Panasonic DMR-EA38VK DVD/VCR Combo
4.0
based on 22 reviews
Ratings Distribution
5 star
9
4 star
9
3 star
2
2 star
0
1 star
2
Category Average
3.5
Pros
  • Easy setup (12)
  • Easy to use (11)
  • High quality picture (11)
  • Consistent performance (10)
  • Attractive design (4)
  • Durable (3)
  • Fast setup (2)
  • Great picture quality (2)
  • Simple controls (2)
  • Features worth the cost (1)
See less See more
Cons
  • Can't handle 4gb card in (1)
  • Difficult to set up (1)
  • Flimsy (1)
  • Llittle expensive (1)
  • Slow to load (1)
  • Takes a while to boot up (1)
Best Uses
  • Home (12)
  • Office (3)
  • High volume usage (2)
  • Movies (2)
  • Video (2)
  • Dorm room (1)
  • Home theater (1)
  • Videotape to dvd copying (1)
Provided by Buzzillions.com
The Panasonic DMR-EZ47V features an Accutune high-precision analog/digital tuner for recording and viewing digital broadcasts without a set top box. The built-in Digital Tuner also allows the user to record one digital broadcast program while watching a second program. Other features include 1080p up-conversion to accommodate the growing trend to 1080p displays, EZ-Sync HDAVI Control system for one-touch operation of Panasonic home theater components, super multi-format recording and playback capability, DivX playback and an SD Card slot for storing, viewing and copying JPEG formatted still photos. 1080p digital video up-conversion produces virtual HD images from standard-definition sources. The DMR-EZ47V also makes it very easy to record from DV camcorders via a DVI.
The Panasonic DMR-EZ47V is a dual deck DVD video recorder/VHS recorder, combining the features and benefits of the two technologies. One of the major uses of DVD recorders is the transfer of VHS tapes to the more durable, higher picture quality DVD format. With that in mind, Panasonic offers this dual deck unit, giving users the ability to easily dub their home movies and recorded VHS tapes onto either a DVD-RAM or DVD-R disc, and from a DVD disc back to a VHS tape. The DMR-EZ47V also includes one touch dubbing. The user also has the option of watching VHS tapes or DVDs on a space saving combination product.
  • Accutune Digital/Analog Tuner
  • High Definition (1080p) Up-Conversion with HDMI
  • Built-in 4-Head Hi-Fi VHS VCR
  • One-Touch 2 Way Transfer DVD-VHS
  • Multi-Format Recording: DVD-RAM, DVD-R, DVD-RW, DVD+R and DVD+RW
  • Multi-Format Playback: DVD-RAM, DVD-R, DVD+R, DVD-RW, DVD+RW, DVD-Audio, DVD-Video, Video CD, Audio CD (CD-DA) and CD-R/RW
  • DV Input With DV Auto Recording and Automatic Playlist Creation
  • EZ Sync HDAVI Control
  • JPEG SD/SDHC Card Slot With Photo Storage and JPEG Viewer
  • MP3, DivX Playback
  • 2-Channel Dolby Digital Audio
  • Virtual Multi Encode System 2X Horizontal Resolution (500 Lines) for LP Mode
  • High Picture Quality With DIGA Engine
  • Time Slip Playback Functions with Time Slip Button
  • Chasing Playback, Simultaneous Recording and Playback
  • Selectable Recording Modes: XP, SP, LP, EP and Flexible Recording
  • Direct Navigator
  • Advanced MPEG2 Encoding Using Hybrid VBR (Variable Bit Rate) Technology
  • Progressive Scan Video Output for Playback
  • Optical Digital Output for dts and Dolby Digital
  • Smart Wheel Remote Control
  • Specification Description
    Model DMR-EA38VK, DMREA38VK
    UPC 037988256617
    Analog Audio Yes
    Analog Audio / Video Yes
    Card Slot Secure Digital
    Card Slot miniSD Card
    Compatible Formats CD
    Compatible Formats CD-R
    Compatible Formats CD-RW
    Compatible Formats DVD
    Compatible Formats DVD+R
    Compatible Formats DVD+R DL
    Compatible Formats DVD+RW
    Compatible Formats DVD-R
    Compatible Formats DVD-R DL
    Compatible Formats DVD-RAM
    Compatible Formats DVD-RW
    Compatible Formats DVD-VR
    Compatible Formats JPEG
    Compatible Formats MP3
    Component Video Yes
    Composite Video Yes
    Depth (Inches) 13.6
    Disc Capacity 1
    Disc compatibility (Play) CD - CDR/W - DVD - DVDR/W
    DVD Disc Compatibility (Record) DVD-RAM - DVD-R - DVD+R
    DVD Dual Layer Play Compatible Yes
    DVD Dual Layer Record Compatible Yes
    HDMI Yes
    Height (Inches) 3.3
    IEEE 1394 (Firewire) Yes
    Recordable Media Type DVD+R
    Recordable Media Type DVD+R DL
    Recordable Media Type DVD+RW
    Recordable Media Type DVD-R
    Recordable Media Type DVD-R DL
    Recordable Media Type DVD-RAM
    Recordable Media Type DVD-RW
    Remote Control Included
    S-Video Yes
    Select DVD / VCR Combos
    TV Broadcast Compatibility NTSC
    Type of DVD Unit Component DVD Recorder Player VCR Combo
    USB Port Yes
    Video Standard Up to 1080p High Definition
    Weight (Pounds) 11.90
    Width (Inches) 16.9
    Panasonic DMR-EA38VK DVD/VCR Combo Questions
    Questions and Answers
    Where to Buy
    Amazon   at Amazon.com
