Panasonic Extra Handset for DECT 6.0 Phone (Model #KX-TGA930T)
#21
4.1
based on 32 reviews
Ratings Distribution
5 star
17
4 star
15
3 star
1
2 star
1
1 star
4
Category Average
3.8
$33.99 - $59.00
from 12 stores
More Images
Pros
  • Nice features (25)
  • Strong signal (24)
  • Easy setup (23)
  • Comfortable handset (22)
  • Compact design (21)
  • Nice sound (21)
  • Good speakerphone (16)
  • Wide range (10)
  • Durable (6)
  • Big range (5)
See less See more
Cons
  • Poor sound quality (3)
  • Limited range (2)
  • Weak signal (2)
  • 'talk 'letters wear off (1)
  • Ans mach needs tone (1)
  • Creates static (1)
  • Difficult to set up (1)
  • Lacks features (1)
  • Manual hard to follow (1)
  • More handsets (1)
Best Uses
  • Everyday (25)
  • Home use (20)
  • Outdoors (9)
  • Office (4)
  • Large buildings (2)
  • Small spaces (2)
Provided by DollarRite
Panasonic KX-TGA930T DECT6.0 Accessory Handset for KX-TH1200 KX-TG6300 and KX-TG9300 series
- Panasonic DECT 6.0 Accessory handset- For use with the KX-TH1200 KX-TG6300 and KX-TG9300 series- Caller ID call waiting caller ID- 50 Caller ID memory- Talking caller ID- 50 Phonebook- Chain dial- 60 Channels- Auto booster- Call block- Light-up indicator/ringer LED- Menu operation- Night mode- LCD 1.4" with white backlight- Ringer LED- VM/message alert- 3 Tone 4 melody ringer- Ringer volume control- 5 Redial- Hold/mute/flash- Talk volume control- Speakerphone- Intercom handset to handset and base- Barge in- Any key answer- Built-in clock with alarm- Requires 2 Ni-MH AAA batteries included- 5 Hour talk battery life- 11 Day standby battery life- 7 Hour charge time- 2.5mm Headset jack- Belt clip- Navigator key- Handset locator- Wall mountable- Lighted handset keypad- Tone/pulse switchable- 1 Year manufacturers warranty- Titanium
Specification Description
Model KX-TGA930T, KXTGA930T, PANKXTGA930T
UPC 037988479566
Accessory Indicator Yes
Additional Functions 50-entry phonebook
Additional Functions Night mode, call block mode
Answering System Type All-digital
Audible Battery Alert Yes
Battery Type Product
Belt Clip Yes
Benefits DECT technology means less interference and higher sound qualityCall Waiting/Caller ID capability lets you see who's calling even whe
Benefits Expand your network of phones with this accessory handsetCompatible with Panasonic 6300 and 9300 series cordless phonesDECT
Built-in Clock Talking alarm clock
Call Hold Yes
Call Transfer Yes
Call Waiting Yes
Caller ID Yes
Caller ID Memory 50 Names and Numbers
Capacity UOM mAh
Chemistry Ni-MH
Conference Call Capability Yes
Connections RJ11 (1)Barrel input (1)Headset jack output (1)
Cordless Phone Standard DECT
Country Of Origin Malaysia
Description Header A handset for every room.
Description Header Expand your network.
