Panasonic DMP-BD35 Blu-ray Player with 1080P Resolution
4.7
based on 96 reviews
Ratings Distribution
5 star
75
4 star
16
3 star
4
2 star
0
1 star
1
Category Average
4.2
$127.95 - $239.99
from 16 stores
More Images
Pros
  • Easy setup (45)
  • Great picture quality (42)
  • Good connections (40)
  • Dvd upconversion (34)
  • Good soundtrack support (34)
  • Backwards compatible (23)
  • Upgradeable (23)
  • Bd-live ready (1)
  • Easy to use (1)
  • High quality picture (1)
See less See more
Cons
  • Slow load time (10)
  • A bit slow load time (1)
  • Bd live (1)
  • Hdmi cable not included (1)
  • Needs hard drive space (1)
  • No audio button on remote (1)
  • No subtile on remote (1)
  • Nothing bad about it (1)
  • Only time expired display (1)
Best Uses
  • Home theater (27)
  • Lcd tv (21)
  • Plasma tv (20)
  • Home (18)
  • Dlp tv (6)
  • Office (3)
  • New generation av amp (1)
Provided by CameraWorld.com
The Panasonic DMP-BD35 Blu-ray Disc Player features technology that reproduces movies with colors that are exceptionally faithful to the original. With PHL Reference Chroma Processor Plus, users viewing content on Blu-ray Discs enjoy crisp, vivid colors that are extremely close to the original.
It features an HD Audio Decoder (Dolby TrueHD, Dolby Digital Plus and DTSTM-HD Master Audio Essential), which supports the 7.1-channel surround sound newly adopted in Blu-ray Discs. Users can enjoy 7.1-channel surround even with systems that do not support HD Audio - as long as the BD35 is connected to a 7.1-channel receiver equipped with an HDMI terminal. The high-quality image and sound technologies found in the BD35 are incorporated in the UniPhier chip.
UniPhier is a Panasonic-created system LSI developed by applying 45-nanometer processing to a consumer product - a world's first. This single-chip integration technology also contributes greatly to the BD35's world's slimmest height of 49mm. It features BD-Live compatibility which enables users to connect to the Internet to download images, subtitles and other data and take part in interactive activities and multi-player games linked to bonus cinema content found on Blu-ray Discs.
It is equipped with an SD Memory Card slot that makes it easy to transfer images from an HD camcorder or digital still camera that uses SD Memory Cards. Simply insert the SD card into the DMP-BD35 and it plays AVCHD-format video images or JPEG stills in full 1920 x 1080 resolution on your flat panel HDTV. It can also play slide shows, complete with background music. It is also compatible with Panasonic's VIERA Link function so they can be operated by the VIERA HDTV remote control.
Specification Description
Model DMP-BD35, DMP-BD35K, DMPBD35, DMPBD35K
UPC 037988257188
Analog Audio / Video (1) Rear Output
Compatible Formats BD
Compatible Formats BD-R
Compatible Formats BD-RE
Compatible Formats BD-ROM
Compatible Formats CD
Compatible Formats CD-R
Compatible Formats CD-RW
Compatible Formats DVD
Compatible Formats DVD+R
Compatible Formats DVD+R DL
Compatible Formats DVD+RW
Compatible Formats DVD-R
Compatible Formats DVD-R DL
Compatible Formats DVD-RAM
Compatible Formats DVD-RW
Compatible Formats DVD-VR
Compatible Formats MP3
Component Video (1) Rear Output
Disc Capacity 1
Disc compatibility (Play) CD - CDR/W - DVD - DVDR/W
DiVX Play Compatible Not Applicable
DVD Disc Compatibility (Record) DVD Play Only - Does not record
DVD Dual Layer Play Compatible Yes
DVD Dual Layer Record Compatible Does not Record
HDMI (1) Rear Output
Manufacturer’s Warranty 1 Year
Optical (1) Rear Output
Power Supply 110 Volts AC
RJ45 Ethernet (1) Rear Output
Select DVD Players
Surround Modes DTS
Surround Modes DTS-HD High Resolution
Surround Modes Dolby Digital
Surround Modes Dolby Digital Plus
Surround Modes Dolby TrueHD
TV Broadcast Compatibility NTSC
Type of DVD Unit Blu-Ray
Video Standard Up to 1080p High Definition
Panasonic DMP-BD35 Blu-ray Player with 1080P Resolution Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Mar 1, 2009
Panasonic DMP-BD35 Blu-ray Player with 1080P Resolution Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
[3 of 4 customers found this review helpful]
5.0
GREAT Player!