    ebay
    eBay listings for: DMR-EA38VK DVD/VCR Combo
    See all eBay results
      at eBay.com
    Product Reviews
    Last update: May 1, 2009
    Panasonic DMR-EA38VK DVD/VCR Combo Reviews
    Most helpful positive review
    [5 of 5 customers found this review helpful]
    Most helpful negative review
    5.0
    Great machine
    "I've tried every feature on this recorder and there have been no problems whatsoever. I have copied dozens of my old family VHS tapes to DVD and the quality on the DVD is even better than the original tape. I've used -R and -R/W primarily but have tried +R as well and they seem to work fine also. However the +R had problems playing on another brand of equipment, but that was mentioned in the owners manual. The o..." Read Full Review »
    Nov 02, 2008 by UltraClassic
    See more positive Panasonic DMR-EA38VK DVD/VCR Combo reviews
    1.0
    disaster
    "A NEW VCR/DVD COMBO THAT MAL FUNCTIONED. PANASONIC'S ANSWER WAS TO SEND IT TO THEIR REPAIR FACILITIES, THEY WOULD FIX IT AND SEND IT BACK AS A REFURB. I COULD HAVE BOUGHT A REFURB FOR CONSIDERABLY LESS. IT HAS BEEN REPLACED BY A TOSHIBA,WHICH WORKS VERY WELL AND COST MUCH LESS...." Read Full Review »
    Aug 11, 2008 by XXXXXXXXX
    See more negative Panasonic DMR-EA38VK DVD/VCR Combo reviews
    Displaying 1 - 5 of 22 Reviews
    Show
    Sort by
    Great machine
    5.0
      Pros
    • Consistent Performance
    • Easy To Set Up
    • Easy To Use
    • High Quality Picture
      Cons
    • None
      Best Uses
    • High Volume Usage
    • Home
    • Videotape to DVD copying
    "I've tried every feature on this recorder and there have been no problems whatsoever. I have copied dozens of my old family VHS tapes to DVD and the quality on the DVD is even better than the original tape. I've used -R and -R/W primarily but have tried +R as well and they seem to work fine also. Ho …"  Read Full Review »
    Was this Combo DVD Player & Recorder review on the Panasonic DMR-EA38VK DVD/VCR Combo helpful to you?
     Report Abuse  (5)  (0)  0 comments
    Nov 2 2008
    UltraClassic
    Virginia
    I am:
    • Enthusiast
    Reviewed at:
    [5 of 6 customers found this review helpful]
    nice machine with lots of options
    4.0
      Pros
    • Durable
    • Easy To Set Up
    • Easy To Use
      Cons
    • Llittle expensive
      Best Uses
    • High Volume Usage
    • Office
    "This machine has a ton of input and output options. I have used it a number of applications after owning it for only a month or two. The dv input is quite handy and makes it quite versatile while using it with the VHS and DVD formats. It a bit pricey, but worth the extra bells and whistles. "
     Report Abuse  (5)  (1)  0 comments
    Jul 28 2008
    pjmiii
    new jersey
    I am:
    • Gearhead
    • Professional
    Reviewed at:
    [2 of 3 customers found this review helpful]
    Slow to turn on but great video quality
    4.0
      Pros
    • Easy To Set Up
    • Easy To Use
    • Nice upconvert to 1080p
      Cons
      Best Uses
    • Dorm Room
    • Home
    • Office
    "It takes me a while to buy an electronic product. Besides reading reviews I'll go down to the local electronic store, pick up a product, test it out, and then return it if it's not up to par. The EA38VK was my third DVD/VCR combo (tried the Sony and LG first). The Panasonic had the best upconvert al …"  Read Full Review »
     Report Abuse  (2)  (1)  0 comments
    Mar 2 2009
    KenY
    San Diego, CA
    I am:
    • Casual User
    Reviewed at:
    [3 of 3 customers found this review helpful]
    Great for the price
    4.0
      Pros
    • Attractive Design
    • Fast Setup
    • Great Picture
    • Simple Controls
      Cons
    • Can't handle 4GB card in
      Best Uses
    • Home
    • Movies
    • Video
    "Great for VHS to DVD copy, also great for digital camera to DVD copy. Nice DVD picture quality using upconvert. "
     Report Abuse  (3)  (0)  0 comments
    Apr 17 2008
    Jsmith8198
    Hickory HIlls, Illlinois
    I am:
    • Tech Savvy
    Reviewed at:
    [1 of 1 customers found this review helpful]
    excellent product
    5.0
      Pros
    • Easy To Set Up
    • Easy To Use
      Cons
    • None
      Best Uses
    • Office
    "I purchased this product primarily to transfer VHS to DVD. It is very easy to use for this purpose - essentially a single push of a button is all that is needed. In addition, I am using it to playback DVD's onto a 50" Pioneer Plasma screen via HDMI -- the interface and the remote are easy - direct …"  Read Full Review »
     Report Abuse  (1)  (0)  0 comments
    Oct 14 2008
    Joshua
    Berkeley, CA
    I am:
    • Casual User
    Reviewed at:
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    ebay
      at eBay.com
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