Dialer Location Handset
Dialer Type Keypad
Digital Transmission Yes
Display Catalog Number 43-289
Display Catalog Number 55033890
Display Languages English, Spanish
Enclosure Color Black
Function Buttons Speakerphone, phonebook, menu, talk, tone, flash, redial, pause, off, navigator key, intercom, mute, clear, repeat, skip, stop, erase, volume, locator
Handset Locator Yes
Humidity Range Operating 20-80
Included in the Box Handset (1)Charger (1)User's guide
Indicators Battery level, answer on
Intercom Yes
Manufacturer Labor Warranty 12
Manufacturer Part Number KX-TGA930T
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Operating Temperature 104 Fahrenheit
Min Operating Temperature 41 Fahrenheit
Model KX-TGA930T
Multiline Operation Capability Single-line
New Date Wed Sep 17 00:00:00 CDT 2008
Number of Channels 60 Channels
Operating Temperature UOM ° F
Power Device Charger, rechargeable battery
Product Depth 1.9
Product Dimensions UOM inches
Product Height 5.7
Product Type DECT phones
Product Weight 0.5
Product Weight UOM pounds
Product Width 1.3
Rechargeable Yes
Recommended Use Panasonic DECT 6.0 handset
Recording Capacity 64 Minutes
Required to function SKU 4300253
Ring Tones 7 Tones
Ringer Control Yes
Size AAA
Speakerphone Yes
Supported Languages English
Transmission Band 1.9 GHz
Transmission Band UOM GHz
Type LCD
Voice Mail Capability Yes
Volume Control Yes
Walkie-Talkie Mode Yes
Panasonic Extra Handset for DECT 6.0 Phone (Model #KX-TGA930T) Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 23, 2009
Panasonic Extra Handset for DECT 6.0 Phone (Model #KX-TGA930T) Reviews
Most helpful positive review
Most helpful negative review
[0 of 1 customers found this review helpful]
4.0
I would buy again and again
"Could use a numbered lighted area for the number of calls received on the answering machine. Much better reception than previous similar product owned. Love the talking feature and special ring tones for specific people. Could use more than 99 programmable numbers since everyone now has at least 3 each (home, work, cell)...." Read Full Review »
Jun 03, 2008 by Cleo
See more positive Panasonic Extra Handset for DECT 6.0 Phone (Model #KX-TGA930T) reviews
3.0
Not so hot
"This is a really good phone. I bought 2 of them. One works very well but the other one drops calls within a few minutes. I think that there is something electrically wrong with the 2nd one if it's dropping calls. This phone model has been discontinued so I don't really know how to remedy the situation...." Read Full Review »
Aug 03, 2009 by Paperpiles
See more negative Panasonic Extra Handset for DECT 6.0 Phone (Model #KX-TGA930T) reviews
Displaying 1 - 5 of 32 Reviews
Show
Sort by
4.0
    Pros
  • Big Range
  • Comfortable Handset
  • Compact design
  • Durable
  • Easy To Set Up
  • More »
    Cons
  • Lacks Features
  • Not enough number storage
    Best Uses
  • Everyday Use
  • Outdoors
"Could use a numbered lighted area for the number of calls received on the answering machine. Much better reception than previous similar product owned. Love the talking feature and special ring tones for specific people. Could use more than 99 programmable numbers since everyone now has at least …"  Read Full Review »
Was this Cordless Telephone review on the Panasonic Extra Handset for DECT 6.0 Phone (Model #KX-TGA930T) helpful to you?
Jun 3 2008
Cleo
Newport News, VA
I am:
  • Quality Oriented
Reviewed at:
Price: $39.00
Unbelieveable Phone System
5.0
    Pros
  • Big Range
  • Compact design
  • Durable
  • Easy To Set Up
  • More »
    Cons
  • None
    Best Uses
  • Everyday Use
"We bought this as an extension add-on to our Panasonic master system (KX-TG9344T). Without going through a bunch of superlatives and descriptive adjectives, simply put: These are the greatest phones we have EVER owned. Do your homework consumers, and chances are that your quest for the perfect phon …"  Read Full Review »
Sep 6 2008
Calibration Guy
Moore, OK
I am:
  • Quality Oriented
Reviewed at:
Price: $39.00
Planning ahead.... Xtra handsets
5.0
"In store purchase of the two-handset KX-TH1212B product is disappointing only in that additional handsets are presently only available online.
A max of 4 additional handsets (six altogether) with the one base station work well together. Address book entries are all saved in the one base station fi …"  Read Full Review »
Jun 23 2008
Goody2013
New Jersey
Reviewed at:
Price: $33.99
Works well and is convient
4.0
    Pros
  • Compact design
  • Easy To Set Up
  • Good Sound
  • Good Speakerphone
  • More »
    Cons
  • None
    Best Uses
  • Everyday Use
"Much like a cell phone for at home use. Each phone in the set has all the functions, so you do not have to find a "master". The blinking message received light is far less intrusive that the "beep" the old system used.
.......B.F........... "
Oct 3 2009
Bernard
New Rochelle, NY
I am:
  • Value Oriented
Reviewed at:
Price: $34.88
Great phone
4.0
    Pros
  • Big Range
  • Compact design
  • Durable
  • Easy To Set Up
  • More »
    Cons
  • Poor Sound Quality
    Best Uses
  • Everyday Use
  • Large Buildings
  • Outdoors
  • Smaller Spaces
"The only things that is lacking on this phone is that the volume in the handsets are to low even when it is turned up to max. Everything else is great. Especially the talking caller ID in not only the base set but also the hand sets. I would highly recommend this phone to everyone. "
Jun 30 2008
xcopsc911
Evansville, In
I am:
  • Quality Oriented
Reviewed at:
Price: $39.00
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