"This is a great Blu-ray dvd player. I was originally going to get the BD30 but decided to hold off for this one since it was the same price and had BD Live and an ethernet connection. With the player connected to your network it will let you know when new firmware is available. As soon as I plugged it in, I was advised firmware 1.5 was available so I had the player load it. Took less than 5 minutes. The picture..." Read Full Review »
Nov 13, 2008 by JTalbert
See more positive Panasonic DMP-BD35 Blu-ray Player with 1080P Resolution reviews
3.0
Missing Connection
"I bought my first HDTV (50" Panasonic Plasma) 12/14/08 and decided to buy a Bluray player a week later to enhance my viewing experience. Sears was running a sale on Bluray players so why not, right? I purchased this player based on CNET's product review and it being a Panasonic, it is EZ Sync capable to my HDTV remote via Panasonic's Viera Link HDAVI Control Picture quality is much improved when playing standa..." Read Full Review »
Dec 23, 2008 by Rokester
See more negative Panasonic DMP-BD35 Blu-ray Player with 1080P Resolution reviews
Displaying 1 - 5 of 96 Reviews
Show
Sort by
GREAT Player!
5.0
    Pros
  • DVD Upconversion
  • Easy Set-Up
  • Excellent Image Quality
    Cons
  • BD Live
    Best Uses
  • Plasma TV
"This is a great Blu-ray dvd player. I was originally going to get the BD30 but decided to hold off for this one since it was the same price and had BD Live and an ethernet connection. With the player connected to your network it will let you know when new firmware is available. As soon as I plugged …"  Read Full Review »
Was this Blu-Ray Player review on the Panasonic DMP-BD35 Blu-ray Player with 1080P Resolution helpful to you?
 Report Abuse  (2)  (0)  0 comments
Nov 13 2008
JTalbert
McLean VA
I am:
  • Casual User
[7 of 7 customers found this review helpful]
My First Blu Ray
5.0
"This is my first Blu Ray player. I did several weeks of research on the differences between all that are out there and kept coming back to this one. I am an extreme novice when it comes to the specs, but reading all the comments from different people, I found it hard to resist this purchase. I've on …"  Read Full Review »
 Report Abuse  (7)  (0)  0 comments
Nov 23 2008
Skyy13
Currently Dallas TX - Las Cruces NM
Much better than Samsung BD-1500
5.0
    Pros
  • Backwards Compatible
  • DVD Upconversion
  • Easy Set-Up
  • Good Connections
  • More »
    Cons
  • None
    Best Uses
  • Home
  • Home Theater
  • LCD TV
"I purchased a Samsung BD-1500 it worked fine until I upgraded the firmware, after that it would not play DVDs or CDs anymore. Samsung did not return my email messages to their support desk, so I returned the Samsung to [...] and picked up the panasonic BD-35K.What a difference. Like night and day.T …"  Read Full Review »
Feb 3 2009
los angeles, CA
I am:
  • Enthusiast
2 minor quibles, but lots of value!
4.0
    Pros
  • DVD Upconversion
  • Easy Set-Up
  • Good Connections
  • More »
    Cons
    Best Uses
  • Home Theater
  • Plasma TV
"I think that the things I don't like about this player are things that might be inherent in the Blu-Ray format. The two things I liked most about my previous non-Blu-Ray player are the subtitle and audio buttons on the remote so I didn't have to go back to the menu to change from the commentary to t …"  Read Full Review »
Jan 12 2009
Warlock 5
Michigan
I am:
  • Enthusiast
Reviewed at:
Price: $169.95
Excellent Blu-Ray Player!
4.0
    Pros
  • DVD Upconversion
  • Easy Set-Up
  • Good Connections
  • Good Soundtrack Support
  • More »
    Cons
  • None
    Best Uses
  • Home Theater
  • LCD TV
"After much online research, I bought the Panasonic DMPBD35 Blu-Ray DVD Player. I have it hooked up to a Samsung LN52A650 LCD HDTV, and a Harman Kardon AVR 354 A/V receiver that powers Monitor Audio speakers.
I wanted a good stand alone Blu-Ray as I am not a gamer and found no justification in spen …"  Read Full Review »
Dec 15 2008
Michael Z
Brooklyn, NY
I am:
  • Enthusiast
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$168.00
BizRate Rating Outstanding 9.4
$169.95
BizRate Rating Outstanding 9.1
$127.95
$127.95
BizRate Rating Outstanding 9.2
$129.99
$136.88
$1.99 Shipping On Orders Over $100 at TigerDirect
$137.99
$138.00
$143.99
$146.99
$149.99
$169.95
$169.99
$169.99
$169.99
Code SEARS5OFF50 : $5 Off Orders Over $50!
$239.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
