Panasonic Es8077s/svr Mens/triple Balde/pivot Hd/box Pk
4.2
based on 11 reviews
Ratings Distribution
5 star
6
4 star
3
3 star
1
2 star
0
1 star
1
Category Average
4.1
$99.99 at drugstore.com
Find it at Amazon
Find it at Ebay
$99.99
from 1 store
More Images
Pros
  • Consistent performance (5)
  • Easy to configure (5)
  • Durable (4)
  • Easy to use (2)
  • Versatile (2)
  • Easy setup (1)
  • Easy to clean (1)
  • Quality construction (1)
  • Smooth wet shave (1)
  • Travel (1)
See less See more
Cons
  • Cheap carryin bag (1)
  • Doesn't cut very well (1)
  • Doesn't give close shave (1)
  • Unreliable (1)
Best Uses
  • Travel (4)
  • Home (3)
  • Portable devices (2)
  • In the car (1)
  • Upgrade (1)
Provided by Beach Audio
  • Linear motor offers a frictionless, clean shave
  • HydraCleanTM Hygienic Cleaning System automatically cleans, dries and refreshes your shaver.
  • Shave Wet or Dry
  • Adjustable Pivot Action Head.
  • Automatic Worldwide Voltage Conversion
  • Specification Description
    Model 037988566068, ES8077S
    UPC 037988566068
    Directions It is recommended that you replace the outer foil at least every year and the inner blade at least every two years to maintain your shaver's cutting performance.
    Product Details HydraClean SystemPowerful hygienic cleaning system automatically cleans, dries and refreshes your shaver Pro-Curve®Linear Pivot Action Shaving System Panasonic introduces a safe and effective method to clean and charge your shaver. Automatic International Voltage Conversion Rinses Clean Fastest Shaver: 13,000 RpmOur proprietary Linear motor provides a constant stream of power, ensuring that whenever the razor is on, you get a frictionless 13,000 rpm shave. Sharpest* BladesConventional shavers only cut at 45-90° angles. Vortex gives you the sharpest blade angle at 30° for the ultimate in precision shaving. Adjustable Pivoting HeadPivoting head rocks both up and down and back and forth, following the contours of your face. Water Infused Cleaning System Triple Blade ShavingCenter slit blade cuts long and stray hairs. Foils on both sides even closer. Shaves Wet or DryGet an ultra-smooth shave every day, and the convenience of using the shaver wet or dry! Charging SystemCharges fully within an hour. The quick charge feature gives you power in five minutes. Pop-up TrimmerFull-width trimmer pops up to groom moustache and sideburns Attractive Slim DesignLightweight, ergonomic design is easy to hold and easy to use. Convenient Cleaning Solution CartridgesLong-lasting cleaning cartridges provide superior cleaning power keeping the blades fresh and always ready to go. Automatic Cleaning SystemA water-infused hygienic solution cleans stubble and debris from the shaver heads and refreshes the blades so Every Shave Feels Like New. Intellitec Multi-Level Charging System Clean - 10min Charge -1 hr Dry - Heater: 1hr 50min Clean-10min Dry- Heater: 2hr 50min Charge-1 hr Dry - Heater: 2hr 50min - Fan Dry - 2hr 50min Dry- Heater: 2hr 50min Fan Dry: 2hr 50min (see box for details) 30 Day Money Back Guarantee. One Year Limited Warranty.Abuse or misapplication of this product voids this guarantee. (see details inside) Service- Assistance - 800-338-0552panasonic.comshavers Made in China
    Panasonic Es8077s/svr Mens/triple Balde/pivot Hd/box Pk Questions
    Questions and Answers
    Where to Buy
    $99.99
    BizRate Rating Outstanding 9.2
    Product Reviews
    Last update: Jul 1, 2009
    Panasonic Es8077s/svr Mens/triple Balde/pivot Hd/box Pk Reviews
    Most helpful positive review
    [1 of 1 customers found this review helpful]
    Most helpful negative review
    [0 of 1 customers found this review helpful]
    5.0
    First time Electric Shaver user
    "I have only had this product for a few weeks but I already like it a lot. I was looking for a shaver to replace the Mach 3 blade I was using. Admittedly, I am not a hairy person and can go 2 - 3 days without having to shave. My skin and hair are very fair/sensitive, so blade shaving was always a problem for me, undoubtedly riddled with nicks/cuts/burns. I was looking for a solution to that and upon assessing..." Read Full Review »
