineered to work in 1.9GHz frequency our DECT 6.0 phones wont conflict with common wireless devices such as 2.4GHz routers wireless keyboards and mouses microwave ovens and other household items. And because its digital youll enjoy long range and clear sound while deterring eavesdropping.
- Call Block
Store the Caller ID info of any and all unwanted callers into your phones Call Block list so that you can eliminate future pesky calls from them. After their information is stored theyll get a busy signal if they call you again.
- Silent Mode
Now you can program each handset to ring or not at your discretion. For example before you go to sleep set the bedside handset to Silent Mode so that it wont ring for the duration of your slumber. In the meantime the handset in another room is unaffected and rings as usual.
- Expandable up to 6 Handsets
- Up to 3-way Conference Capability
- Ringer ID
- Light-up Indicator with Ringer/Charge Alert
- Lighted Handset Keypad
- Cal Waiting Caller ID
- Handset Locator
- Handset Intercom
Specification Description
Model KX-TG6411T, KXTG6411T
UPC 037988481705
Cordless Frequency 1.9GHz - DECT
Handsets Included 1
Maximum Number of Extensions 6 Handset Extension Capable
Telephone Lines 1
Panasonic KX-TG6411T DECT 6.0 Cordless Phone Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 17, 2009
Panasonic KX-TG6411T DECT 6.0 Cordless Phone Reviews
Most helpful positive review
Most helpful negative review
5.0
Good Value/Good Features
"This phone is excellent. I had to give away the last cordless phone I purchased because of the limited sound quality. I had trouble hearing at times. This Panasonic is truly a great value for the $. Panasonic has been recommended to me by friend, and I think their equipment is top shelf...." Read Full Review »
Nov 17, 2009 by relady
See more positive Panasonic KX-TG6411T DECT 6.0 Cordless Phone reviews
2.0
Not very durable
"So far not so good. I have gone through two of these phones so far. I had both of them on my shoulder talking on the phone when they slipped out and hit the desk. Not too far of a drop. Both phones same problem. After the fall they only work in speaker phone mode. I have less expensive cordless phones that are years old and have lived through my two year old. If you work in a padded office this phone is f..." Read Full Review »
Sep 18, 2009 by T in VA
See more negative Panasonic KX-TG6411T DECT 6.0 Cordless Phone reviews
Displaying 1 - 5 of 21 Reviews
Show
Sort by
Not very durable
2.0
    Pros
  • Comfortable Handset
  • Compact design
  • Easy To Set Up
  • Good Sound
  • Good Speakerphone
  • More »
    Cons
  • Not Durable
    Best Uses
  • Everyday Use
  • Home Use
  • Office Use
"So far not so good. I have gone through two of these phones so far. I had both of them on my shoulder talking on the phone when they slipped out and hit the desk. Not too far of a drop. Both phones same problem. After the fall they only work in speaker phone mode. I have less expensive cordles …"  Read Full Review »
Was this Cordless Telephone review on the Panasonic KX-TG6411T DECT 6.0 Cordless Phone helpful to you?
Sep 18 2009
T in VA
Annandale, VA
I am:
  • Value Oriented
Reviewed at:
Price: $39.00
Very nice cordless phone
5.0
    Pros
  • Compact design
  • Easy To Set Up
  • Good Sound
  • Good Speakerphone
  • More »
    Cons
  • None
    Best Uses
  • None
"Very satisfied with this Pana cordless. Handset is small but keypads is decent size and display is particularly nice. Display is quite bright and provides large high contrast letters/numbers. No need to put on one's glasses to read. Has all the features I want - clear speakerphone, memory, cal …"  Read Full Review »
Sep 3 2009
Geek
Fair Haven, NJ
I am:
  • Quality Oriented
Reviewed at:
Price: $39.00
Mostly Good.
4.0
    Pros
  • Easy To Set Up
  • Good Sound
  • Good Speakerphone
  • Nice Features
  • Strong Signal
  • More »
    Cons
  • Size too compact
    Best Uses
  • Everyday Use
  • Home Use
"One great feature is the ability to enter a number before actually calling it (like a cell phone does). The phonebook was easy to set up. The unit is a bit to compact to be able to hold it between shoulder and ear. And the number of ringer tones is limited. The voice and signal quality are what matt …"  Read Full Review »
Aug 25 2009
Not Jim the Runner
Birmingham, AL
I am:
  • Quality Oriented
Reviewed at:
Price: $39.00
A Great Value For The Price
5.0
    Pros
  • Compact design
  • Easy To Set Up
  • Good Sound
  • Nice Features
  • More »
    Cons
  • None
    Best Uses
  • Everyday Use
  • Home Use
"The audio quality is very clear anywhere in the house. The battery life before recharging is better than any other similar device I've owned. So far, I haven't experienced any negative issues and would recommend this item to anyone. Buying from Abt was a smooth [...] transaction and I have no hesit …"  Read Full Review »
Jun 22 2009
Qwerty
Citrus Heights, CA
I am:
  • Value Oriented
Reviewed at:
Price: $39.00
Nice phone!!
5.0
    Pros
  • Compact design
  • Easy To Set Up
  • Good Sound
  • Good Speakerphone
  • More »
    Cons
  • Poor Battery Life
    Best Uses
  • Everyday Use
  • Home Use
  • Office Use
"This phone is compact with a nice large screen. I have not had any interference from or with my cellular phone or wireless LAN. The range seems to be great and call quality is good. Battery life could be a bit better but over all one of the better wireless handsets I have owned. "
Jun 11 2009
Tom
Washington, DC
I am:
  • Quality Oriented
Reviewed at:
Price: $39.00
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