    Feb 15, 2009 by Averse to Blades
    See more positive Panasonic Es8077s/svr Mens/triple Balde/pivot Hd/box Pk reviews
    1.0
    Not impressed
    "I bought this to replace my Norelco three blade rotary razor. I never used this type of razor and have read many reviews saying its better and smother for sensitive skin so I decided to give it a try. When I first turned it on (at 4:30am) my dog went crazy barking which woke the wife. It has a high pitch buzzing which is much louder than the Norelco. It is smoother on the skin only because it doesn't cut ver..." Read Full Review »
    Aug 31, 2008 by John
    See more negative Panasonic Es8077s/svr Mens/triple Balde/pivot Hd/box Pk reviews
    Displaying 1 - 5 of 11 Reviews
    Show
    Sort by
    5.0
      Pros
    • Consistent Performance
    • Durable
    • Easy To Configure
    • Versatile
      Cons
    • None
      Best Uses
    • Home
    • Portable Devices
    • Travel
    "I have only had this product for a few weeks but I already like it a lot. I was looking for a shaver to replace the Mach 3 blade I was using. Admittedly, I am not a hairy person and can go 2 - 3 days without having to shave. My skin and hair are very fair/sensitive, so blade shaving was always a …"  Read Full Review »
    Was this Electronics Accessory review on the Panasonic Es8077s/svr Mens/triple Balde/pivot Hd/box Pk helpful to you?
     Report Abuse  (1)  (0)  0 comments
    Feb 15 2009
    Averse to Blades
    Charlotte, NC
    I am:
    • Casual User
    Reviewed at:
    Price: $99.99
    Not impressed
    1.0
      Pros
    • None
      Cons
    • Unreliable
      Best Uses
    • None
    "I bought this to replace my Norelco three blade rotary razor. I never used this type of razor and have read many reviews saying its better and smother for sensitive skin so I decided to give it a try. When I first turned it on (at 4:30am) my dog went crazy barking which woke the wife. It has a hi …"  Read Full Review »
     Report Abuse  (0)  (1)  0 comments
    Aug 31 2008
    John
    Florida
    I am:
    • Professional
    Reviewed at:
    Price: $99.99
    Pretty darn good electric shaver
    4.0
      Pros
    • Easy to clean
    • Smooth wet shave
      Cons
    • Cheap carryin bag
      Best Uses
    • Home
    • Travel
    "I was told by doctors to start using an electric razor vs a blade razor (I have been a blade razor user my whole life) during my Leukemia teatment to prevent nicks and cuts that could cause infection. I was not pleased to hear that as I had never enjoyed using an electric razor. I researched the w …"  Read Full Review »
    Mar 18 2009
    KevOwens
    St. Augusutine, FL
    I am:
    • Casual User
    Reviewed at:
    Price: $99.99
    [3 of 3 customers found this review helpful]
    Before I purchased the ...
    5.0
    "Before I purchased the Panasonic 8077S just over a year ago, I had resigned myself to fact that with my rough skin, I'd never be truly satisfied with a shaver. Was I wrong. This one shaves smooth and close, and my 5 o'clock shadow doesn't show up until about 9-10 p.m. Braun makes some good shavers, …"  Read Full Review »
     Report Abuse  (3)  (0)  0 comments
    Jan 6 2007
    Wayne
    Milford, MI
    Reviewed at:
    Price: $99.99
    Good shaver
    4.0
      Pros
    • Easy To Configure
    • Easy To Use
    • Great for Travel
      Cons
    • None
      Best Uses
    • Home
    • Travel
    "This razor shaves best in the shower with shave cream. Next best is with shave cream outside of shower. Next best use is with electric pre shave. Then finely it does a fair job dry. Great travel and home shaver. The cleaner works well. Cartridges last about a week or maybe even 2 if used every day. …"  Read Full Review »
    Jul 1 2009
    Retired Christopher
    Kalamazoo, MI
    I am:
    • Casual User
    Reviewed at:
    Price: $99.99
    pages: 1 2 3 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
